| Type_Mo |
 Type_Mo World Chat Champion
| Type_Mo |
 Posted: 22:22 - 19 Feb 2006 Post subject: |
Do you mean either one or the other comes on and you can select which or only one of them comes on? Either way, that sounds like there is a fault on the grips themselves or their control box. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| True Blue |
 True Blue World Chat Champion
 Posted: 22:25 - 19 Feb 2006 Post subject: |
You can only wire in one at a time? Sounds as if there is some sort of splitter cable missing. ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
| Superlight |
 Superlight Nitrous Nuisance
| Type_Mo |
 Posted: 23:54 - 19 Feb 2006 Post subject: |
Easily, but not the most elegant of solutions. Either crimp both wires into the same connector or fit a 'double' bullet terminal on the end of your single wire.
Sorry to sound like a broken record but a five-terminal, twin output, single throw relay would be the more elegant way of doing it. Then you can wire it to switch off with the ignition.
About Relays
If you do something similar to the "GPS" example I gave there using the twin output relay in the wire coming from the battery, the grips will power-down when you switch off the ignition. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful? |
