Brake Calipers
minesweeper
Whoah there!
PostPosted: 14:07 - 04 May 2003    Post subject: Brake Calipers Reply with quote
Currently im in the middle of rebuilding my bike after the skidmarx fairings i had fitted earlier this year decided to rip themselves apart...... Turns out the garage who fitted them didint have any instructions so the entire headlight fairing was held on by ...... 1 bolt
that bolt snapped surprise surprise the resulting weight on the side fairings split them but luckily my crash mushrooms held the weight of the front end until i could park up...
Ive now got a full refund and bought new side panels but not a bellypan, Im tempted to not bother with the belly pan because i like the sight of the engine and the side panels cover all the wiring. I will have the healight fairing and side panels finished in smokey joe colours.
The point of this post however Smile is that ive been offered a pair of mv aguste front brake calipers, would i be able to fit them to my rvf and would it result in an improvement in braking performance... ?
minesweeper
TiN
Pocket Tin
PostPosted: 15:06 - 04 May 2003    Post subject: Reply with quote
Just how cheap are the calipers? ...and is there anything actually wrong with your current ones?
I doubt that many people here could give you a definately answer, but the easiest way to check is to just physically compare the 2 calipers (or at least have a clear picture of them) and check the mounting points, their alignment with the discs etc.
As for a belly pan, I'm just in the process of fixing up my crashed bits, and the belly pan survived quite well (all lugs intact etc) but just a bit cosmetically challenged (which will be fixed and primed etc), interested? But from my experience, original fairing panels don't seem to go well with aftermarket stuff.
TiN
dotgems.net
PostPosted: 15:13 - 04 May 2003    Post subject: Reply with quote
I've tried fitting my (ex) zx6 calipers to the zx9... they're exactly the same, but din't quite fit Confused
So be very sure they will.
TBH braided hoses (IF you don't have 'em) and a fluid change will probably give you plenty enough power Smile.
minesweeper
Whoah there!
PostPosted: 15:19 - 04 May 2003    Post subject: Reply with quote
nah tin my bellypans fine just not sure if id perfer the rvf half faired Smile on another note tin try riding the rvf without any fairings and headlights the handling is amazing! all that weight off the front end! on the oher hand the weight loss makes the bars twitch Rolling Eyes
Ive already got braided lines on front and back just looking for more power Cool
Matt
TiN
Pocket Tin
PostPosted: 18:53 - 04 May 2003    Post subject: Reply with quote
Bah, why bother with brakes, they only slow you down Wink
The thing is though, why do you need extra braking power? Six pots aren't automatically *that* much better that 4-pots, unless you have radial calipers, so you probably won't notice much difference. The Fireblade and R1 still have 4-pots.
Also, the more powerful your brakes are, the quicker you'll eat through pads and discs...and front tyres Wink
TiN
dotgems.net
Mrs_Hippy
The Pink Lady
PostPosted: 21:47 - 04 May 2003    Post subject: Reply with quote
They certainly do if you are pottering along to work when they decide to seize on fully
Twisted Evil
Karma - Karma
The last post was made 23 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 50.13 Kb
