dam!!!!!!!!!!!!1
riichy
PostPosted: 17:53 - 18 Mar 2006    Post subject: dam!!!!!!!!!!!!1 Reply with quote
ok bit of a problem..
my bike has started cutting out.. it will run fine then just cut out. the engin the lights the lot cuts out, then it will spring back..
i can also have it running then when i shake the bike it cuts out, like there is a lose wire or something. but when it comes back to life its fine Mad
i dont know wether its just all the snow and wet we have been having or what, because its be stud out side college in snow and rain all week Question
its pi#sing me off though beacuse i have skegy coming up this friday.. Sad
.......... PLOD ............ zx636 2004
Rob W
PostPosted: 18:46 - 18 Mar 2006    Post subject: Reply with quote
Try checking all your connections. Take them all apart, spray some WD in there and try that. May just be a loose connection somewhere, or a bit of water has got in.
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
Jammy-R6
PostPosted: 18:55 - 18 Mar 2006    Post subject: Reply with quote
Check the connections from the battery terminals, and wiggle the wires around the coils, HT leads etc until the problem occurs then bingo.
Rob W
PostPosted: 18:56 - 18 Mar 2006    Post subject: Reply with quote
When it cuts out, does it fire up again straight away?
riichy
PostPosted: 19:04 - 18 Mar 2006    Post subject: Reply with quote
some times it cuts out and thats it.... no power for like 2 mins.... then sometimes it cuts out and in less than a second its back agin.. like a flickering light bulb Confused
Rob W
PostPosted: 19:06 - 18 Mar 2006    Post subject: Reply with quote
Definitely sounds like a dodgy connection somewhere. Was thinking it may be a charging problem and it was draining the battery, but if it starts OK it probably isn't.
Best to just go through and check all your connections, make sure there's nothing loose and give them a clean up.
mchaggis
PostPosted: 19:53 - 18 Mar 2006    Post subject: Reply with quote
A multimeter or continuity tester would make your job far more simple. Don't try measuring anything in the HT portion while it is running however. Shocked
I must not be a troll...
Mmmm, Guinness
bish777
PostPosted: 01:44 - 19 Mar 2006    Post subject: Reply with quote
likely sites of failure are at the battery or the fusebox for this kind of failure, start by checking all the connections here.
GSXR1100J
Jrod
Page 3 Girl
PostPosted: 02:03 - 19 Mar 2006    Post subject: Reply with quote
I belive a place like this may be the best thing for it...
https://freespace.virgin.net/r.welfare/scrapyard.jpg
phantomtek
Lil Joe Tek
PostPosted: 02:53 - 19 Mar 2006    Post subject: Reply with quote
Could it maybe be anything to do with when you replaced the CDI? Maybe you left a connection loose ?
Just a thought though. Karma
riichy
PostPosted: 13:52 - 19 Mar 2006    Post subject: Reply with quote
well today its dead,,,, Mad
no power at all, not even the little LED's..
jordan talked me though a few things but there not the problem so off to the garage it gos..
just hope its nothing bad i need the bike for skegy this friday, other wise dose any one want a £78 3 night stay with yoko and uncle.. Wink
The last post was made 19 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 70.45 Kb
