How to change break disc on Yamaha R6
Shan
PostPosted: 16:41 - 09 Feb 2006    Post subject: How to change break disc on Yamaha R6 Reply with quote
Can anyone pls point me towards any decent website that shows how to change break discs on Yamaha R6.
As it's going to be my first attemp, I am trying to be careful and not mess up things, therefore any help would be appreciated.
R4nger
PostPosted: 17:35 - 09 Feb 2006    Post subject: Reply with quote
www.haynes.co.uk
Shan
PostPosted: 17:51 - 09 Feb 2006    Post subject: Reply with quote
I have seen this website and is very generic and not specific to what I am looking for - But thanx anyway.
Rookie
PostPosted: 18:00 - 09 Feb 2006    Post subject: Reply with quote
I think his point was; get a Haynes manual for your bike. It will tell you how to do just about anything to it.
0ni
PostPosted: 18:36 - 09 Feb 2006    Post subject: Reply with quote
Rear disc:
1. Remove rear wheel
Remove rear calliper. Undo rear axle nut. Note where bits are, spacers tensioners etc. Give axle polite nudge out its wee hole. Wheel will then be movable. Moving it towards the bike will give you enough slack on the chain to get it off. You now have a loose wheel.
2. Remove old disc
Undo bolts. Remove disc.
3. Fit new disc
Fit disc. Tighten bolts.
4. Fit rear wheel
Opposite of above. Don't forget any silly things like putting the drive chain around the sprocket.
Front discs:
1. Remove front wheel
Undo callipers, undo bolts holding wheel in. Drop wheel out.
2. Remove old discs
As above
3. Fit new discs
Again as above
4. Fit front wheel
As a above.
A few things to note when refitting the brake callipers, the discs are going to be a bit thicker as they are new, you may have to use some light persuassion to move the pads back a bit.
I would really get a haynes manual though.
Its a lovely day, just wait until some bastard spoils it.
divuk83
PostPosted: 19:36 - 09 Feb 2006    Post subject: Reply with quote
Its best to put new pads on as well when you fit a new disc.
Dave
ancientd
PostPosted: 20:23 - 09 Feb 2006    Post subject: Reply with quote
Be careful undoing the disk fixing bolts, they have a habit of snapping, make sure you spray plenty of WD40 on the back of the bolts to remove and build up. I recently did my Thundercat disks and on the front wheel 7 of the 12 bolts snapped, it was a nightmare getting the studs out and new threads put in.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
ZRX61
Victor Meldrew
PostPosted: 16:44 - 10 Feb 2006    Post subject: Reply with quote
Thats because rotor bolts usually have red loctite on em which requires heat to loosen...WD40 won't be of any use whatsoever.
Cillit-BANG
PostPosted: 17:09 - 10 Feb 2006    Post subject: Reply with quote
Points to note-
Pouring boling water over the old disk bolts should help loosen them off. Naturally avoid getting this on other bike parts.
Gently tightening the old bolt first will help break the seal without mashing up the bolt head.
A firm yank is better than a slow gradual twist. Always ensure the tool has a good seating before applying any pressure.
Apply thread-lock to the bolts when you replace them.
Torque the bolts down in a star type pattern, to avoid distorting the disk (as you would on cylinder head for example).
Use the manufarcturers torque settings. If you havn't a torque wrench, borrow one.
Wipe new disks down with suitable cleaner before exposing them to brake pads. Meths will do as a cheap substitute.
Jrod
Page 3 Girl
PostPosted: 18:37 - 10 Feb 2006    Post subject: Reply with quote
I wouldn't put wd40 anywhere near my discs.... Shocked
ancientd
PostPosted: 19:49 - 10 Feb 2006    Post subject: Reply with quote
No its because the back of the bolts are open into a dirt trap in the wheel hub. They sit in mud and the end of the bolt becomes highly corroded and starts to bind after a couple of turns and then tends to shear at the top of the bolt due to 'Work hardening' and localised stressing. Spraying WD on to them helps if you can get enough in there.
And as the idea is to change the disc it won't matter getting WD all over it.
DukeRed
PostPosted: 19:53 - 10 Feb 2006    Post subject: Reply with quote
Old discs to be thrown out. Rolling Eyes .
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Jrod
Page 3 Girl
PostPosted: 23:10 - 10 Feb 2006    Post subject: Reply with quote
No one said they were going to be thrown out, he might want to take them off to get the wheels powdercoated or loads of other reasons so stfu. Rolling Eyes
ancientd
PostPosted: 23:18 - 10 Feb 2006    Post subject: Re: How to change break disc on Yamaha R6 Reply with quote
This was the first post. He said 'Change'
Jrod
Page 3 Girl
PostPosted: 23:53 - 10 Feb 2006    Post subject: Reply with quote
Ok so he wants to change them, what if he wants to sell the others or keep them as spares? Putting wd40 near brakes is just plain stupid imo.
numark1
Scared of girls
PostPosted: 23:58 - 10 Feb 2006    Post subject: Reply with quote
It would come off pretty easy though. Confused
JamesVFR This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Shan
PostPosted: 16:13 - 13 Feb 2006    Post subject: Reply with quote
Alright alright, stop fighting over it...
Thank you all for your advise and would keep these things in mind when I am "changing" my break discs Very Happy
The last post was made 20 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 100.29 Kb
