removal of exhaust bolts
hazza
PostPosted: 21:59 - 21 Mar 2006    Post subject: removal of exhaust bolts Reply with quote
i goty a new engine for my rxs from a breakers a few days ago and today after putting it into the frame i found that one of the exhaust bolts is seized into the thread...how dop i get the dam thing out!!!!...i know it can come out as obviously the dude at the breakers removed it not long ago as i saw the bike the engine came out of a month or so before
Rit
PostPosted: 22:52 - 21 Mar 2006    Post subject: Reply with quote
Try seeping plenty of penetrating oil in 1st and leaving it to soak a while before trying again.
bish777
PostPosted: 22:58 - 21 Mar 2006    Post subject: Reply with quote
I also found heating it with a blowtorch helped immensely.
Is it an allen head bolt? If so, if you round the thread you can grip the outside with a set of molegrips after heating it and get good leverage.
GSXR1100J
hazza
PostPosted: 23:14 - 21 Mar 2006    Post subject: Reply with quote
ok im not being technical here its a 12 mm nut but the nut is like on a bolt and when i undo the nut(if i could ) the bolt will come out with it
Bezzer
PostPosted: 23:35 - 21 Mar 2006    Post subject: Reply with quote
The "bolt" is a stud, doesn't matter if it comes out with the nut you can sort it out off the bike and either clean it up or get a replacement. Much better than snapping a bolt off inside the head you get two chances either the nut comes off on it's own or it comes off with the stud...a win win situation Mr. Green .
bish777
PostPosted: 23:37 - 21 Mar 2006    Post subject: Reply with quote
Indeed, my GSXR has bolts into the head. I am going to convert to studs as the bolts were total bastards to get out last time.
remove the lot! Find a suitable steel bolt and cut the head off, hey presto new stud.
GSXR1100J
hazza
PostPosted: 23:40 - 21 Mar 2006    Post subject: Reply with quote
no the stud is stuck too, nothing will move and i dont want to force it and snap it in the head...sorry for bad description
bish777
PostPosted: 00:12 - 22 Mar 2006    Post subject: Reply with quote
well heat the bugger up with a blow torch nice and hot, then allow to cool.
repeat a few times.
then get a fark off spanner on the nut and get it off.
GSXR1100J
hazza
PostPosted: 20:54 - 22 Mar 2006    Post subject: Reply with quote
cheers mate the heat was just what the doc ordered
The last post was made 19 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 58.62 Kb
