Making Downpipes
numark1
Scared of girls
PostPosted: 19:03 - 09 Feb 2006    Post subject: Making Downpipes Reply with quote
Having a real real real hard time finding downpipes for a fzr400, sourced some exup 600 pipes but not sure if they will fit and charging over £200. Confused
How easy would it be to make some? I was having a think and i don't think it would be too bad. 4 Bits of pipe, calcuate how it needs to be bent, get a garage or whatever to bend it, weld brackets on to secure it onto the engine then maybe extend the pipes so i can have an underseater. Cool
Yay or nay?
Gazdaman
I did a trackday!!!
PostPosted: 19:12 - 09 Feb 2006    Post subject: Reply with quote
Why have I got images of you sitting there with a bit of plastic guttering and a lighter?
No mate, I wouldn't try it, just keep an eye on eBay or go looking round some breakers. FZR400s pop up quite a lot.
If you think, people buy micron or whatever full systems because they increase power over the standard pipework, and that's not the end can, it's the pipework aswell. It's not just the metal being bent, there's so much more in the equasion.
Gaz
PostPosted: 19:50 - 09 Feb 2006    Post subject: Reply with quote
Down pipe design is very important (far more important than some tatty old can on the end). As such you can't just lob something together (and also why an exhaust for an engine that revs to a far lower level such as the FZR600 is not the best thing to use).
There are people around who will make them up. Best if you have some to copy (full of holes should still be fine). Try Gazelle or OS Stainless.
Ichy
I made some for a street fighter I was building a few years ago. Spent about 10 quid on bits of pipe from a dealer and built them at work. Rather than bend the pipes, I don't know anyone that had a pipe bender big enough, I cut segments and welded it all together. Took about 2 months to finish them and they did look pretty good on the bike, very 'industrial' . It did restrict the bike though, lost about 20mph top speed but that was running stock carbs with K&n's so it probably would of helped if I rejetted.
On a 4 stroke most downpipes will work as long as the gases can flow freely.
mchaggis
PostPosted: 21:24 - 09 Feb 2006    Post subject: Reply with quote
Thats's fine until you get to collector boxes for multi-cylinder engines. Then you have perform some calculations with the lengths of the manifolds and the firing intervals to work out what the pressure pulses are doing in the exhaust. If you get the lengths of pipe wrong, you might end up with a high pressure pulse emerging from two different pipes into the same collector at once, which is bad news as it then restricts both pipes.
As with the rest of the exhaust and silencer system, you need to tune all the pipes with their length and diameter so as to avoid having high pressure pulses of gas coinciding. That is only really possible to tune around with a fixed system at one engine speed, which is why variable exhaust systems are used (e.g. EXUP).
I must not be a troll...
Mmmm, Guinness
Brava210
PostPosted: 21:49 - 09 Feb 2006    Post subject: Reply with quote
Exactly what I was gonna say....... Wink
Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE"
Ichy
PostPosted: 22:04 - 09 Feb 2006    Post subject: Reply with quote
Totally agree, which is why I said downpipes and not exhaust systems. I guess its why so many custom bikes have the same number of pipes as cylinders, saves a lot of hassle
PostPosted: 23:47 - 09 Feb 2006    Post subject: Reply with quote
Without connecting the down pipes you can probably wave goodbye to a load of power anyway as the pressure pulses from each cylinder cannot be utilised on each other.
SoND
PostPosted: 22:27 - 11 Feb 2006    Post subject: Reply with quote
When I made my exhaust the downpipe was a complete pain to make. Didnt have access to a pipe bender so I cut loads of slots into a pipe, bent it, welded it up and ground it down again. Took ages to do. This is only a small bit of what i cut.
https://www.bikechatforums.com/files/bend1.jpg
If you have 4 pipes to make it's going to take a long time and it's going to be difficult to get them bent properly. If they're sitting just a little bit off then the whole thing could look crooked.
It's going to be pretty difficult if you don't know what you're doing.
Ichy
PostPosted: 23:04 - 11 Feb 2006    Post subject: Reply with quote
When you have no rear suspension a lack of maximum power is a bonus Laughing Took a year to build and about a week to decide to sell it Laughing
The last post was made 20 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 70.09 Kb
