Some puzzles
Bike Chat Forums Index -> Found on the 'Net Goto page 1, 2  Next
fuzz
PostPosted: 23:10 - 27 Feb 2006    Post subject: Some puzzles Reply with quote
Arrow There are three boxes containing 2 balls each. In one there are two white balls, in another two black balls, and in the third one ball is black, the other is white. Boxes have been labeled to indicate their contents. However, whoever did the job got all labels wrong. The task is to straighten things out. You may select only 1 box and blindly pick up a ball out of it. How can you be sure to label them correctly?
Arrow
Though only five letters,
From my start to my end,
I can have the meaning,
Of "Gone out with a friend."
Add two letters of negation
If you follow this rhyme
And my meaning is now
"Not classified according to time."
Add two more letters in front,
Again that mean "Not"
Now my meaning is "flooded."
So the answer is what?
Arrow Can you give an English word with the same letter three times in a row? No hyphens are allowed, so bee-eater wouldn't do.
Arrow The sentence "The unclear creator is the course of chum peach greeny," can be anagrammed to "The nuclear reactor is the source of much cheap energy" anagramming each word of four or more letters of the original sentence.
Can you do the same with these 4 sentences (the anagrammed sentences must still be grammatically correct and make sense, as the example above)?
1. Do spoilt eden plaices silences to fly percussion panels?
2. Few enumerations veer adverb the eighths speak in the meteor anger.
3. Myna taste allegorists praise to be treasons in the optical.
4. The pertain dues his shrub to drapes stokers in clarets and magnate silo.
PostPosted: 23:21 - 27 Feb 2006    Post subject: Reply with quote
Given that the labells are all wrong, open the one labelled mixed, this can only contain either two white or two black balls.
If the ball you pick is white, the white balls are in that box, the mixed ones are in the black box and the black ones are in the white box.
If the ball is black, the black balls are in that box, the mixed ones are in the white box and the white ones are in the black box.
PostPosted: 23:25 - 27 Feb 2006    Post subject: Reply with quote
Date, undate, inundate.
Rookie
PostPosted: 23:27 - 27 Feb 2006    Post subject: Reply with quote
I got the first anagram:
Do pilots need special licenses to fly supersonic planes?
Dance!
Rookie
PostPosted: 23:30 - 27 Feb 2006    Post subject: Reply with quote
Partially got the 2nd one: Laughing
Few mountaineers ever braved the highest peaks in the meteor range.
edit: REMOTE range. Mr. Green
Rookie
PostPosted: 23:33 - 27 Feb 2006    Post subject: Reply with quote
4th: Mr. Green
The painter used his brush to spread strokes in scarlet and magenta oils.
fuzz
PostPosted: 23:54 - 27 Feb 2006    Post subject: Reply with quote
You guys are good Thumbs Up
I hadn't done the anagrams myself, but I've got the third, which is good for me as I'm crap at anagrams Mr. Green
fuzz
PostPosted: 23:55 - 27 Feb 2006    Post subject: Reply with quote
Dated, undated, inundated.
Mr. Green
PostPosted: 23:58 - 27 Feb 2006    Post subject: Reply with quote
fuzz wrote:
[b]Dated, undated, inundated.
Mr. Green
No need to get tense about it.
Rookie
PostPosted: 00:11 - 28 Feb 2006    Post subject: Reply with quote
I may not have understood it, but 'date' doesn't have 5 letters!
PostPosted: 00:15 - 28 Feb 2006    Post subject: Reply with quote
TENSE
daz|n00by
The Internet
PostPosted: 00:17 - 28 Feb 2006    Post subject: Reply with quote
The usual rules of English spelling outlaw triple letters. Hyphens are inserted into words such as bee-eater, bell-like, chaff-flower, cretaceo-oolitic, cross-section, egg-glass, joss-stick, off-flavour, hostess-ship, puff-fish, toll-lodge, and zoo-organic.
The complete Oxford English Dictionary does contain instances of frillless, bossship, countessship, duchessship, governessship, and princessship, and the county name Rossshire.
The only other word with a triple letter is the invented word Amerikkkan, which is intended to symbolize the racist aspect of American society by including the initials of the Ku Klux Klan.
Graphic representations of noises, such as brrr, shhh, and zzz, do not really count as proper words.
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
fuzz
PostPosted: 10:07 - 28 Feb 2006    Post subject: Reply with quote
A few more
Arrow If the difference of two numbers is 8 and their product is 16, what is the sum of their squares?
Arrow There is a pole in a lake. One-half of the pole is in the ground, another one-third of it is covered by water, and 12 ft is out of the water. What is the total length of the pole in ft?
Arrow A cylinder 108 cm high has a circumference of 24 cm. A string makes exactly 6 complete turns round the cylinder while its two ends touch the cylinder's top and bottom. How long is the string in cm?
Arrow If you were to construct a 7 x 7 checkered square (i.e., a 7 x 7 chess board), how many squares would there be in total?
Arrow What about a 7x8 chessboard?
Arrow When I add 4 times my age 4 years from now to 5 times my age 5 years from now, I get 10 times my current age. How old will I be 2 years from now?
the grim reaper
PostPosted: 12:35 - 28 Feb 2006    Post subject: Reply with quote
The answer to the first one is 32. -4 and +4 are the two numbers.
The pole is 36 ft long.
Can't be bothered with the rest.
Grim
John C
PostPosted: 13:05 - 28 Feb 2006    Post subject: Reply with quote
But the product of -4 and +4 is -4 x 4 which is -16 not 16?
1/2 of the pole is in the ground............1/2 = 3/6
1/3 of the pole is covered by water......1/3 = 2/6
12ft is out of the water.........................6/6 - (3/6 & 2/6) = 1/6
12ft = 1/6th so the full pole is = 6x12 = 72ft
John C
PostPosted: 13:26 - 28 Feb 2006    Post subject: Reply with quote
Question is the string 180cm long?
i.e.
√((24x6)^2) + (108^2) = 180
√(20736 + 11664) = 180
√32400 = 180
John C
PostPosted: 13:39 - 28 Feb 2006    Post subject: Reply with quote
Question 140 squares on a 7x7?
John C
PostPosted: 13:43 - 28 Feb 2006    Post subject: Reply with quote
Question 168 on a 7x8?
John C
PostPosted: 13:49 - 28 Feb 2006    Post subject: Reply with quote
Age=A
so...
10A = 4(A+4)+5(A+5)
10A = 4A+16+5A+25
10A = 9A + 41
A = 41
Age in two years = 43
fuzz
PostPosted: 16:26 - 28 Feb 2006    Post subject: Reply with quote
Grim
Wrong and wrong.
Hint for first - they are not integers Wink
fuzz
PostPosted: 16:27 - 28 Feb 2006    Post subject: Reply with quote
NSRSparkie - All correct, you clever get Wink
John C
PostPosted: 17:44 - 28 Feb 2006    Post subject: Reply with quote
fuzz wrote:
Wrong and wrong.
Now he tells me. Rolling Eyes Laughing
I better come at this from a different angle then...
Andy C
Tree Seeking Missile
PostPosted: 19:22 - 28 Feb 2006    Post subject: Reply with quote
I might be on the wrong lines here but:
4 + 12 = 16
12 - 4 = 8
4squared = 16
12 sqaured = 144
So sum of squares is 160
I cant remember if product means add or times so not sure if this is right
daz|n00by
The Internet
PostPosted: 19:25 - 28 Feb 2006    Post subject: Reply with quote
Answer please fuzz ? as you havnt replied to my post.
John C
PostPosted: 19:44 - 28 Feb 2006    Post subject: Reply with quote
It's a quadratic
x-y=8 and xy=16 so...
x (x-8) =16
x^2 - 8x -16 =0
when ax^2 + bx + c = 0, x = (-b±(√b^2 – 4ac))/2a. So...
x = [-(-8)±√(-8^2 – 4.1.(-16))]/2.1
x = 8±√(64 – (-64))]/2
x = (8±√128)/2
x = 9.656(3dp), or x = -1.656(3dp)
y = 1.656(3dp), or y = -9.656(3dp)
Using the above values of x & y...
x^2 + y^2 = 96
Question 96
The last post was made 19 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Found on the 'Net All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 133.25 Kb
