| Dom_ |
 Dom_ Points Mean Prizes
| shammon |
 shammon World Chat Champion
| fazed |
 fazed Korn is my hero!
| Dom_ |
 Posted: 17:52 - 09 Feb 2006 Post subject: |
Not taken the others out yet, i've been asleep all day.
Got a K and N, full stainless system. |
| stinkwheel |
 Posted: 18:13 - 09 Feb 2006 Post subject: |
Either the piston has hit that plug, or the pot it came from is running lean as hell.
If it is the latter, you are not far away from a holing a piston. Get it sorted quick. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dom_ |
 Posted: 18:20 - 09 Feb 2006 Post subject: |
Erm,,,,f*ck!
I've got some spare time saturday morning, i'll get the rest of them out and see what they look like.
It did only start running like crap after i'd got back from birmingham, most of the motorway was taken at fairly high revs (13-14k.)
The reason i took the plug out was because it spat out, so somehow had vibrated loose, then was spat out under compression as it was only the last couple of threads holding it in.
Am i looking at 2 different problems here do you think? |
| sickpup |
 sickpup Old Timer
| Dom_ |
| ancientd |
 ancientd Renault 5 Driver
| Kickstart |
 Kickstart The Oracle
 Posted: 23:54 - 09 Feb 2006 Post subject: |
I take it that the outer electrode has broken off? Looks like it has been running hideously lean. Not sure if would land up that dry and burnt just from leaking around the plug. Serious heat from running lean might well cause the electrode to come off (and it might well have done some damage).
Be interesting to see the state of the other plugs. Also take the carbs off (probably will have to when taking the plugs out), and check the condition of the carb rubbers. Check the mount for that cylinder to check the carb was seated properly. Also worth checking the carb diaphragm (perforrated the slide won't lift so it will run lean).
| Kickstart |
| sickpup |
 sickpup Old Timer
| bish777 |
 bish777 World Chat Champion
| Bezzer |
 Bezzer World Chat Champion
| Dom_ |
| Kickstart |
| sickpup |
 sickpup Old Timer
The last post was made 20 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
