Electrical probs
HerbalDayZ This post is not being displayed because the poster is banned. Unhide this post / all posts.
Rookie
PostPosted: 02:14 - 20 Mar 2006    Post subject: Reply with quote
Things dimming at low revs are probably due to a dodgy battery. It may just need charging; Lidls are selling trickle chargers for £5 today, so get down there sharpish and see if they have any left. If charging it up overnight doesn't solve it, you probably need a new one.
If moving the bulk of wires about seems to stop this cutting out happening, it's probably a dodgy connection somewhere along the line, or possibly corroded wire(s), or something earthing on the frame, who knows? It's time to whip of somefairings and have a look around, see if anything looks amiss. If it does, it's best to get it down to a mechanics so they can say what exactly is wrong with it.
Mr.Everready
PostPosted: 13:37 - 21 Mar 2006    Post subject: Reply with quote
A trickle charger keeps your battery at top charge all the time.
Rit
PostPosted: 13:55 - 21 Mar 2006    Post subject: Reply with quote
Not sure about the ones at Lidl but mine has a connector that you can leave on the bike all the time. That way you just plug your charger into it. You could knock sommat up to fit on your bike if the Lidl ones dont have them (and at 5 quid it aint bad)
If you ride it every day I wouldnt have thought you would need one. I got mine because I only use the bike a couple of times a week.
Mr.Everready
PostPosted: 14:08 - 21 Mar 2006    Post subject: Reply with quote
HerbalDayZ wrote:
How often do i have to use it ? .Would that mean removing the battery everynight an putting it on charge ?.One time a week or somthing .
thanks MR.everready
As said already you leave the battery in the bike and connect it up when you put the bike away for the night or longer. You then know that when you come to ride it again it will start ok.
Mr.Everready
PostPosted: 16:20 - 21 Mar 2006    Post subject: Reply with quote
If you stay in a flat and the bike is out in the open then that is a different kettle of fish all together. Laughing
Looks like you'll have to take the battery out and charge it inside, nothing else you can do.
edd
PostPosted: 17:43 - 21 Mar 2006    Post subject: Reply with quote
if i were you id check your regulator rectifier
check what voltages its putting out as you rev your bike up,
should be about 15 ish
Bluespark Automotive - Diesel Tuning for Performance and Economy
The last post was made 19 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 77.1 Kb
