| numark1 |
 numark1 Scared of girls
 Posted: 19:03 - 09 Feb 2006 Post subject: Making Downpipes |
Having a real real real hard time finding downpipes for a fzr400, sourced some exup 600 pipes but not sure if they will fit and charging over £200.
How easy would it be to make some? I was having a think and i don't think it would be too bad. 4 Bits of pipe, calcuate how it needs to be bent, get a garage or whatever to bend it, weld brackets on to secure it onto the engine then maybe extend the pipes so i can have an underseater.
Yay or nay? |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Kickstart |
 Kickstart The Oracle
| Ichy |
 Ichy World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
| Brava210 |
 Brava210 Crazy Courier
 Posted: 21:49 - 09 Feb 2006 Post subject: |
| mchaggis wrote: | | marki wrote: | On a 4 stroke most downpipes will work as long as the gases can flow freely. |
Thats's fine until you get to collector boxes for multi-cylinder engines. Then you have perform some calculations with the lengths of the manifolds and the firing intervals to work out what the pressure pulses are doing in the exhaust. If you get the lengths of pipe wrong, you might end up with a high pressure pulse emerging from two different pipes into the same collector at once, which is bad news as it then restricts both pipes.
As with the rest of the exhaust and silencer system, you need to tune all the pipes with their length and diameter so as to avoid having high pressure pulses of gas coinciding. That is only really possible to tune around with a fixed system at one engine speed, which is why variable exhaust systems are used (e.g. EXUP). |
Exactly what I was gonna say.......  ____________________ Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE" |
| Ichy |
| Kickstart |
| SoND |
 SoND World Chat Champion
 Posted: 22:27 - 11 Feb 2006 Post subject: |
When I made my exhaust the downpipe was a complete pain to make. Didnt have access to a pipe bender so I cut loads of slots into a pipe, bent it, welded it up and ground it down again. Took ages to do. This is only a small bit of what i cut.
https://www.bikechatforums.com/files/bend1.jpg
If you have 4 pipes to make it's going to take a long time and it's going to be difficult to get them bent properly. If they're sitting just a little bit off then the whole thing could look crooked.
It's going to be pretty difficult if you don't know what you're doing. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| Ichy |
The last post was made 20 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
