rusted pads and discs
kwacky
PostPosted: 20:09 - 27 Feb 2006    Post subject: rusted pads and discs Reply with quote
've got solid discs and EBC HH pads.
I hadn't used the bike for a few days and when I went to use it this morning the pads had rusted solid onto the discs. Normally I just stick the bike into first and let the clutch out gently and that does the trick. I tried that this morning and the back end span up and the front stayed in place
I kicked the discs (I'm dead technical) to try and loosen them but that didn't do it.
So, without wanting to cover the pads and discs in WD40, how do I free them? Is it a case of getting a metal wallpaper stripper and a hammer and just chiselling the pads off the discs?
fuzz
PostPosted: 20:59 - 27 Feb 2006    Post subject: Reply with quote
I wouldn't recommend attacking anything near the discs with a hammer. The only suggestion I have is to drain the brake fluid completely, and then separate the pads by riding gently forward (clutch and back brake.) Without the fluid there might be less resistance to the pistons and they may break free. I wouldn't risk damaging the discs TBH.
Guest
PostPosted: 21:10 - 27 Feb 2006    Post subject: Reply with quote
I wouldn't fanny about draining the fluid, just pry the pads back gently. A decorator's scraper (without the hammer Wink ) sounds ideal - nice and thin.
kwacky
PostPosted: 21:59 - 27 Feb 2006    Post subject: Reply with quote
thanks for your help
I went for a very fine long knife and tapped it under the outer pads on each disc
If I die tomorrw I know it went wrong Smile
riichy
PostPosted: 22:48 - 27 Feb 2006    Post subject: Reply with quote
try just rocking the bike back and forth....might free them up... Confused
.......... PLOD ............ zx636 2004
kwacky
PostPosted: 22:56 - 27 Feb 2006    Post subject: Reply with quote
Riichy, they were welded solid mate. Thanks for teh offer
riichy
PostPosted: 23:20 - 27 Feb 2006    Post subject: Reply with quote
sorry, it just mine in a morning are stuck to the pads so i just push it as hard as i can frees them up... but you might have to take some tools to it Shocked Thumbs Up Karma
Ichy
PostPosted: 23:48 - 27 Feb 2006    Post subject: Reply with quote
A wooden or plastic wedge would be better next time. Laughing If your not going to use the bike for a few days it might be worth slipping some thin plastic between the pads and disc.
ZZR-Souls
PostPosted: 00:35 - 28 Feb 2006    Post subject: Reply with quote
Have you got sintered pads in. They are a definite NNOOOO in winter. The high metal content of sintered pads reacts with the salt from the crap they put on our roads and bimetallic corrosion races away and your discs get a nasty case of the rust worm.
Best to get yourself a set of standard pads for the winter.
JOIN IN THE BIGGEST RIDE-OUT OF 2007 here
kwacky
PostPosted: 08:50 - 28 Feb 2006    Post subject: Reply with quote
Cheers for the heads up ZZR
It the combination of the racing discs and the sintered pads. I'll know for next year
slimjim04
PostPosted: 19:06 - 28 Feb 2006    Post subject: Reply with quote
Laughing just remember to remove the plastic thou before you drive off the following morning Embarassed
Im a Safh Eash Winnah and a Winnah i will be.
LukeVFR and his pussies can bash my Karma. But i bet you cant turn uto a meet and say it 2 me in person. LOL
BCF is now Pants full of little boys
sickpup
Old Timer
PostPosted: 12:07 - 01 Mar 2006    Post subject: Reply with quote
Don't mess around just hit the caliper with a rubber mallet a couple of times.
NSR Mick
PostPosted: 12:22 - 01 Mar 2006    Post subject: Reply with quote
It may ease the problem if you dont use the front brake when parking up, that way the pads will be a little further from the disc.
The last post was made 20 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 77.93 Kb
