Valve Clearance Costs.
RS125_Tecky
PostPosted: 19:59 - 10 Feb 2006    Post subject: Valve Clearance Costs. Reply with quote
following on from my previous thread...
Someone said at 24,000 miles they are due a major service.
The bike is on 20,000 miles and he doesn't have proof that the valve clerance was checked at 16,000 miles although he assures me it was done.
So basically I'm thinking of getting it to a dealer ASAP for a valve clearance service.
How much would this cost for;
a) they sure measure it but all is ok?
b) they measure it and need to adjust?
Help appreciated, cheers Thumbs Up
2004 ZX6R B1H
Simple
PostPosted: 21:00 - 10 Feb 2006    Post subject: Reply with quote
I had quotes for my GPZ adjustment of valves ranging from £360 to £70
I took up the £70 one as I know the mechanic is very good,
he even collected my bike for free too!
If you're local to midlands, pm me ill pass on his details
simple
Insta - FemFeral
Klause
PostPosted: 21:16 - 10 Feb 2006    Post subject: Reply with quote
What bike do you have?
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
PostPosted: 21:31 - 10 Feb 2006    Post subject: Reply with quote
Very much depends on the bike. Shimmed valves can be a pig to adjust (on many bikes the cams need to come out) but rarely need touching. You measure the clearance, take the existing shim out, calculate the size of the shim you need, buy it and replace it (probably about £3~£5 per shim, although some places will part ex them).
Other bikes have screw and locknut type adjustment (such as Simples GPZ500). These are far quicker to adjust but need doing far more often.
Given that the interval is 16k~24k this suggests that they are shimmed valves. Expect a bill of a good few hundred pounds.
Simple
PostPosted: 21:47 - 10 Feb 2006    Post subject: Reply with quote
R reg GPZ500s, which is shimmed not lock nut kickstart, according to my haynes anyway, Varadero125 is the screw and lock nut, I could do that my self , but didnt fancy moving shims around.
Insta - FemFeral
PostPosted: 21:49 - 10 Feb 2006    Post subject: Reply with quote
Didn't know they changed that. The older GPZ500s are screw and locknut and were up to 1996 at least).
Simple
PostPosted: 21:51 - 10 Feb 2006    Post subject: Reply with quote
I'm not aware they did change? mine is deffo Shims, I beleieve the older GPZ500 engines are the same ad the newer facelift ones?
a quick look on google suggest they are both the same
simple
Insta - FemFeral
Zimbo
PostPosted: 21:56 - 10 Feb 2006    Post subject: Reply with quote
I would expect an independant bike shop to charge in the region of £80 to check the clearances and replace any shims that are necessary.
You could always check them yourself, just for peace of mind? Costs - nothing, perhaps just buy a set of feeler gauges and a haynes manual.
PostPosted: 21:59 - 10 Feb 2006    Post subject: Reply with quote
Checked on the Kawasaki US web site and that has the parts diagrams for the GPZ500 (Ninja 500 they call it or Ninja 500R) and up to the latest model shown there they are screw and locknut.
Simple
PostPosted: 22:02 - 10 Feb 2006    Post subject: Reply with quote
how odd :S
perhaps I own the only shimmed GPZ500s in the country...
gotta be worth more come time to sell it then Laughing
Insta - FemFeral
RS125_Tecky
PostPosted: 22:46 - 10 Feb 2006    Post subject: Reply with quote
Cheers for the replies
The bike is a 01 zx6r.
2004 ZX6R B1H
RS125_Tecky
PostPosted: 22:48 - 10 Feb 2006    Post subject: Reply with quote
i'm going to view the bike tomorrow, is there any way I can check whilst im there?
2004 ZX6R B1H
Simple
PostPosted: 23:28 - 10 Feb 2006    Post subject: Reply with quote
If the valve clearences were 6000 miles overdue you'd hear it..
be a rattle..like tapping a spoon on a railing.
Insta - FemFeral
RS125_Tecky
PostPosted: 23:52 - 10 Feb 2006    Post subject: Reply with quote
Cheers for that mate, very helpful, will listen out for that when he starts it.
Anyone else know of any sounds I should listen out for as a sign the engine aint right?
Im going to view it early tomorrow so prompt replies would be great Thumbs Up
2004 ZX6R B1H
PostPosted: 23:57 - 10 Feb 2006    Post subject: Reply with quote
Not that likely. With shimmed valves the clearances tend to tighten up which if anything results in them getting quieter. Also although they may be 6k beyond the service interval shims often do not need adjusting.
Easiest way to get some idea of the state of the clearances is to do a compression check. Hardly something the seller would expect you to do.
RS125_Tecky
PostPosted: 23:58 - 10 Feb 2006    Post subject: Reply with quote
How do I do a compression check and what tools do I need and what should it roughly be?
2004 ZX6R B1H
Doddmaster
I just paid £480
But that did include genuine honda chain + sprockets, cush drive rubbers, full service, braided hoses and a new clutch Rolling Eyes
Simple
PostPosted: 00:10 - 11 Feb 2006    Post subject: Reply with quote
Kickstart how do you know about the valves on your gpz? where are you getting that they aren't shimmed from? my haynes say its shimmed, ive jsut paid to have it re shimmed and every link on google says shimmed....
my valves were out, and it deffinelty increased the rattling.
Insta - FemFeral
PostPosted: 00:12 - 11 Feb 2006    Post subject: Reply with quote
Not really realistic to do there. You will need a compression gauge with the right fittings for the ZX6Rs spark plugs. Then you will need to get the bike far enough apart (so probably at least fuel tank and airbox off.
PostPosted: 00:16 - 11 Feb 2006    Post subject: Reply with quote
Kawasaki parts list, Kawasaki workshop manual, 2 GPZ500 we have owned and Craigs GPZ500 which I have adjusted the valves on. All were screw and lock nut.
Simple
PostPosted: 00:18 - 11 Feb 2006    Post subject: Reply with quote
Exclamation Neutral Shocked Confused
Insta - FemFeral
ancientd
PostPosted: 00:38 - 11 Feb 2006    Post subject: Reply with quote
Got to second that, my Thundercats done 65K miles and the shims have not been changed since new, they were checked about 1,000 miles ago and all were well within tolerance. I would think it most unlikely that a ZX6R with 20k miles will need re shiming, but it's always worth checking.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
RS125_Tecky
PostPosted: 12:47 - 11 Feb 2006    Post subject: Reply with quote
Can anyone else add any more useful info on what to listen out for engine wise?
2004 ZX6R B1H
Zimbo
PostPosted: 14:30 - 11 Feb 2006    Post subject: Reply with quote
Basically, a bit of rattle from the top end may not be too much to worry about, as long as it isn't excessive, but if you hear a regular deep knocking, walk away. Pull the clutch in and see if you get a change in the noise, if you do it's mechanical noise from the clutch / transmission, if not it's likely from the engine. Make sure there's no white smoke from the exhaust when you blip the throttle.
RS125_Tecky
PostPosted: 14:43 - 11 Feb 2006    Post subject: Reply with quote
Cheers will listen and watch out for those.
Hopefully there wont be though as it's 3 1/2 hours drive away and thats just there Sick
2004 ZX6R B1H
The last post was made 20 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 136.05 Kb
