| kwacky |
 kwacky Nitrous Nuisance
| fuzz |
 fuzz World Chat Champion
 Posted: 20:59 - 27 Feb 2006 Post subject: |
I wouldn't recommend attacking anything near the discs with a hammer. The only suggestion I have is to drain the brake fluid completely, and then separate the pads by riding gently forward (clutch and back brake.) Without the fluid there might be less resistance to the pistons and they may break free. I wouldn't risk damaging the discs TBH. ____________________ https://www.bikepics.com/members/fuzzbcf/
| Guest |
 Guest Brolly Dolly
 Posted: 21:10 - 27 Feb 2006 Post subject: |
I wouldn't fanny about draining the fluid, just pry the pads back gently. A decorator's scraper (without the hammer ) sounds ideal - nice and thin. |
| kwacky |
 Posted: 21:59 - 27 Feb 2006 Post subject: |
thanks for your help
I went for a very fine long knife and tapped it under the outer pads on each disc
If I die tomorrw I know it went wrong  |
| riichy |
 riichy World Chat Champion
 Posted: 22:48 - 27 Feb 2006 Post subject: |
try just rocking the bike back and forth....might free them up...  ____________________ .......... PLOD ............ zx636 2004 |
| kwacky |
| riichy |
 Posted: 23:20 - 27 Feb 2006 Post subject: |
| Ichy |
 Ichy World Chat Champion
 Posted: 23:48 - 27 Feb 2006 Post subject: |
A wooden or plastic wedge would be better next time. If your not going to use the bike for a few days it might be worth slipping some thin plastic between the pads and disc. |
| ZZR-Souls |
 ZZR-Souls Renault 5 Driver
 Posted: 00:35 - 28 Feb 2006 Post subject: |
Have you got sintered pads in. They are a definite NNOOOO in winter. The high metal content of sintered pads reacts with the salt from the crap they put on our roads and bimetallic corrosion races away and your discs get a nasty case of the rust worm.
Best to get yourself a set of standard pads for the winter. ____________________ JOIN IN THE BIGGEST RIDE-OUT OF 2007 here |
| kwacky |
| slimjim04 |
 slimjim04 Nearly there...
| sickpup |
 sickpup Old Timer
| NSR Mick |
 NSR Mick World Chat Champion
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
