Rear brake on NSR 125 help...
Blunet600
PostPosted: 18:55 - 23 Mar 2006    Post subject: Rear brake on NSR 125 help... Reply with quote
My rear brake is shit! it hardly does anything when pressed down, i have to use the fron brake for everything as th back is nor reliable. how can i change this or what might be the problem?
i have topped up the brake fluid in case it was that, no change, i have tried altering the position of the rear brake lever, no change. please help?
veeeffarr
PostPosted: 19:01 - 23 Mar 2006    Post subject: Reply with quote
Have you tried bleeding the brake system?
Do they feel spongy?
Blunet600
PostPosted: 19:05 - 23 Mar 2006    Post subject: Reply with quote
i havent felt them spungy? but i know i have to push really hard on the lever to get the back brake to have some (little but some) effect on the slowing down of the bike.
i havent tried bleeding it no, i didnt think i woudl need to coz i dont think it is this. how ever u could be wrong.
NSR-Rulez
PostPosted: 19:15 - 23 Mar 2006    Post subject: Reply with quote
The rear brake on any sports bikes are crap, mine is poor, thats why there's a massive front disc.
Front brake is fine to use alone.
NSR-Rulez
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
Handsome
PostPosted: 19:48 - 23 Mar 2006    Post subject: Reply with quote
Top up your brake fluid and bleed it as you go.
If it still feels the same after then you may need new pads, they're a piece of piss to change. While you're changing them give the Caliper a good srub and clean aswell and check the condition of your brake disc while you're at it.
If you need to change them give David Silver Spares a ring.
And if you feel up to it while you are doing the back give the front a check and clean.
Chiz
PostPosted: 20:14 - 23 Mar 2006    Post subject: Reply with quote
Mine is useless as well, just make sure you look after the front brake.
alains
PostPosted: 20:20 - 23 Mar 2006    Post subject: Reply with quote
rear break on nsr is just a slow down accessory . it's good that it's not a strong one , otherwise you had fell down very often ! you can improve a bit by changind the rubber pipe between the master & caliper with aeroplane type (brembo) .
Blunet600
PostPosted: 20:13 - 24 Mar 2006    Post subject: Reply with quote
ummmm.... how do i bleed the rear brake on my nsr? (stupid, i know)
alains
PostPosted: 20:19 - 24 Mar 2006    Post subject: Reply with quote
like the front one Idea Very Happy
Blunet600
PostPosted: 20:22 - 24 Mar 2006    Post subject: Reply with quote
alains do you know how i can get this exact heel plate?
its from that german website, i dunno hwo to order it from there and ebay dont have any.
alains
PostPosted: 00:04 - 25 Mar 2006    Post subject: Reply with quote
not yet , i will have a look on german sites
alains
PostPosted: 00:14 - 25 Mar 2006    Post subject: Reply with quote
found it , they are 50 euros for the set , it means £40 with postage
https://www.motorrad-bach.de/
clic on "NSR125" then on "teil 1" and go down the page
Blunet600
PostPosted: 00:54 - 25 Mar 2006    Post subject: Reply with quote
thats the website i saw it from but i dunno how i can order it, the website doesnt seem to give ma an option to buy it
alains
PostPosted: 03:40 - 25 Mar 2006    Post subject: Reply with quote
you must mail first , but i am not sure they will answer . sometime yes other time no , you may insist !
jonnay
PostPosted: 13:58 - 25 Mar 2006    Post subject: Reply with quote
I emailed them once about mirrors. Got a reply back the next day which said;
"Hello
The Shipping Coast for your Country is 18,-€ you can pay with Credit
Card.Motorrad Bach"
Just email them, they speak english!
Jon
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
code guru
PostPosted: 03:33 - 27 Mar 2006    Post subject: Reply with quote
buy how does your bike passes the mot? i mean i just spent like 2 weeks trying 2 get my back brake on my rieju 2 brake from new pads 2 new spacers 2 cleaning my back disk and wearing my pads down and its slows the bike down but i am takeing it for an mot 2moro, but at the otherhand your back brake shouldnt be sharp coz it lock up and i did that once with my old yam and i nearly flew off the bike Laughing Laughing
John C
PostPosted: 11:56 - 27 Mar 2006    Post subject: Reply with quote
The back brake on my NSR is actually quite good, you only need to use it lightly, otherwise you could lock the rear wheel. There's certainly no need to "push really hard on the lever" with mine.
alains
PostPosted: 12:16 - 27 Mar 2006    Post subject: Reply with quote
do you read sometimes answers ?
element
PostPosted: 16:56 - 28 Mar 2006    Post subject: Reply with quote
The rear brake on my scoot was like that... I changed the pads, gave the caliper a good stripdown/clean (found out one piston had semi seized) and then finally gave the disc a clean with some ethenol to make sure no oil/grime were on the discs (which might be your problem). Now I can lock the back wheel quite easily if I want. Before I nearly could pull off with the lever in as far as I could pull it!
You can pass an MOT with a fairly weak brake (not as in lever to the handlebars just generally shite) since they only take it off the center stand and push the bike forward while grabbing the brake. Mine would grip ok if I was just pushing the scoot around... Was worse than useless at anything above 10-15mph though..
I remember actually back when my rear hose needed replacing.. I took my scoot to the bikeshop with a crappy rear brake and it came back exactly the same. I was hoping they'd sort it but they must of assumed they were ok but just pushing the bike around you wouldnt've known. but yeh 3 days later all the fluid had leaked out causing complete failure Evil or Very Mad fucking idiots. Didnt think to double check all the bolts were tight when they replaced the hose had they!! Sick Thumbs Down shouldve went back and kicked off but you cant exactly prove anything Neutral
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
code guru
PostPosted: 22:54 - 28 Mar 2006    Post subject: Reply with quote
well my rieju brakes now coz wot i did woz go fast and at the same time hold the brake down and it slowed down and now its better, but before i took it in for an mor and the guy said he had 2 test it on the roller test machine? i know they got them for cars but i cant c how they can use them on a bike, well gona put my bike in for its mot 2moro tho Very Happy but u slow down with your gears anyway and use the brakes gently, but i am so use 2 an auto i whanted my back brake 2 be sharp Rolling Eyes
The last post was made 20 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 106.09 Kb
