How sharp are your clutching fingers?
Rookie
PostPosted: 02:54 - 15 Feb 2006    Post subject: How sharp are your clutching fingers? Reply with quote
Just got back from the pub, so Shhh!...
How sharply do you come off the clutch when you're riding? Obviously when going from neutral to first you need to let it out fairly slowly, but when changing up particularly, how sharp is your action?
During my lesson, the instructor said I was really slamming the clutch out when changing up; and when I thought about it I was. I think it was a side effect of being on a ratty 4 poke 125; I was riding fairly aggressively, in order to get up a decent speed quickly. My instructor told me it wasn't neccessary and I should be lighter with it.
My question is; do you do anything similar, and does it have a detrimental effect on the bike itself or the riding itself?
Ichy
PostPosted: 09:43 - 15 Feb 2006    Post subject: Reply with quote
The clutch provides a means of controlling the power between the engine and rear wheel so worse case would the rear wheel slipping, but I guess you would have to rev the engine pretty high between changes to do that, bit like popping a wheelie.
fuzz
PostPosted: 10:12 - 15 Feb 2006    Post subject: Reply with quote
Changing up it would have little effect on the rear wheel, as the the engine slows. Dumping the clutch when changing down could cause the rear to skip.
Use of the clutch when changing up really only changes how smooth the gear change is. When riding solo, I usually change up in about half a second. With pillion, I release the clutch slower and the transition is a bit smoother. Sometimes you can get a jerk if you put the power on quickly, the clutch removes it.
So to answer your question, yes I do, but only when solo.
dainesefreak
PostPosted: 10:32 - 15 Feb 2006    Post subject: Reply with quote
Similar thing for me, I let the clutch out slowly and gradually if I'm carrying a pillion, stops the head butting action, and if I'm taking it easy. The bike does tend to change gear more smoothly with quick changes and clutch action though which is generally when I'm giving it some.
FreshAL
Sir Crashalot
PostPosted: 11:23 - 15 Feb 2006    Post subject: Reply with quote
Changing up I tend not to use the clutch at all.
Changing down, I try to let the clutch out gently, especially with the slippery roads at the moment
Type_Mo
PostPosted: 12:23 - 15 Feb 2006    Post subject: Reply with quote
I tend not to use the clutch when shifting up
PostPosted: 14:16 - 15 Feb 2006    Post subject: Reply with quote
I find a bit of rear brake for control and a fairly closed throttle gets a nice little slide Smile.
For your test, however, smoothness is definitely the key Thumbs Up.
Andy C
Tree Seeking Missile
PostPosted: 15:17 - 15 Feb 2006    Post subject: Reply with quote
yea, when i got the SV i kept looking the wheel and couldnt work out why, i then realised a was dumping the clutch for the last bit and made it lock.
With practise you can be smoth and fast at it without dumping it Thumbs Up, and then learn clutchless upshifts
fuzz
PostPosted: 15:20 - 15 Feb 2006    Post subject: Reply with quote
It just involves rolling the throttle on before you fully engage the clutch - should make it smooth and quick.
Method
PostPosted: 15:25 - 15 Feb 2006    Post subject: Reply with quote
I duno about my clutch hand...
But the g/f says my braking fingers are pretty quick? Wink
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
fuzz
PostPosted: 15:30 - 15 Feb 2006    Post subject: Reply with quote
Right handed then mate
Method
PostPosted: 15:38 - 15 Feb 2006    Post subject: Reply with quote
Lefty for writing, everything else is the job of good ol' righty Laughing
On a side note i always end up dumping the clutch on downshifts. So my clutching is reeeealy quite quick, both up and downshifting, it just has a nasty affect when downshifting Smile
PostPosted: 16:37 - 15 Feb 2006    Post subject: Reply with quote
Nowhere near as fast as I am on the clutch when the engine makes a funny noise. Comes of having owned an RD series Yamaha. Probably saved me from a crash when the conrod snapped in half on my MZ supermoto while I was doing 85mph round a corner.
I hardly pull the clutch in at all when I am changing gear. No more than halfway under normal conditions, just enough to slip the plates a bit. I only pull it right the way in when I stop.
Jrod
Page 3 Girl
PostPosted: 00:36 - 16 Feb 2006    Post subject: Reply with quote
If I'm just cruising I don't even pull it in, shift up and down clutchless. Thumbs Up
tatters
Exxon Valdez
PostPosted: 00:41 - 16 Feb 2006    Post subject: Reply with quote
I always dump the clucth when changing gears, only slip it when pulling off in first.
DukeRed
PostPosted: 01:57 - 16 Feb 2006    Post subject: Reply with quote
Clutchless up and rear wheel skippingness down Thumbs Up .
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
SteWhit
PostPosted: 02:20 - 16 Feb 2006    Post subject: Reply with quote
Only when nailing it Thumbs Up
Are You Serious??
carlnicholson...
PostPosted: 03:11 - 16 Feb 2006    Post subject: Reply with quote
Clutchless upshifts, if done correctly, save a lot of 'undriven' time, and are therefore perfect if accelerating in a hurry. They need to be done properly though, or the gearbox can be seriously abused.
The trick is, when ready to change up, make sure that you are quite close to the maximum torque of the rev range, quickly turn the throttle back to a little short of closed, (so that no power is being transmitted through the gearbox) and the bike is neither accellerating, nor decellerating, and give the gear lever a good lift up, then quickly, but, progressively open the throttle to put the gear in place and then your away.
Clutchless downshifts can work, but are more difficult, are carry more risk of causing damage to the box. Changing clutchless is all about saving 'undriven' time, so there is nothing to be gained by not using the clutch going down the box.
I would also recommend using the clutch between 1st and 2nd, and then go clutchless after that. The box can easily fall out of second and back into neutral otherwise. I did this on a brand new ZX636R I bought, and will not do it again!
"THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING."
The last post was made 20 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 100.77 Kb
