help needed for yamaha TZR 125
cully1980
PostPosted: 22:48 - 10 Feb 2006    Post subject: help needed for yamaha TZR 125 Reply with quote
hello all new to this, i have just bought a Yamaha TZR 125 the bike has not been running for a year or so and when i drove it home and stopped i noticed a puddle of petrol underneath the bike
is this something to do with the Carburettor becos it has been sat for a while? if so whats best to do
Ie can a complete novice have a go at cleaning it or does it require an expert
Hoffy
PostPosted: 23:25 - 10 Feb 2006    Post subject: Reply with quote
Sounds like it may be be a perished / split petrol pipe to me.
If its not , get a haynes manual and dive in there !!
Take Care
Alec
Plagued by 1980s Suzuki 2 strokes !
cully1980
PostPosted: 23:35 - 10 Feb 2006    Post subject: Reply with quote
just had a look and it was coming from a black tube from the carb
is that an overflow pipe or summot
looked on internet and says it could be the floats are stuck in carb
that sound right to anyone
Hoffy
PostPosted: 23:43 - 10 Feb 2006    Post subject: Reply with quote
Yeah sounds about right. Get a can of carbrettour cleaner , and then take off the float chamber (bowl at bottom of carb , usually held on by a few screws at the bottom) and liberally spray with carb cleaner.
If that doesnt work , You may need to strip the carb down.
Take care
Alec
Vin
PostPosted: 23:56 - 10 Feb 2006    Post subject: Reply with quote
Sometimes tapping the float bowl from the outside with the handle of a screw driver can free the float......but gently does it, don't go mad!
Cog Head
PostPosted: 23:57 - 10 Feb 2006    Post subject: Reply with quote
apply a few sharp taps to the side of the carb, mine did this, so i decided to see what happened if i wack it , and guess what... Thumbs Up Mr. Green
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
cully1980
PostPosted: 16:28 - 11 Feb 2006    Post subject: Reply with quote
thanks for the help
even though the day i wantto try and fix it it starts raining Sad did get it going once though but kep on spluttering and wouldnt go over 3k revs
is that cos of the carb, therfore not letting any fuel to into it
i tried hitting it a few times with a spanner?
as i am pants on bikes(first bike and all that but i am wiling to learn any advice anyone
TL666
PostPosted: 19:05 - 11 Feb 2006    Post subject: Reply with quote
If its pissing petrol don't run it. Be careful mate. You don't want it blowing up on you Wink
lllN30lll
PostPosted: 19:13 - 11 Feb 2006    Post subject: Reply with quote
i remember my petrol tank leaking on my AR125, i didnt notice until i'd just been for a long ride, stopped at traffic light and i could hear a hissing noise.
looked down and my tank was leaking petrol directly onto my expansion chamber.
my god it was a brown pants moment Embarassed
Turbo R1
CRF450R
Gazdaman
I did a trackday!!!
PostPosted: 01:11 - 12 Feb 2006    Post subject: Reply with quote
I think you'll find it will have been sat with very little or no petrol in it. So the floats will sit at the bottom of the float bowl, and get stuck there. Therefore when it fills with petrol, the floats won't raise, and won't restrict the flow of petrol.
Therefore it'll piss petrol.
Clean your carbs, although giving the float bowls a tap might do the trick in the short term.
Gaz
The last post was made 20 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.31 - MySQL Queries: 13 - Page Size: 63.12 Kb
