| Cog Head |
 Cog Head Could Be A Chat Bot
 Posted: 18:13 - 28 Feb 2006 Post subject: Is it bad ? |
i was riding back from bassets pole with a mate the other day, and coming down the a road towards mile oak, just after the last hill, i was giving it some down the hill, all was fine until i stuck my head up and sat with full throttle just cruising at whatever speed i was doing in 6th, and the back wheel locked up completely randomly and i lost all power and lighting, everything stopped working, i dragged the clutch in and went down 2 gears, and slowly let out the clutch bit it locked up again, so i pulled the clutch back in and went down another 2 gears and dumped the clutch, i then gained power, got myself to the side of the road, let my bike cool down as when the wheel locked up the first time, the overheat light come on, i then had a look around the chain and break area of the bike and nothing, so i got back on my bike and went to ride it down the street opposite the bus stop i was in, and all was normal.
what could this have been?
i have also noticed that when i go full tilt in 5th and change into 6th at about 55-60Mph the bike always seems to overheat.
any ideas, i think that the 2 problems are coming from the same sauce.
any help will be muchly appreciated  ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore
McGee: Hence I smell like a gimp |
| veeeffarr |
 veeeffarr Super Spammer
| Cog Head |
 Posted: 18:26 - 28 Feb 2006 Post subject: |
tis what i was thinking, but it seems to always overheat in 6th gear, how could i stop this from happening ?
would a change of gearbox oil do it ?
or could it be more sinister ? ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
| Cog Head |
 Posted: 00:19 - 01 Mar 2006 Post subject: |
Bumpage  ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
| Ichy |
 Ichy World Chat Champion
| Scorpius |
 Scorpius Scooby Slapper
| ZRX61 |
 ZRX61 Victor Meldrew
| Cog Head |
 Posted: 09:00 - 01 Mar 2006 Post subject: |
i have changed my exhaust yeah, i gave it to bike tec to re-jet, and they said it was ok, but al they did was look at my spark plug which i cleaned the day before and id riden the bike slowly to the garage, so it probs would look ok with the mixture.
they lying bastards, they said it was fine i recon they should do the work 4 free, whatever it needs doing.
cheers for the help everyone  ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 10:27 - 01 Mar 2006 Post subject: |
Sounds like it could be a heat seize.
Your always going to be flat out in top gear longer than you are in any of the other gears, so heat will build up more so than in other gears.
Could be down to a lean mixture (could try going up a jet size), or try a different plug (go up a grade).
Might also want to check your oil (2T) pump is adjusted correctly.
| woodyfjr |
 woodyfjr Scooby Slapper
| jonnay |
 jonnay World Chat Champion
 Posted: 18:41 - 01 Mar 2006 Post subject: |
You ALWAYS have to upjet after doing anything to a 50cc 2t. Airfilter, exhaust, whatever, they leave the factory designed to work with the standard parts, a new exhaust will make it run a hell of a lot differently to how it's intended to. You will have siezed it, and probably nipped the piston and barell.. you'll need a new top end, otherwise it will be low on compression, and will run like a bag of shit.
When it's fixed, don't ride it until it's upjetted, you'll need to start with a much bigger jet and work down, until your sparkplug is a chocolate brown colour.
tbh, everyone I know with a geared 50 with a minarelli engine (reiju, aprilia, motohispania) who's put a new exhaust on has had these problems. They just make the bike sound louder and cause it to blow up  ____________________ ::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi:: |
| Cog Head |
 Posted: 23:01 - 01 Mar 2006 Post subject: |
| Rob W |
 Rob W World Chat Champion
 Posted: 13:53 - 02 Mar 2006 Post subject: Re: Is it bad ? |
| Cog Head |
 Posted: 16:23 - 02 Mar 2006 Post subject: |
WTF  ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
| Barry_M2 |
 Posted: 17:25 - 02 Mar 2006 Post subject: |
Sauce = tomato ketchup.
Source = The word you should have used. Thats all. Move along, nothing to see here!
| Cog Head |
 Posted: 17:36 - 02 Mar 2006 Post subject: |
The last post was made 20 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
