I wondered why my bike was running like sh*t...
Dom_
Points Mean Prizes
PostPosted: 13:55 - 09 Feb 2006    Post subject: I wondered why my bike was running like sh*t... Reply with quote
https://img143.imageshack.us/img143/9016/sparkplug6ht.jpg
What zee hell has caused that, they were changed fairly recently.
shammon
PostPosted: 17:07 - 09 Feb 2006    Post subject: Reply with quote
Thats Gubbed! I can only think it was the wrong plug for it to get a pounding like that.
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
fazed
Korn is my hero!
PostPosted: 17:20 - 09 Feb 2006    Post subject: Reply with quote
What do the other's look like ? have you got a race can, different air filter etc?
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
Dom_
Points Mean Prizes
PostPosted: 17:52 - 09 Feb 2006    Post subject: Reply with quote
Not taken the others out yet, i've been asleep all day. Laughing
Got a K and N, full stainless system.
PostPosted: 18:13 - 09 Feb 2006    Post subject: Reply with quote
Either the piston has hit that plug, or the pot it came from is running lean as hell.
If it is the latter, you are not far away from a holing a piston. Get it sorted quick.
Dom_
Points Mean Prizes
PostPosted: 18:20 - 09 Feb 2006    Post subject: Reply with quote
Shocked Erm,,,,f*ck!
I've got some spare time saturday morning, i'll get the rest of them out and see what they look like.
It did only start running like crap after i'd got back from birmingham, most of the motorway was taken at fairly high revs (13-14k.)
The reason i took the plug out was because it spat out, so somehow had vibrated loose, then was spat out under compression as it was only the last couple of threads holding it in.
Am i looking at 2 different problems here do you think?
sickpup
Old Timer
PostPosted: 23:07 - 09 Feb 2006    Post subject: Reply with quote
If the plug was loose the cylinder would run lean.
Dom_
Points Mean Prizes
PostPosted: 23:24 - 09 Feb 2006    Post subject: Reply with quote
I was thinking exactly that sickpup. Still i'll have a look at the other plugs and see how they are.
ancientd
PostPosted: 23:38 - 09 Feb 2006    Post subject: Reply with quote
I would do a compression test on the bike, there is another option to explain the damage, and that is that a valve has broken up and the bits took out the plug before it went through the rest of the engine
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
PostPosted: 23:54 - 09 Feb 2006    Post subject: Reply with quote
I take it that the outer electrode has broken off? Looks like it has been running hideously lean. Not sure if would land up that dry and burnt just from leaking around the plug. Serious heat from running lean might well cause the electrode to come off (and it might well have done some damage).
Be interesting to see the state of the other plugs. Also take the carbs off (probably will have to when taking the plugs out), and check the condition of the carb rubbers. Check the mount for that cylinder to check the carb was seated properly. Also worth checking the carb diaphragm (perforrated the slide won't lift so it will run lean).
PostPosted: 23:55 - 09 Feb 2006    Post subject: Reply with quote
To go with the compression test, good luck finding an adaptor that will fit.
sickpup
Old Timer
PostPosted: 00:04 - 10 Feb 2006    Post subject: Reply with quote
They are available. I have them.
bish777
PostPosted: 00:11 - 10 Feb 2006    Post subject: Reply with quote
youve not rejetted obviously. And its run lean. And melted things.
Lesson 1-freeing exhaust and inlet requires rejetting........
GSXR1100J
Bezzer
PostPosted: 00:14 - 10 Feb 2006    Post subject: Reply with quote
Did you have it checked - dyno'd/jetted when you fitted the new exhaust and filter?, might have coped with one but both would have probably leaned it right out, the high speed/revs run wouldn't have helped.
Dom_
Points Mean Prizes
PostPosted: 00:22 - 10 Feb 2006    Post subject: Reply with quote
It had the K and N on before i bought it, i fitted the downpipes.
It's made a fair few motorway journeys since then though, and i do tend to be at high revs a lot of the time.
PostPosted: 00:27 - 10 Feb 2006    Post subject: Reply with quote
Yeah, but you bought the entire stock Laughing .
sickpup
Old Timer
PostPosted: 22:09 - 10 Feb 2006    Post subject: Reply with quote
Wanna see the charge for renting a set?
Never said I was a nice person now did I. Twisted Evil
The last post was made 20 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 96.52 Kb
