| sunbear |
 sunbear Could Be A Chat Bot
| sunbear |
 Posted: 14:09 - 18 Mar 2006 Post subject: |
WOW thanks for the help guys Sorted it I found it myself  |
| fuzz |
 fuzz World Chat Champion
 Posted: 14:11 - 18 Mar 2006 Post subject: |
I take it you don't need my help anymore!
I was in the process of answering your question, but then the machine decided to reboot itself unexpectedly.
Are you sure you need to set the needle lower though? I would have thought you needed to raise it to help in the midrange, considering you have a 190cc kit.  ____________________ https://www.bikepics.com/members/fuzzbcf/
| sunbear |
 Posted: 11:35 - 20 Mar 2006 Post subject: |
Yeah Stan Stephens said for more mid range power it needs to be richer . Hence lower it one . It was on the second from top anyway when it should have been in the middle . Now it aint working properly at all ( |
| fuzz |
 Posted: 12:07 - 20 Mar 2006 Post subject: |
The needle needs to be higher to richen up the midrange. Standard is 3rd groove, I think he meant lower the clip, not the needle. It should have gone on 4th groove from the top. The problem you have might be due to running lean. I would be concerned with damage to the piston if you still have the problem. Running lean = running hot. Not a good situation. ____________________ https://www.bikepics.com/members/fuzzbcf/
| sunbear |
 Posted: 14:25 - 20 Mar 2006 Post subject: |
Yeah i put the clip on the 3rd (middle) notch but had this problem with the spluttering so i put it back on the second and its doing it on that setting now New piston has only just been ran in  |
The last post was made 19 years, 284 days ago. Instead of replying here, would creating a new thread be more useful? |
