Screwing with coke machines
Visitor Q
$25 whore
PostPosted: 04:15 - 13 Mar 2006    Post subject: Screwing with coke machines Reply with quote
It does work
Weird Laughing
Here is a video of some yank doing it
Just tried it on the one in the launderette. Havent got a scooby doo what it does (i had hoped i could lower the price but no luck).
Anyway, give it a go.
That sequence again is 4-2-3-1, and i found holding down 5 works to shut it up. Try the numbers slow and held, or fast.
See what happens.
PS. Anyone worked vending machines? Im assuming it could be a way to change availability of stock or something like that. Ie when you reload it you key in the amount you have put in.
Anyone confirm?
Kwaks
I'm not a fast rider
PostPosted: 09:35 - 13 Mar 2006    Post subject: Reply with quote
But how do you get freebies Twisted Evil
www.cliqueycuntsmcc.co.uk
NSR Mick
PostPosted: 09:47 - 13 Mar 2006    Post subject: Reply with quote
With the coke machine at work if you press your selection twice very quickly it'll give you 2 cans. Whistle
Kwaks
PostPosted: 10:25 - 13 Mar 2006    Post subject: Reply with quote
My work once had set the price wrong and you could get the 'draught' Irn Bru for a penny,was good whilst it lasted(about 6 months).
Adam_P
PostPosted: 10:45 - 13 Mar 2006    Post subject: Reply with quote
Years ago on the earlier machines (with the flip up front panel) one of the mechanics in the team I was working with then had worked out how to get free cans using a piece of bent brake piping from one of the cars.
He said he'd been working really late one night and needed a drink but didn't have any change, took a look under the panel and could see the cans set in the system just above. Went back to the workshop, got a piece of brake pipe and a torch, back to the coke machine, five minutes later he'd worked out what he needed to do and had 5 cans of coke to drink! Laughing Cool
He told us about it one night while we were testing as we all fancied a drink (we were at Snetterton) so him and another guy drove up to the one that was at the far end of the paddock and came back with about a dozen cans! Laughing Laughing Laughing
Not sure it works on the new machines though. Sad
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
McGee
O RLY?
PostPosted: 11:33 - 13 Mar 2006    Post subject: Reply with quote
*Runs of to college giggling*
Hopefully works im tired of spending 2 dollars on a bottle of pap. Shocked
Will return with pics and vids if it does Wink
Its pronounced Jixxer!
tatters
Exxon Valdez
PostPosted: 11:35 - 13 Mar 2006    Post subject: Reply with quote
Thanks to ch0pstickninja for teaching the world about the menu, and for Fire for assisting with research.
PREFACE
Coke vending machines are everywhere. They're getting more and more like regular computers with LEDs that show little "ICE COLD" messages and whatnot. Well, there's a lot more to those little built-in computers than you may think. Included in the low-level operating system that these babies run on is an actual debug menu that gives you access to all sorts of machine information and possibly gives you free cokes in older machines.
WHICH MACHINES WORK?
There's a very strict list of vending machines that have the debug menu. First off, they're all COCA-COLA product vending machines. This means the giant, un-missable picture on the front must show any of the following: Coke, Dasani (Water), Barq's Root Beer, Vanilla Coke, Cherry Coke, Sprite, Evlan (water), Fanta, Fresca, Frutopia, Hi-C, Sprite Remix, Mad River, Mello Yello, Minute Maid, Nestea, Odwalla, Mr. Pibb/Pibb Xtra, Planet Java, Power Ade, Seagram's Ginger Ale, Simply Orange, Sparkletts, or Tab. Of course anything Diet or Caffeine free works too.
The machine must have an LED screen. Some of the older ones just allow the LED to be set to a price amount and won't have the debug menu. You're safer if the little LED is telling you something. Usually it will scroll a little message like "Ice Cold Cokes". Newer machines are more likely candidates.
ACCESSING THE MENU
To enter the menu, there's a button combination. HERE'S THE ONLY THING YOU HAVE TO REALLY REMEMBER:
[4]-[2]-[3]-[1]
The buttons are numbered depending on how they are positioned. They will either be vertical (more likely), or in horizontal rows of 4 buttons per row. If it is vertical, the first button is #1, the one below it is #2, and so forth. If the buttons are in horizontal rows, the first button is #1, and the one to the right of it is #2. The numbers work like a type writer after that. In rows of 4, the first button of row 2 will be button #5. So, to review, getting in to the debug menu looks like this:
COKE MACHINE::::::
$1.00 -------
[ Coke ] <-- Hit this button last
[ Coke ] <-- Hit this button second
[ Diet Coke ] <-- Hit this button third
[ Sprite ] <-- Hit this button first
[ And so on ]
Some text should show up on the LED (probably the word "Error", we'll explain what it means next sections). If nothing happens, your machine doesn't have the debug menu.
NAVIGATION
To navigate from option to option (What they are is next section), remember the numberings we gave the buttons. They work as follows:
Button [ 1 ] - Exit/Back
Button [ 2 ] - Up
Button [ 3 ] - Down
Button [ 4 ] - Select
OPTIONS
Depending on the age of the machine, you will get a varying amount of default options available.
On older machines: SALE, VER, EROR, and RTN
On newer machines: CASH, SALE, EROR, and RTN
CASH - Machine Earnings Display
The CASH option will display how much money is in the machine currently. It generally takes a second or two to load. From here, you can scroll up and down through 12 or 16 different options, depending on the machine age. These other options display how much money was spent on each individual item, classified through its button (or slot, as I like to call it) number.
A neat side note about the slot numbers is that there are more slot numbers than there are actual slot, so usually the last 4 buttons contain zero money. This could be so that the same OS could be used on bigger machines, but the newer machines have even more slot numbers.
SALE - Total Sale Count
The SALE option displays how many drinks have been sold out of the machine. This tends to be cumulative, but not on all machines. The stock guy is probably supposed to reset this each time he re-stocks. Also, this has the same sub-options as the CASH option, where you can scroll up and down and see how many drinks have been sold from each slot.
VER - System/Machine Version?
This option will cause a large alphanumeric string to scroll across the LCD. The number looks very much like a serial number, but doesn't vary from machine to machine. It is most likely the OS or machine version number, but of the older machines that have the option, I haven't seen one that doesn't have the same number.
EROR - Error Log
There are 8 different types of errors - COLJ (Column Jams), VEnd (Vend Mechanism), door (Door Switch), sels (Select Switch), CHAR (Changer Errors), acce (Acceptor Errors), StS (Space-to-sales errors), and bVal (Bill Validators). The separate types and actual errors are useless, as you assumably can't get inside the machine, BUT(!) you can clear the errors. Hold the enter (Number 4) button down for about 2 seconds, and it should clear the error.
RTN - Return
This is simply the return option. Selecting this will exit the debug menu. On newer machines, pressing the BACK button at the main menu will not exit, and RTN must be selected.
A side note: The menu can also be exited by pressing the coin return button.
EXTRAS
By holding in the coin return button and not releasing, on the newer "big-button" machines, this will display the internal temperature in Fahrenheit, as in "42F".
**Update**
There are many more menu options that are only accessible if they've either been enabled from the computer inside the machine, or on the internal computer behind the door (Probably not feasible for you to access).
CPO - Coin Payout Mode
You can can dump coins from the coin mechanism, and the various menu options allow you to choose which type of coins (Nickels, dimes, etc.) are dumped.
Thinking
tVFL - Tube Fill Mode
This is useless to you. This allows you to load coins into the coin tubes, which you can't do from the outside.
TEST - Test Routines
This allows you to test the following various routines:
SE Allows you to test the buttons. Will give you number
of button when you press it
SP Sold-out paddle test. Not quite sure, most likely internal function.
Su Sold-out switch test. Same as paddle.
CO Motor test. Will run various column motors.
Cn Coin test. Put in a coin and it will tell you what kind of
coin it is.
nA Note acceptor test. Same as Cn, but for bills.
dSP Display test. Will illuminate various LEDs.
vErS Rattles off version number.
RELY - Relay test
This tests the relay electronic control of various parts. Do not do, as it will cause damage if various internal parts are not unplugged before usage.
PASS - Password
This is not normally accessible, but allows you to change the menu password from the 4-2-3-1. Whoo!
PrIC - Price Setting
Used to set the price for a drink. Not sure how to work it, but it seems simple enough.
StOS - Space-to-sales routine
Lets you change the STS routine and other options. This means that various buttons will all mean the same thing, i.e. the 6 coke buttons don't actually vend from 6 different columns, but vend from one (changing when one runs out of course).
COn - Machine Configuration/Permissions
This is the machine config menu that decides what of these options you are allowed to access through the outside panel. This is probably only accessible with the door open. I won't go into detail, but I'll list the Config numbers and what each do: C1 sets price menu on, C2 sets special (manufacturer) options on), C3 disables the "ICE COLD COKE" message. C4 is autoviewing of menu when door is opened, C5 is door switch status, C6 is mysteriously reserved for "future use", C7 determines whether your money credit stays in for 5 minutes or indefinitely, C8 is Force Vend, C9 allows multiple vends without putting in more money (i.e put in a 5 and get 3 cokes and then your change), and C10 is Escrow Inhibit.
CCoC - Correct Change Only Control
Adjusts Correct Change only rule to your liking.
TIME - Time Adjustment
Allows you to set the machine's local time.
LANG - Language Selection
Not sure how many languages are supported, but there are apparently more than just English.
USEFULNESS
Unless you can get behind the door, there's little you can do with this except impress your friends. However, if you're able to set the C-switches properly, you'll be able to manipulate the machine in any way you want, get free drinks, change the price, set up cool buy-one-get-one-free deals, etc, etc Smile. Not to forget, knowledge is power. One step closer to free sodas!
{mos_sb_discuss:18}
Last Updated ( Thursday, 31 March 2005 )
Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650 Present:G650XC,C12,KZ750,1190ADV
Andy C
Tree Seeking Missile
PostPosted: 17:49 - 13 Mar 2006    Post subject: Reply with quote
i got a coke machine at work in my section, just me there for hours but dont think it had a LED screen Sad how annoying!!!
Any way of getting free stuff from the non-LED screen coke machines?
tatters
Exxon Valdez
PostPosted: 18:34 - 13 Mar 2006    Post subject: Reply with quote
https://img.epinions.com/images/opti/ab/fa/Ames_6_Pound_Sledgehammer_Shop_Tools-resized200.jpg
thx1138
PostPosted: 18:48 - 13 Mar 2006    Post subject: Reply with quote
CNC punch, and messing about with various offcuts of sheet metal, and a process of trial and error, find the right size and weight blanks to use instead of money to fool the coin mechanism in the machinery, would be my suggestion.
apart from the whole legal issues about fraud & forgery side to it that is... Confused
Andy C
PostPosted: 19:55 - 13 Mar 2006    Post subject: Reply with quote
They might notice!! would be plan as free coke is great......saying that they do let me take 2L bottles of coke and ice from bar so might just do that!!
bikemad495
PostPosted: 21:50 - 13 Mar 2006    Post subject: Reply with quote
the numers that were showing in the video are how many they have sold of each product, i have only dound 2 out of 12 machines which i can get to the proper menu
Valentino Mossy
PostPosted: 22:04 - 13 Mar 2006    Post subject: Reply with quote
Give the machine a shake !
We do !!!! Very Happy
The last post was made 18 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.18 - MySQL Queries: 17 - Page Size: 95.68 Kb
