nsr125rm 1991 full power italian import earths
gazza876
PostPosted: 18:06 - 26 Feb 2006    Post subject: nsr125rm 1991 full power italian import earths Reply with quote
hi can someone please help me i need to know where the earth points are on this model of bike cheers
hello
magpiemale
PostPosted: 18:53 - 26 Feb 2006    Post subject: Reply with quote
pass! I have one rm import but havent took much notice of where they are.why do you ask,take a torch and hunt around the engine and subframe there is only a few earth's.
magpiemale
2Smoke
PostPosted: 19:59 - 26 Feb 2006    Post subject: Reply with quote
Follow the battery negative lead it should go directly to earth. There is usually a smaller earth by the coil, although I may be wrong!
gazza876
PostPosted: 20:14 - 26 Feb 2006    Post subject: nsr Reply with quote
thanks guys my electrics are giving me hell bike wont spark indicator not working and not enough power getting to one of the headlights
hello
alains
PostPosted: 20:32 - 26 Feb 2006    Post subject: Reply with quote
the main earth is on the starter
gazza876
PostPosted: 20:42 - 26 Feb 2006    Post subject: nsr Reply with quote
thanks alains that is the only one i can find and it seems to be nice and secure
hello
robbie21mcn
PostPosted: 09:34 - 27 Feb 2006    Post subject: Reply with quote
batttery terminals on securely??? particularly the earth lead this has gave me probs in the past. Thumbs Up
fzr 600 its yellow but its no banana!!!!!!
gazza876
PostPosted: 12:21 - 27 Feb 2006    Post subject: nsr Reply with quote
well thanks for the replys people but it seems batterys connected secure and earth is secure so perhaps its something else any ideas anyone cheers
hello
alains
PostPosted: 12:56 - 27 Feb 2006    Post subject: Reply with quote
if you've got an electric problem , tell and how Very Happy
gazza876
PostPosted: 13:24 - 27 Feb 2006    Post subject: nsr Reply with quote
the problem is the bike has twin headlights and when they are both on main beam one works as normal but the other one comes on but its very dim and the rear left indicator doesnt work and the bike doesnt allways spark please help thanks
hello
alains
PostPosted: 19:14 - 27 Feb 2006    Post subject: Reply with quote
which bulbs are on ? power ? it seems that has nothing to do with the system , probably a loose contact on the bulb . are the crossing lights working together ? also put your battery on charge and look if the problems are still on
afterwards we can think about (alternator,regulator etc..)
gazza876
PostPosted: 12:21 - 28 Feb 2006    Post subject: nsr Reply with quote
ive charged my battery i will go check it out in a mo
hello
gazza876
PostPosted: 13:37 - 02 Mar 2006    Post subject: nsr Reply with quote
hi guys i put the newly charged battery on still the same checked the indicator tapped it a few times now it works the headlight is just the same and the bike still wont start im not worried about the light not working the main thing is getting the bike running thanks
hello
alains
PostPosted: 14:08 - 02 Mar 2006    Post subject: Reply with quote
it still could be a worn battery . https://www.geneva-racing.com/~alains/NSRtips.doc and look how to check your battery
for the other things it's probably bad contacts on the bulbs (oxyde) but tell me , when you press start , do you hear your starter running fast or just a "clac" ?
this starter is special because if you've not enough voltage in your battery the gear will not engage the flywheel . i suggest that you use leads from a car battery to see if your starter works . if it not works look my file to make a DIY repair
gazza876
PostPosted: 14:16 - 02 Mar 2006    Post subject: nsr Reply with quote
ive tried it from a car battery the starter motor engages ok but it wont evan bump start also there is a constant buzzing noise when you turn on ignition key
hello
alains
PostPosted: 14:56 - 02 Mar 2006    Post subject: Reply with quote
which year is your bike and is it a uk specs ?
when you put key on ,can you define where this noise comes from?
could be the starter relay (follow the starter wiring it's in a kind of protection)
gazza876
PostPosted: 15:01 - 02 Mar 2006    Post subject: nsr Reply with quote
its an italian import and it is the starter relay any ideas thanks
hello
gazza876
PostPosted: 17:26 - 02 Mar 2006    Post subject: nsr Reply with quote
right the bike is not making any buzzing noises now the bike is sparking ive cleaned the carb checked the oil and the fuel the spark plug seems to be wet with red oil but the bike did fire when i bumped it for a split second anyway so what do i do next hope you can help cheers
hello
alains
PostPosted: 17:43 - 02 Mar 2006    Post subject: Reply with quote
when you press start do you hear your engine turning ?
if not , do hear the starter turning fast without engaging the flywheel ?
if not , do you hear just a slight electrical knock
gazza876
PostPosted: 18:02 - 02 Mar 2006    Post subject: nsr Reply with quote
yes the engine is turning?
hello
alains
PostPosted: 18:25 - 02 Mar 2006    Post subject: Reply with quote
this is very strange ,no electric start and it bump start Embarassed
try a BR9EIX
gazza876
PostPosted: 18:31 - 02 Mar 2006    Post subject: nsr Reply with quote
ok thanks i will see if i can get one tomorrow
hello
The last post was made 20 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 109.59 Kb
