How to wire Oxford Heated Grips?
 Topic moved: from General Bike Chat to The Workshop by Korn (19 Feb 2006 - 23:34)
Type_Mo
PostPosted: 22:05 - 19 Feb 2006    Post subject: How to wire Oxford Heated Grips? Reply with quote
theres a set on the bike and there a bitch to take off, so i aint gonna bother, But you can only wire in 1 at a time. So how would i go about having both on at the same time?
PostPosted: 22:17 - 19 Feb 2006    Post subject: Reply with quote
Do what? Only have one grip on at a time? Confused
Further explanation needed.
Type_Mo
PostPosted: 22:19 - 19 Feb 2006    Post subject: Reply with quote
You can only have one grip on at a time at the moment!
And i want to wire it so i can have both of them on at once.
PostPosted: 22:22 - 19 Feb 2006    Post subject: Reply with quote
Do you mean either one or the other comes on and you can select which or only one of them comes on? Either way, that sounds like there is a fault on the grips themselves or their control box.
True Blue
PostPosted: 22:25 - 19 Feb 2006    Post subject: Reply with quote
You can only wire in one at a time? Question Sounds as if there is some sort of splitter cable missing.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Superlight
PostPosted: 23:03 - 19 Feb 2006    Post subject: Reply with quote
I think the newer versions have got better wiring, but they used to have a load of bullet connectors, and included a little connector to plug all the bullets together.
I've got some spare wiring for Oxford grips, I've had a couple of sets and tended to make my own loom up for them. I'm not sure if it's complete, if you're interested let me know, I'll dig out what I've got.
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
Type_Mo
PostPosted: 23:18 - 19 Feb 2006    Post subject: Reply with quote
ok, just checked were the wire goes to, Someones connected it directly to the Battery and they have taken out the temp adjustor aswell. So can i get a connection to join the one from the battery to both the wires on the grips?
PostPosted: 23:54 - 19 Feb 2006    Post subject: Reply with quote
Easily, but not the most elegant of solutions. Either crimp both wires into the same connector or fit a 'double' bullet terminal on the end of your single wire.
Sorry to sound like a broken record but a five-terminal, twin output, single throw relay would be the more elegant way of doing it. Then you can wire it to switch off with the ignition.
About Relays
If you do something similar to the "GPS" example I gave there using the twin output relay in the wire coming from the battery, the grips will power-down when you switch off the ignition.
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 57.82 Kb
