| mrsteko |
 mrsteko Nova Slayer
| jonnay |
 jonnay World Chat Champion
| NSR-Rulez |
 NSR-Rulez World Chat Champion
| mrsteko |
 mrsteko Nova Slayer
| Chiz |
 Chiz Trackday Trickster
| biggaz |
 biggaz Renault 5 Driver
| Fawbish |
 Fawbish World Chat Champion
| biggaz |
| NSR125-Kid-UK |
 NSR125-Kid-UK Attention Whore
 Posted: 23:22 - 25 Feb 2006 Post subject: |
The easiest way to sort out the problem is to compare the total wattages of either side - i.e. each side uses 15 watt bulbs (just an example!) so you need 30 watts a side...In my case, I got round the problem of fitting tiny indicators to the rear of the NSR by fitting oversize bulbs in the front ones.
Basically, the smaller the bulbs on the front, the bigger the ones on the back - make sure they're fairly matched up and it should just be trial and error.
Worrying about resistors is a lot of effort when you can simply just get some oversize bulbs for the indicators that you aren't replacing, unless you replace all of them in which case add up the wattage for each side of the bike and buy a relay with that capacity . ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman |
| biggaz |
| Blunet600 |
 Blunet600 Nearly there...
| alains |
 alains World Chat Champion
 Posted: 10:51 - 27 Feb 2006 Post subject: |
do not be idiot , what you will do with different bulb fittings such are Ba9s and Bay15s !  ____________________ the worst day fishing is better than the best day working |
| fuzz |
 fuzz World Chat Champion
 Posted: 12:10 - 27 Feb 2006 Post subject: |
| NSRdude wrote: | mate i had the same. dont go and buy anything!!!!! you dont need too.
if you still have the original indictors, then do the following.
- attach the new rear indicators.
-and on the front indicators take the bulb out of the new pair, and put the bulb from the old indicators in it. do this for both indicators on the front. then replace the new indactor back on the bike with the bulbs from the old indicators in them. |
Agreed. The NSR uses 10w bulbs, mini indicators use 21w. Either you have to change the relay to one that can handle 21w, or you need 10w bulbs. I would suggest getting 10w bulbs (OE) as a 21w relay requires more current from the battery. Works fine without headlights on or while the revving the engine, but if you're idling at the lights with your beam on, they will flash incredibly slowly or not at all. I know. ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| alains |
 Posted: 12:24 - 27 Feb 2006 Post subject: |
since ages i've told anybody that ! my solution is :
generally these mini indicators use ba9s bulb fittings (21 or 23w) the solution is to find 10w bulbs in ba9s fittings
https://www.norbsa02.freeuk.com/goffybulbs.htm ____________________ the worst day fishing is better than the best day working |
| mrsteko |
 mrsteko Nova Slayer
| alains |
| fuzz |
| tokarev |
 tokarev World Chat Champion
 Posted: 19:38 - 01 Mar 2006 Post subject: |
I have a similar problem...got 21watt bulbs rather than 10watt bulbs. I want to replace them with 10watt bulbs but I am a bit unsure of what type of bulbs they are.
Here is a picture of the bulb alongside a broken one of the same type but with clearer writing on it. Anyone know what type bulb it is?
https://img109.imageshack.us/img109/483/12v21wattbulb1kb.jpg
Thanks! |
| alains |
| tokarev |
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
