| matphillipsuk |
 matphillipsuk Borekit Bruiser
| G |
 G The Voice of Reason
| matphillipsuk |
| G |
| ZZR-Souls |
 ZZR-Souls Renault 5 Driver
 Posted: 14:44 - 30 Mar 2006 Post subject: |
Fuel tap M8. The backfire is because it's running really lean.
The Hondas have a vacuum pipe on the fuel tap. If it has become detached or has split the fuel tap wont open and therefore you'll not get any fuel in the carbs. If the vacuum pipe is OK then I'd suspect the diaphragm inside the fuel tap has perished with the same result.
There is a modification that removes the vacuum part of the system. If you want' I'll get you the info on how to do it. ____________________ JOIN IN THE BIGGEST RIDE-OUT OF 2007 here |
| matphillipsuk |
The last post was made 20 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
