| Milo |
 Milo World Chat Champion
 Posted: 16:25 - 12 Mar 2006 Post subject: Switching to Telewest cable package |
It's £30/month and includes 2mb broadband, basic TV and phone package...but I seem to be having issues trying to find out much about they internet kit.
The modem has USB and RJ45 connector so I should be fine to use my existing Linksys ADSL router simply as a router/switch though can I route all traffic and the internet IP through to my Linksys so I can use all my existing routing rules/NAT configuration?
I also can't find any mention of static IP or static IP options anywhere, but having not had cable before does a static IP come as default?
Also is the "modem" part of the TV box, or a separate bit of kit?
Any info or suggestions much appreciated!
Adam
ps...I'm switching as my parents want the extra TV channels and the price is fixed for a year, and includes free installation. Also PlusNet are giving me usage warnings... ____________________ Shaft drives rule.  |
| fuzz |
 fuzz World Chat Champion
 Posted: 16:52 - 12 Mar 2006 Post subject: |
The modem is separate, and is usually a Motorola Surfboard. You will get a dynamic IP address, but as the connection is always on, this will hardly ever change unless you are disconnected for some reason. A static IP address is available at extra cost. ____________________ https://www.bikepics.com/members/fuzzbcf/
| iCraig |
 iCraig World Chat Champion
| colin1 |
 colin1 Captain Safety
| carvell |
 carvell Scuttler
| Milo |
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| carvell |
 carvell Scuttler
 Posted: 01:32 - 15 Mar 2006 Post subject: Re: Switching to Telewest cable package |
| Milo wrote: | All results seem to suggest the cable "modem" has an ethernet port, so I'll just use a crossover cable to connect it to my switch/router as it doesn't have an uplink or WAN port. |
Yeah - it does.
However that won't work. Feel free to ignore me, but I have just moved from adsl to telewest and was thinking exactly the same as you.
You cannot plug the modem ethernet port into a standard switch, it has to be the WAN port on a non-ADSL router. I have a linksys one the same as maurice.
As I say you can ignore me, but you'll discover that I'm right.
| Robin Walker Site wrote: | Disregard cable modem documentation about being able to support multiple PCs via a hub: with most domestic broadband ISPs (including NTL, Blueyonder), you can have only one.
If you have more than one computer on a LAN at home, and you want to make the cable modem available to them all, you cannot just plug the cable modem into your LAN hub, because the cable modem will communicate with only one MAC address, and will issue only one IP address via DHCP. |
____________________ Yamaha TDM 850 |
| Milo |
 Posted: 09:02 - 15 Mar 2006 Post subject: Re: Switching to Telewest cable package |
| carvell |
 carvell Scuttler
| Milo |
| zaknafien |
 zaknafien
| carvell |
 carvell Scuttler
| EuropeanNC30R... |
| Tarmacsurfer |
 Posted: 00:37 - 16 Mar 2006 Post subject: |
Think it was the WRT54G v1-4 that had that ability, the v5 is redesigned though, only 32meg of ram and it's a standard (I *think* motorola) chip/firmware for the router functionality so no longer flashable  ____________________ I'm immortal. Well, so far. |
| kawakid |
 kawakid World Chat Champion
 Posted: 01:15 - 16 Mar 2006 Post subject: |
I'm on telewest and have been for years, since cable first came out.
Service is pretty good.
There are lots of ethernet cable style routers that you can use, I have an old D Link 604, 4 port going if you offer us a £10. That works a treat, it will clone whatever MAC address you want and then do the routing.
ie when I first got Telewest, they provided the NIC and then I had to copy the MAC address to the router to fool it. Anyway it works fine.
I've now got a wireless Joby.
But Telewest are good, I particularly like their TV service.
Its the bol**xs , the Teleport is ace.
I rarely watch live TV anymore, I just sit down and choose something I want to watch. Recently, i've been watching loads of episodes of spooks, never watched it before.
Only thing I wish, it would record, channels other than BBC ones. ____________________ I've a twin and a 4. |
| UKski |
 UKski L Plate Warrior
 Posted: 13:43 - 31 Mar 2006 Post subject: Re: Switching to Telewest cable package |
| carvell wrote: | | Milo wrote: | I should be fine to use my existing Linksys ADSL router simply as a router/switch though |
That's what I thought.
Your ADSL needs to have a RJ45 WAN socket for this to work, every single ADSL router I've seen doesn't, it only has a connection designed for a telephone line.
You can't plug the cable modem into the telephone WAN port on your ADSL router. Nor can you plug it into one of the ports on your switch, it won't magically share between all of the PC's also plugged into it. |
A router connects two different subnets, i.e WAN to LAN. Each subnet must be on opposite sides of the router, i.e the internet connected to the WAN side and your PCs connected to the LAN side, either directly to the built in swith or through a hub/switch if your router has only one LAN port. If you have an ADSL modem router then the WAN port on your router is actually an ADSL modem which then connects to the built in router, which is why you must connect your telephone line. This is why you cannot connect blueyonder/ntl to an ADSL modem router as you cannot bypass the modem function of it, so the only connection available is for your telephone line. If however you just have a product sold as an 'ADSL router' (note no mention of modem) which you plug an ADSL modem into, then this will be fine to work with telewest as the WAN input into the modem is an ethernet connection, which you simply plug your cable modem into as opposed to your ADSL modem. You cannot plug a cable modem into the LAN side of the a modem router as it will not go through the router section of it. You can think of an ADSLmodem router as three seperate units joined togetherin series:
1. An ADSL MODEM ---> 2. A Router ---> 3. A LAN Switch
What you are trying to do with a cable modem is bypass the modem and go direct to the router function, however there is no real simple way to do this.
If however you are prepared to use internet connection sharing you could plug your cable modem into a computer and then using ICS share the internet connection with other computers connected to the LAN on the router. This however does not use the routing funciton of you router (as your PC is doing all the work) and means you have to have that PC on all the time.
Basicly what I am trying to say is that if you have an ADSL Modem router then IMHO you would be better off buying a new router rather than using ICS. If however you currently have a seperate ADSL modem plugged into your router then you will be fine.
Hope this makes sense/helps
D |
| UKski |
| daz|n00by |
 daz|n00by The Internet
 Posted: 19:41 - 31 Mar 2006 Post subject: |
And dont forget that your 2 meg will be upgraded to 10 meg for free unless you only ordered 512k..
"blueyonder broadband - 512k becomes 2Mb
Currently our introductory service runs at up to 512K. This will become up to 2Mb, that's 4x faster at no extra cost.
In addition we are doubling the upstream speed (the speed at which you can attach photos and files to the internet) to up to 256k.
blueyonder broadband complete - 1Mb becomes 4Mb
Our standard service currently has a speed of up to 1Mb. This will become a super-fast up to 4Mb service, that's 4x faster than the current speed at no extra cost.
We are also increasing the upstream speed to up to 384k from 128k.
blueyonder broadband elite - 2Mb and 4Mb become an amazing 10Mb
Our elite services with speeds of either 2Mb or 4Mb will both be increased, to up to 10Mb.
The broadband elite- 2Mb service will also benefit from an increase in upstream speed to up to 384k.
The 10Mb service costs only £35 (the price for current 4Mb customers waiting to be upgraded was reduced to £35 at the end of 2005 )." ____________________ "Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class.  |
| NSR Mick |
 NSR Mick World Chat Champion
The last post was made 20 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
