| Blunet600 |
 Blunet600 Nearly there...
| veeeffarr |
 veeeffarr Super Spammer
| Blunet600 |
| NSR-Rulez |
 NSR-Rulez World Chat Champion
| Handsome |
 Handsome World Chat Champion
 Posted: 19:48 - 23 Mar 2006 Post subject: |
Top up your brake fluid and bleed it as you go.
If it still feels the same after then you may need new pads, they're a piece of piss to change. While you're changing them give the Caliper a good srub and clean aswell and check the condition of your brake disc while you're at it.
If you need to change them give David Silver Spares a ring.
And if you feel up to it while you are doing the back give the front a check and clean.
 ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| Chiz |
 Chiz Trackday Trickster
| alains |
 alains World Chat Champion
| Blunet600 |
| alains |
 Posted: 20:19 - 24 Mar 2006 Post subject: |
like the front one  ____________________ the worst day fishing is better than the best day working |
| Blunet600 |
| alains |
| alains |
 Posted: 00:14 - 25 Mar 2006 Post subject: |
found it , they are 50 euros for the set , it means £40 with postage
https://www.motorrad-bach.de/
clic on "NSR125" then on "teil 1" and go down the page ____________________ the worst day fishing is better than the best day working |
| Blunet600 |
| alains |
| jonnay |
 jonnay World Chat Champion
| code guru |
 code guru Brolly Dolly
 Posted: 03:33 - 27 Mar 2006 Post subject: |
buy how does your bike passes the mot? i mean i just spent like 2 weeks trying 2 get my back brake on my rieju 2 brake from new pads 2 new spacers 2 cleaning my back disk and wearing my pads down and its slows the bike down but i am takeing it for an mot 2moro, but at the otherhand your back brake shouldnt be sharp coz it lock up and i did that once with my old yam and i nearly flew off the bike  |
| John C |
 John C World Chat Champion
| alains |
| element |
 element World Chat Champion
 Posted: 16:56 - 28 Mar 2006 Post subject: |
The rear brake on my scoot was like that... I changed the pads, gave the caliper a good stripdown/clean (found out one piston had semi seized) and then finally gave the disc a clean with some ethenol to make sure no oil/grime were on the discs (which might be your problem). Now I can lock the back wheel quite easily if I want. Before I nearly could pull off with the lever in as far as I could pull it!
You can pass an MOT with a fairly weak brake (not as in lever to the handlebars just generally shite) since they only take it off the center stand and push the bike forward while grabbing the brake. Mine would grip ok if I was just pushing the scoot around... Was worse than useless at anything above 10-15mph though..
I remember actually back when my rear hose needed replacing.. I took my scoot to the bikeshop with a crappy rear brake and it came back exactly the same. I was hoping they'd sort it but they must of assumed they were ok but just pushing the bike around you wouldnt've known. but yeh 3 days later all the fluid had leaked out causing complete failure fucking idiots. Didnt think to double check all the bolts were tight when they replaced the hose had they!! shouldve went back and kicked off but you cant exactly prove anything  ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| code guru |
The last post was made 20 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
