OT pc overheating
Danny
Ask Me About Stoppie School
PostPosted: 20:21 - 01 May 2003    Post subject: OT pc overheating Reply with quote
My PC seems to be overheating Confused I checked that the fans are working and they seem to be Confused The power box thing and the processor seem to be the hottest parts, it seems to be working for now with the cover off. Any ideas anyone Question Idea
Syfoon
TRUCK!!!
PostPosted: 20:49 - 01 May 2003    Post subject: Reply with quote
Keep the case off Razz
Or get a big ol' casefan, try https://www.frozencpu.com/ , they offer good stuff Smile
Not here...
kev
I Hump Things
PostPosted: 20:50 - 01 May 2003    Post subject: Reply with quote
run it under a cold tap
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Crazy Manx Man
The Fly Swatter
PostPosted: 20:51 - 01 May 2003    Post subject: Re: OT pc overheating Reply with quote
Try This
Too Fast For Even The Plod To Keep Up With
Danny
PostPosted: 20:59 - 01 May 2003    Post subject: Reply with quote
Helpful as ever Kev Rolling Eyes
Keep the case off
Seems to be the solution for now Very Happy
kev
I Hump Things
PostPosted: 21:04 - 01 May 2003    Post subject: Reply with quote
see i is helpfull
kevo
Cop Seeking Missile
PostPosted: 22:17 - 01 May 2003    Post subject: Re: OT pc overheating Reply with quote
Check the thermal paste on your heatsink if your using some if not get some artic silver or similar and use a fine layer not loads as that makes things worse.
If your heatsink has one of those transfer stickers then remove it and use some proper heat transfer paste as per the above.
Increase the flow of air which exits the rear of the case by adding additional fans and include a fan toward the front blowing cold air into the base.
Regards,
Kevo.
Danny
PostPosted: 22:32 - 01 May 2003    Post subject: Reply with quote
Thx kevo, i'll try the fan idea Very Happy . I don't know about all these pastes Confused
kev
I Hump Things
PostPosted: 22:42 - 01 May 2003    Post subject: Reply with quote
take kevo`s advice he knows about this shit
kevo
Cop Seeking Missile
PostPosted: 23:40 - 01 May 2003    Post subject: Reply with quote
Thermal heat transfer paste. Basically the paste acts as the conduit between the processor and the heatsink. Creating a good transfer of heat between the two by sealing all the small cracks and holes between two peices of metal.
More fans more fans. That's what you need along with some new cpu goop.
Are you running you CPU at it's defined speed or overclocked?.
Regards,
Kevo.
Danny
PostPosted: 23:44 - 01 May 2003    Post subject: Reply with quote
No it's not over clocked or anything; it's only a Pentium II with a 450mhz processor. I really should upgrade the motherboard and processor.
125wannabe
PostPosted: 23:50 - 01 May 2003    Post subject: Reply with quote
Right heres what i think you should do, drill a hole in the case, nip to macdonalds an get a straw tape one end of the straw to the cpu then poke the other end out of the case, then when it gets hot just blow on it
.:simple:.
-ped for sale 2001 Zip SP
?800 ono. its well fast for ped-
-wanted- mk2 VW golf driver 1.6, black-
M1ke
Ped Boi
PostPosted: 01:43 - 02 May 2003    Post subject: Reply with quote
There really isnt much point in upgrading the pc mate, you may as well get a new one.
A pc is as slow as its slowest component, so upgrading the motherboard and processor may not make any difference at all.
Flog the old and get a new Wink
EuropeanNC30R...
Gay Hairdresser
PostPosted: 02:30 - 02 May 2003    Post subject: Reply with quote
Mike's right, its not really worth just upgrading a few components. You can build a nice system these days for around £500, especially if you order from somewhere off the net like ebuyer.
Use the monitor from your old machine, or buy a new one so you can plan deathmatch Quake/UT over a LAN. You know it makes sense! Razz
Phoenix
Twisted Firestarter
PostPosted: 03:51 - 02 May 2003    Post subject: Reply with quote
I disagree, with a Pentium 450 you'll most likely have a GeForce 2 graphics card, TNT2 or an old ATI at the very least. That means a new motherboard, CPU, probably faster RAM and maybe a new Graphics card.... prolly about £200 for that lot, it's still cheaper than buying a whole new system.
As for the overheating, I personally wouldn't bother checking for thermal compound between the heatsink and CPU, CPUs usually come with some paste on them and if not the heatsinks nowadays are polished to a very smooth finish so contact is usually more than adequate. Either way, fans is the way to go as they will make the biggest difference. Also if your Power supply fan is on the way out it'll be generating more heat which will be heating up the inside of your case so that could be the cause if it's only just recently started overheating.
Danny
PostPosted: 11:42 - 02 May 2003    Post subject: Reply with quote
I don't need to upgrade the RAM 'cos i've got 523mb anywayz Very Happy I've also got a TNT 2 Ultra 32mb which could do with upgrading.
Demonic69
The Pink Rhino
PostPosted: 11:46 - 02 May 2003    Post subject: Reply with quote
Bin it Very Happy If a P2-450's overheating you really need a bigger one.
I just specced up a machine for around £300 with a 333 XP 2600 512 DDR400 memory, 128mb GF4 graphics, 80g ATA133 drive etc.
You could get a decent system for £200 easily nowadays
Back on a Blade. Just feels so right.
Guest
PostPosted: 14:16 - 02 May 2003    Post subject: Reply with quote
[/quote] I don't need to upgrade the RAM 'cos i've got 523mb anywayz Very Happy I've also got a TNT 2 Ultra 32mb which could do with upgrading.[/quote]
Ammout of RAM isn't the issue - on a recent MBD and Proc setup, FASTER RAM will be needed maybe DDR and 2100 or 2700 sepc upwards.
Demonic69
The Pink Rhino
PostPosted: 16:06 - 02 May 2003    Post subject: Reply with quote
523mb RAM? now that's difficult! 512 520 or even 528 maybe. Razz
chunkielad
PostPosted: 16:24 - 02 May 2003    Post subject: Reply with quote
it'll be 512 and he's getting the report in bytes not mega bytes
512Mb = 512*1024=524288 not far from what he's said esp if it's reporting free memory and some is used up by system files.
WTF can't everyone in the IT world use the same system - 1024 not 1000 bytes per Mb? Oh yeah that'll be because Misro$oft are wankers!!!
Mark Harrison R.I.P - 26th March 2003.
Remember you always and will ride in your honour.
Big revvs up for Mark!
andrew
Mister Road Rage
PostPosted: 16:36 - 02 May 2003    Post subject: Reply with quote
You might aswell blame Microsoft for the weather aswell Laughing
Danny
PostPosted: 17:37 - 02 May 2003    Post subject: Reply with quote
Well t
Well that is what is says
Scotty
Scooter Boi
PostPosted: 17:50 - 02 May 2003    Post subject: Reply with quote
The joys of that Card,
Regards
Scott
Demonic69
The Pink Rhino
PostPosted: 17:51 - 02 May 2003    Post subject: Reply with quote
Actually it says "523,828 KB.
Which is never and will never ber 523mb Razz
You've got 512mb then Razz
Danny
PostPosted: 18:38 - 02 May 2003    Post subject: Reply with quote
Ok my bad Embarassed
What do you mean Scotty Confused
The last post was made 22 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 125.44 Kb
