A different tyre question
www.125power.com
PostPosted: 18:58 - 08 Feb 2006    Post subject: A different tyre question Reply with quote
Hi all, i want a bit fatter profile on my rear and front tyres, and they offer very little grip in the corners.
What do the numbers mean??
100/80 -17 is my rear tyre size ( i know the 17 is rim size)
does 100 mean the width of the rim and 80 mean the rpofile of the tyre? i.e how curved it is? If it does what profile will be rounder (more rubber at egdes for cornering). Thanks all Thumbs Up
My eBay Items
Zimbo
PostPosted: 19:21 - 08 Feb 2006    Post subject: Reply with quote
The 100 refers to the width of the tyre in mm, the 70 is the depth of the tyre expressed as a percentage of it's width.
Be aware that fitting wider tyres may cause clearance problems with mudguards / huggers, swinging arm, and chain.
Also be aware that fitting wider tyres than the bike was designed for is likely to provide worse handling, not better. Big bikes have wide tyres because they have a lot of power to put down. Just watch the corner speed of 125cc 2-stroke race bikes and you'll see what I mean!
The Tot
PostPosted: 19:24 - 08 Feb 2006    Post subject: Reply with quote
the 100 will mean the width of the tyre and the 80 will mean that it's the height of the tyre as a percentage of the tyre's width i.e. 80mm in this case.
you'd ofter worsen your handling if you fit wider tyres as it gives more of a "cliff edge" feeling. You're also going to be adding more rolling mass.
There's simply no need to do anything to the tyres on the CBR125. The best thing you can do to improve the handling is to get some bridgestones instead of the eagles or kenda or whatever the hell they put on those as standard.
EDIT: Whoops seems like Zimbo already answered the question
Never argue with autism
www.125power.com
PostPosted: 19:28 - 08 Feb 2006    Post subject: Reply with quote
i thought wider tyres, but ones were the wall of the tyre is only small maing a lot more of a radiused corner than a cliff edge. Mine have a nice blend between tyre wall and the actual its just the part of the tyre your are riding on is actually about a cm wide when you lean over
My eBay Items
www.125power.com
PostPosted: 19:47 - 08 Feb 2006    Post subject: Reply with quote
there is pair of pirellis available for these bikes but i cant rmember what size they were i think they were 100/70/17 but look a lot rounder ad look like youll get a lot more grip in the corners
My eBay Items
PostPosted: 19:48 - 08 Feb 2006    Post subject: Reply with quote
The manufacturers fit the best tyres from the factory. The ratio between 'profile' and 'tyre wall' is carefully calculated to work with the suspension of the bike.
Change anything and your bike will handle worse.
www.125power.com
PostPosted: 19:58 - 08 Feb 2006    Post subject: Reply with quote
So there is no way i can get more rubber on the ground when leaning over? This sucks! Any one recommend a good tyre for them them???
My eBay Items
meooo
PostPosted: 20:21 - 08 Feb 2006    Post subject: Reply with quote
my lad has nsr125 & it was on stock pirellis
hes changed the rear for brigestone and is changing the front to the same asap, apparantly they stick a lot better to the road.
Zimbo
PostPosted: 21:13 - 08 Feb 2006    Post subject: Reply with quote
You can try different brands and models of tyre within the range, as long as you stick to the same sizes. The pirellis may well suit you better. Are you having problems with cornering grip on the standard tyres, on a dry warm day? In winter conditions, all tyres will slip . . . .
Davo
Davo To The Rescue!
PostPosted: 21:15 - 08 Feb 2006    Post subject: Reply with quote
The only thing I can suggest there is to try hanging off a little more.
PostPosted: 21:21 - 08 Feb 2006    Post subject: Reply with quote
CBR125 is a nice handling little bike, I rode my GFs one when it was new and it went round corners like it was on rails. I can't see why you should be having any problems on the standard tyre sizes.
Chiz
PostPosted: 22:06 - 08 Feb 2006    Post subject: Reply with quote
My NSR handles a lot better on my new Bridgestone Battlax's, in comparison to the old Pirellli MT75's. If its a CBR125 (think i read that somewhere) then i don't know, the tyres on that really are small. Apparently the CBR125 was a bike designed as a commuter bike for the Asian (Thailand? etc) market. Honda sleeved down the engine to 125 (from 150) and put some fairings on it. So it was never designed for handling or speed, but i don't know about different wheels etc. Definetly recommend Bridgestones though. Thumbs Up
www.125power.com
PostPosted: 23:53 - 08 Feb 2006    Post subject: Reply with quote
It does go round most corner like its on rails, but say you want to go 3/4 way round a round about then it starts to slip out..........same for a long corner once you getting past 1/2 - 3/4 of way round they start to slip out.......I havnt put one scratch on my sliders because of this........it always mean gently coming off the throttle and trying to press as much weight onto the rear as possible to make it "dig in" ( other alternative is to chuck it up straight again but i cant always do that (cars on other side of road etc ect))
They are shite tyres though, if i lean over handle bars to stop it doing a wheelie and just dump the clutch it spins......on warm dry tarmac! Not by any means am i saying my bike is immensly powerful but the fact it will do this is not much reassurance for trying to learn how to corner properly. Oh yea will stiffer rear suspension help me corner better or will it be more likely to "jitter" on the country roads?
My eBay Items
www.125power.com
PostPosted: 00:01 - 09 Feb 2006    Post subject: Reply with quote
Davo, if i hang off any more surely it will just go from under me quicker?? I mean im leaning it as far as i dare because the tires slip, and i dont have any mushrooms yet....
No not magic ones to make me fearless before it gets said.....
My eBay Items
No offence, but sounds like it's the rider not the tyres that are your limit so far.
If a tyre is going to slip, there's usually no reason it will wait until 3/4 of way around. Thus it would lead me to think you are changing something at the point or before incorrectly
First off, are you on a slightly open throttle? You should be gently accelerating throughout the turn. The idea is to give 60/40 weight distribution towards the rear as the rear tyres have a bit bigger contact patch.
Also consider your position? Are you too far forwards or back on the seat. Trying to press as much weight onto the rear may well make it overload the rear tyre more.
A light bike with you leaning over the front is quite likely to slide. If it did the same when you were sitting on the seat I'd be more worried, but still not immesly so; you should still have decent lean unless they're really bad.
I'm sure your tyres could be better, but I reckon the first stop should be trying to get some smoother more technical riding to make the most of what you have at the moment.
www.125power.com
PostPosted: 00:11 - 09 Feb 2006    Post subject: Reply with quote
Okay all just found a piccy of them pirellis i was on about.look at how rubber is on the edge of the tires surely this has got to help???
https://img6.imageshack.us/img6/3592/10oktober0028fs.jpg
^^not sure wich one will work
My eBay Items
www.125power.com
PostPosted: 01:07 - 09 Feb 2006    Post subject: Reply with quote
entering
No offence what so ever mate, i am picking my lines to go as smoth ass possible i.e the straightest way round the corner. Ive been using the same road to get more used to what i have to do and i figured what corners at what speeds.think the fastest one is 65.
I am not braking or anything i do that long before the corner to give me chance to get settled. Usually the back of my leg and one half my arse cheek is still on the seat (saying that im about 5'6") (im cant put both feet flat on the floor if i sit too far back on the bloody thing) from that id say the 40/60 is about right.
cornering
I am not conciously changing anything as i go round a corner it just sems to be mid corner when its starts to feel a little wrong....im sure my knee should be on the floor by now...
I just arrive at the corner doing say 60 lean it in keeping it at 60 then about half way round (just after suspension and bike settles) it seems to start slipping. This problem is worsened when accelerating obviously but i cant say by how much as i dont like it and slow down Embarassed
sliding
When it does try to slide i really press on the inside peg and pull the outside of the bike towards the floor with my other leg and it seems to stop sliding and grip again (im pressing all my weight towards the road - i hope, thats what im trying to do anyways)
take-off's
I am still on the seat when it spins although i lean right onto the handle bars to stop it wheelie-ing.
My eBay Items
www.125power.com
PostPosted: 01:08 - 09 Feb 2006    Post subject: Reply with quote
P.S if im doing it all wrong just say "Gav, you fucking muppet"
Dont forget to explain what i done wrong though Thumbs Up
My eBay Items
AcIdBuRnZ
PostPosted: 01:20 - 09 Feb 2006    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing
You serious?
Anyway. So you are trying to knee down at 60mph on cold tyres on crappy roads at near freezing temperatures and you are wondering how the tyres are slipping? Laughing
www.125power.com
PostPosted: 01:27 - 09 Feb 2006    Post subject: Reply with quote
Yep im serious........8-9000rpm and dump clutch from standing start........might only be 14BHP but im only 8-stone....
Nope not in freezing temps wait till its warmed up mid-day (on soem lucky days we getting a bit of heat and sun) go do an hours ride to warm tires up, get to my "practice road" go up it with front brakes trailing (helps warm front tyre up) do a burnout at the top if its really cold and fly back down and see what happen's. At present it is doing no better or worse than it did last summer.......
My eBay Items
Davo
Davo To The Rescue!
PostPosted: 01:32 - 09 Feb 2006    Post subject: Reply with quote
Still doesn't mean that it's ideal temperature for your tyres to give optimal grip.
If I was you I'd practice pulling away a little, when I did my stint on a CG125, I found there was no need rev it that high to make it pull away.
Are there any bikesafe or rider training schools in your area, may be worth polishing up your riding (e.g. maybe move towards taking your test). I think this may be the better way for you, as it's a bit difficult to help whilst sitting in front of a computer screen.
PostPosted: 01:35 - 09 Feb 2006    Post subject: Reply with quote
What do they have on now? Maybe your bike has the wrong tyres on, did you buy it from new?
I could have sworn they were pirelli MT75 as standard.
If not, they are something similar, can't find what the original fitment tyre is supposed to be, but here is a picture of the rear tyre on a brand new CBR125R.
www.125power.com
PostPosted: 01:37 - 09 Feb 2006    Post subject: Reply with quote
i can pull away perfectly fine ......just when i tried to race my mate i noticed that if i pull off as said above the bike doesnt have much of a tendacy to acclerate just to shred the rear wheel instead
Getting my knee down is what i want to learn while i still have a light skinny bike.......so i dont kill myself on my RVF wich i have set my heart on but i need to pull a few grand out my arse before i get it Crying or Very sad
My eBay Items
www.125power.com
PostPosted: 01:40 - 09 Feb 2006    Post subject: Reply with quote
I bought it brand new its done 3000miles and no more than 5 burnouts (all of wich where upright so ive only damaged the middle part of the tyre)
original fitment is 100/80 rear but no idea on make will check tommorow and get back to you
And idea if them pirelli's i showed you about 9 post up will help my grip better?
My eBay Items
PostPosted: 01:53 - 09 Feb 2006    Post subject: Reply with quote
I always used to use pirelli MT65 on my smaller bikes and they were great, the MT75 is the new version so I reckon they should be perfectly adequate, but I would get them in the original size.
Beware of trying to run before you can walk. I bet there are very few people on this forum, even experienced riders on the latest sports bikes who would be even thinking about knee-down cornering at this time of year. Even when the road looks dry, it is still covered in salt. The salt acts like a fine grinding compound and 'polishes' the surface of the road as tyres run over it. Very slippery.
As a general rule, if you are outriding the grip on a tyre like that at this time of year, it isn't a problem with the tyre, it is just you are going at it too hard. Back off.
And since this is the internet and I can say what I want. I reckon with all this talk of popping wheelies, knee down and burnouts, you are going to knacker a perfectly good wee bike in short order, if you don't come off it first. Sounds to me like you are flogging the proverbial tits off it and while it is a robust wee motor, it won't take that sort of abuse forever.
[/dad mode]
The last post was made 20 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 137.54 Kb
