Scottoiler pipes which where how ?
MikeH
PostPosted: 20:29 - 16 Mar 2006    Post subject: Scottoiler pipes which where how ? Reply with quote
Has anyone got a scottoiler who can tell me how it should all be mounted and connected up.
I bought a second hand one off Ebay for £25 and it has one pipe out of the bottom which I assume is to feed down to the chain. Then there are two pipes on the top a thin black one for ? vacuum ? and another larger short pipe which I think may a breather am I right.
Then how do you set it up i.e. how much oil, can I use any old oil etc..
Any help greatly appreciated
Ta Mike Cool
Busa Junkie
Steve H
PostPosted: 20:44 - 16 Mar 2006    Post subject: Reply with quote
Try Here or Here
Or the Scottoiler site has plenty of details and FAQ's Thumbs Up
Mellow Yellow
Guest
All you need to know on here mate https://www.scottoiler.com/
they're apparently very helpful so if you're still stuck a phone call should sort it Thumbs Up
PostPosted: 21:07 - 16 Mar 2006    Post subject: Reply with quote
Spot on. Oil out the bottom, vacuum in the top, breather out the rubber bit on the side.
Technically you are suppoosed to use scotoil. I just bung engine oil in mine, seems to be ok.
If you look at the inlet stub of the right carb, there is a rubber over the vacuum inlet, take this off. There should be a fitting with the scotoiler like a black rubber boot that has a branch coming off it (see picture). Push this over the vacuum stub and run some of the thin black hose from it to the top of the scotoiler (you can thread it through the frame alongside some of the wiring).
I just fitted mine to the frame tube using two bits of rubber hose and some cable ties. Easily acessable there and easy to route the hose but still behind the mudguard. (see diagram)
I routed the hose along the swingarm and fixed it there using cable ties, remember to leave some slack at the pivot to allow for movement of the swingarm. Then it is just a case of bending the delivery tube so it drips oil onto the chain at the 6 o' clock position. (oil hose coloured red on picture).
Took me about 15 minutes, which includes thinking time.
Just tuck the breather up under the plastic.
MikeH
PostPosted: 21:09 - 16 Mar 2006    Post subject: Reply with quote
Top Job, cheers guys Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Busa Junkie
MikeH
PostPosted: 21:24 - 16 Mar 2006    Post subject: Reply with quote
Just been out to have a look at mine and I'm going to have to get hold of a vacuum rubber thingy or nick one off an old lucas distributer down at the local tat yard Wink
Link to KLE500 oiler PDF
Busa Junkie
PostPosted: 21:31 - 16 Mar 2006    Post subject: Reply with quote
If you have the T-piece, you can tap into the vacuum tube going to the fuel cock too.
vfr800
PostPosted: 23:11 - 17 Mar 2006    Post subject: Reply with quote
It only cost's £4.50 for the correct oil and it lasts for ages.
don't take it easy 'ride it like you stole it'
MikeH
PostPosted: 13:00 - 18 Mar 2006    Post subject: Reply with quote
Fitted it up this morning, piece of cake. Used a stop rubber of a diesel injector and popped a tight hole in it for the vacuum pipe, worked a treat.
I've given the chain a good clean with some white spirit adjusted it up and have set the oiler at about half so I'll see how she goes.
Thanks for the help guys Thumbs Up
Mike
Busa Junkie
PostPosted: 19:16 - 19 Mar 2006    Post subject: Reply with quote
If you heat the end of the thin black vacuum hose with a lighter, it 'mushrooms' which would stop it pulling back out of the rubber.
MikeH
PostPosted: 19:41 - 19 Mar 2006    Post subject: Reply with quote
No worries it's well and truly in there Wink
Busa Junkie
The last post was made 19 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 69.53 Kb
