Can it be repaired
The#Doctor#
PostPosted: 21:41 - 21 Feb 2006    Post subject: Can it be repaired Reply with quote
After crashing my cbr600fy there is only one part left to find or repair before i can get back on the road, the radiator has a small crack in the top left of it(causing it to leak), can this be repaired if so how? and by who ? how much ?
Thanks
CBR125R - CBR600Fy Smile
'140 mph officer thats impossible the bike is 33 bhp restricted'
PostPosted: 22:11 - 21 Feb 2006    Post subject: Reply with quote
It is possible it could be repaired using solder of some sort, but modern radiators are very thin.
I would have a go with something like lumiweld, prepare the surface well and use plenty. Ideally you would pressure test it after your repair to make sure it is going to 'hold water'. This will most likely either fail immediately or fix permanantly.
Cog Head
PostPosted: 22:55 - 21 Feb 2006    Post subject: Reply with quote
wack an egg in the coolant, that has actually been proved and works fine, on cars that is, but in theory it should work fine in a bike as its pretty much the same type of system Thumbs Up Mr. Green
Bodge of the century
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
craigs23
Mr Muscle
PostPosted: 08:38 - 22 Feb 2006    Post subject: Reply with quote
How about Ebay or breakers yard? Couldn't be more than a couple of quid.
PostPosted: 08:43 - 22 Feb 2006    Post subject: Reply with quote
And if it doesn't, you get a tasty poached egg, anyway Wink.
The#Doctor#
PostPosted: 10:51 - 22 Feb 2006    Post subject: Reply with quote
e bay has one but it is a bit banged up although they say it doesn't leak, dont know of any breakers yards anyone point me in the right direction ??
Thanks
PostPosted: 15:11 - 22 Feb 2006    Post subject: Reply with quote
Thanks
Buy a copy of motorcycle news. Look in the classified adverts section, there are loads of breakers in there (and possibly even a radiator repair shop), phone round a few.
www.125power.com
PostPosted: 15:15 - 22 Feb 2006    Post subject: Reply with quote
You are joking right? Or are you? I cant see how an egg will save a radiator sounds a really silly idea.......
My eBay Items
PostPosted: 15:40 - 22 Feb 2006    Post subject: Reply with quote
It does work, seen it with my own two eyes. I always thought of it as more of a 'get you home' bodge than a permanant fix though.
Jack_Cheese
PostPosted: 15:43 - 22 Feb 2006    Post subject: Reply with quote
Mythbusters proved the egg in the radiator works perfectly fine Thumbs Up
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
MikeyC
PostPosted: 15:45 - 22 Feb 2006    Post subject: Reply with quote
When did you crash? Confused
zx636
PostPosted: 15:47 - 22 Feb 2006    Post subject: rad repair. Reply with quote
I had a leak in the rad on the car. I got some metal repair from Halfords, Its a two part, heat resistant epoxy putty, mix it together, push over crack/hole, leave it for 30 minutes, start up and as the rad warms its cures the epoxy.
This has been on the car for over 2 years and never leaked. worth a try and at under a fiver well worth it.
Cog Head
PostPosted: 16:03 - 22 Feb 2006    Post subject: Reply with quote
exactly, if it doesnt get you home, then at least you will have a poached egg to eat whilst you waite for the recovery van to arrive
fuzz
PostPosted: 16:05 - 22 Feb 2006    Post subject: Reply with quote
But dont forget to take the egg out when you do come to do the proper job, it would be such a waste Mr. Green
mr.z
PostPosted: 16:09 - 22 Feb 2006    Post subject: Reply with quote
The egg trick also perminently lowers the efficiency of the radiator too, especially (i'd imageine) on modern radiators..
If you canget at the leak easy rnought en i reckon solderings your best bet, you can get a rad rebuilt for £60 or so (depending) look on www.yell.co.uk and search "motorcycle radiator repair" in your area.. had one done and it took 1day, they picked it up and dropped it off within 20 hours Thumbs Up
The last post was made 19 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 4.38 - MySQL Queries: 13 - Page Size: 88.56 Kb
