| hazza |
 hazza World Chat Champion
| bish777 |
 bish777 World Chat Champion
| hazza |
 Posted: 16:55 - 21 Feb 2006 Post subject: |
So you start it by putting the choke on and kicking it over. It starts and you need to leave the choke on for a while before you can touch the throttle?
Doesn't sound like anything out of the ordinary to me.
Remember you don't need to kick it over very hard. More pressing down on the lever a few times rather than booting it over. That sort of bike usually starts third kick.
You switching the fuel off when you park it up? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hazza |
| Richard1987 |
 Richard1987 Scooby Slapper
 Posted: 19:52 - 21 Feb 2006 Post subject: |
you would need to rejet if you go with a k&n filter, but i dont think you will gain much unless you do other mods like exhaust?
Id leave it standard  ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
| Richard1987 |
 Posted: 19:57 - 21 Feb 2006 Post subject: |
yea it will sound different, different design in chambers and baffles etc. how much did you pay for the bike? ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
| Richard1987 |
 Posted: 20:04 - 21 Feb 2006 Post subject: |
cool, my H100 still isnt back on the road since the crank bearings went on me like 6 weeks ago mabye more  ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
| Richard1987 |
 Posted: 20:10 - 21 Feb 2006 Post subject: |
i could always hear a slight churning noise when mine was, when mine went, my engine just siezed, they stoped the engine from turning over ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
| Richard1987 |
 Posted: 20:17 - 21 Feb 2006 Post subject: |
it locked my wheel up for a small moment before i pulled the clutch in, but i was only going like 5mph. i had just come back from a 7 mile trip? i think that just killed them off ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
| Richard1987 |
 Posted: 20:21 - 21 Feb 2006 Post subject: |
i just assumed it was its normal running noise. i had it for 5 months and put about 3k on the clock
Ive not heard it run yet after doing all the work
so it might still sound the same ... oh how i miss that sound  ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
| Richard1987 |
 Posted: 20:33 - 21 Feb 2006 Post subject: |
i had someone do the bearings, you have to heat the crankcase up with oxy - ascetalyne which i dont have,
The h100 looks very similar. ive never owned a RXS100 but just look at the pics  ____________________ add me to your msn messenger contacts : [email protected] |
 Posted: 20:37 - 21 Feb 2006 Post subject: |
There is a fair bit of difference between an H100 and an RXS100. The RXS has disc-valve, crankcase induction. The H100 has piston porting and reed valves.
I wouldn't go fannying about with K&N filters until you are sure the bike is running perfectly in standard trim. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Richard1987 |
 Posted: 20:40 - 21 Feb 2006 Post subject: |
oh yea, i think ive seen them before with a K&N cone filter poking out from the crankcase? ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
| Richard1987 |
 Posted: 20:44 - 21 Feb 2006 Post subject: |
the metal expands under the heat, not holding the bearings in as tight ____________________ add me to your msn messenger contacts : [email protected] |
 Posted: 21:01 - 21 Feb 2006 Post subject: |
You can fit main bearings by putting the crankcase in the oven till it is 'Jesus hot' (touch it and you will know how hot this is) and the bearings in the freezer. You then quickly seat them and tap them in square using a big socket and extension bar on the outer race.
From previous experience, it is best to do this when your mum is out all day because you will get your head to play with if she finds you with half an engine in her oven.
Or you take the crankcase halves and your new bearings along to a half-decent local garage and say "Excuse me mister, could you put these bearings in with your press please?" Then (most important) when he says there is no-charge, give him some beers, I would consider pressing main bearings into already prepped crankcase halves a 'four bottles of stella' job. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Richard1987 |
 Posted: 21:08 - 21 Feb 2006 Post subject: |
bet burning gearbox oil stinks smells bad enough when its fresh  ____________________ add me to your msn messenger contacts : [email protected] |
| hazza |
The last post was made 20 years, 239 days ago. Instead of replying here, would creating a new thread be more useful? |
