NSR carb
sunbear
PostPosted: 10:01 - 18 Mar 2006    Post subject: NSR carb Reply with quote
Got the carb out of my NSR125, need to know where/how to set needle 1 setting lower. Where is it ????????
sunbear
PostPosted: 14:09 - 18 Mar 2006    Post subject: Reply with quote
WOW thanks for the help guys Razz Sorted it I found it myself Mr. Green
fuzz
PostPosted: 14:11 - 18 Mar 2006    Post subject: Reply with quote
I take it you don't need my help anymore! Mr. Green
I was in the process of answering your question, but then the machine decided to reboot itself unexpectedly. Mad
Are you sure you need to set the needle lower though? I would have thought you needed to raise it to help in the midrange, considering you have a 190cc kit. Confused
sunbear
PostPosted: 11:35 - 20 Mar 2006    Post subject: Reply with quote
Yeah Stan Stephens said for more mid range power it needs to be richer . Hence lower it one . It was on the second from top anyway when it should have been in the middle . Now it aint working properly at all Sad(
fuzz
PostPosted: 12:07 - 20 Mar 2006    Post subject: Reply with quote
The needle needs to be higher to richen up the midrange. Standard is 3rd groove, I think he meant lower the clip, not the needle. It should have gone on 4th groove from the top. The problem you have might be due to running lean. I would be concerned with damage to the piston if you still have the problem. Running lean = running hot. Not a good situation.
sunbear
PostPosted: 14:25 - 20 Mar 2006    Post subject: Reply with quote
Yeah i put the clip on the 3rd (middle) notch but had this problem with the spluttering so i put it back on the second and its doing it on that setting now Sad New piston has only just been ran in Thumbs Up
The last post was made 19 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 46.58 Kb
