New piston...(Someone has to know)
Cog Head
PostPosted: 00:52 - 30 Mar 2006    Post subject: New piston...(Someone has to know) Reply with quote
How manny kilometers should i run it in for ? and at what revs ?
any help wil be appreciated Thumbs Up
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
element
PostPosted: 01:44 - 30 Mar 2006    Post subject: Re: New piston...(Someone has to know) Reply with quote
Everyone has there own way so you aint gonna get a straight answer.... But since its only the piston that needs bedding in just take it easy for like 1500km to let the seals set in then just carry on riding like you would..
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
Ichy
PostPosted: 09:26 - 30 Mar 2006    Post subject: Reply with quote
You can go from one extreme to the other, I thought a couple of hundred miles (300km) without putting loads of strain on the engine would have been more than enough?
I found this which was recommended after a complete rebuild of a off road ATV.
ATV OnLine Tech Sheet
by Colin Bylund, Editor ATV OnLine
Two Stroke Engine Break In
After engine has been installed and all fluids replenished (coolant/water, gear oil etc) you must then break the engine in properly. Improper break in results in lower reliability and possible engine seizures.
Use the gas and oil mixture ratio that you intend to run after the break in. Check all fluid levels periodically during the break in. Check the carb jetting periodically during the break in.
Part 1
Idle: Start engine and let idle with a fan blowing on the radiator to help it cool properly. Let idle for 15 minutes.
Cool Down: Shut engine off and let engine cool for a minimum of 30 minutes.
Idle: Repeat first step.
Cool Down: Repeat second step.
Part 2
Note: Be careful not to put unnecessary strain on the motor during the break in. Do not climb large hills or go through deep mud. If possible use a mild treaded tire. If you are on the sand do not use sand paddles.
Ride: Ride for 15 minutes varying your RPM not to exceed 50% of normal riding pace.
Cool Down: Shut engine off and let cool for a minimum of 30 minutes.
Ride: Ride for 15 minutes varying your RPM not to exceed 60% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 70% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 80% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 90% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 100% of normal riding pace.
puremagic72
PostPosted: 18:32 - 30 Mar 2006    Post subject: Reply with quote
About 400 miles on my ns125-r, just had new piston and rings and cylinder gasket put on, and honda shop said 400miles.
So most bikes are probably the same.
Baz. Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
Cog Head
PostPosted: 01:40 - 31 Mar 2006    Post subject: Reply with quote
thanks for the help guys Thumbs Up karma on the way
ill have a go at the technique stated above on the weekend
fuzz
PostPosted: 13:09 - 31 Mar 2006    Post subject: Reply with quote
While the ATV procedure might work, I would think that for the first 200 miles or so, don't exceed 5000 rpm. Use varying engine speeds.
For the next 500 miles, increase the maximum engine speed gradually.
Cog Head
PostPosted: 21:26 - 31 Mar 2006    Post subject: Reply with quote
i red lined today, Surprised the bike felt well rough so i went up 2 gears Shifty
but it keeps overheating, i think it may be the result of a nakered thermostat
puremagic72
PostPosted: 21:33 - 31 Mar 2006    Post subject: Reply with quote
well, you really have to be carefull, can see a nasty sieze coming up!!!
I know its frustrating to hold back the revs,like me(just had new piston in), but if you value the bike, well its up to you.
Looking at £200 upwards otherwise, unless your lucky!!
Baz. Thumbs Up Thumbs Up
NC30UK
PostPosted: 22:15 - 31 Mar 2006    Post subject: Reply with quote
I basically run in over 500km gradually increasing the revs.
exat figures don't matter, but the more slowly you take things the more likely you are to not break anything, and to spot a problem before it causes serious damage
Gazdaman
I did a trackday!!!
PostPosted: 01:31 - 01 Apr 2006    Post subject: Reply with quote
https://www.mototuneusa.com/break_in_secrets.htm
Gaz
Andy C
Tree Seeking Missile
PostPosted: 10:14 - 01 Apr 2006    Post subject: Reply with quote
i had to run my RS125 in twice and did it first time buy manual instruction but 2nd time and skiped the last bit (under 9000rpm) but still easy and was fine
Very painful on a 125 so cant imaging on a 50 Shocked
Cog Head
PostPosted: 14:05 - 01 Apr 2006    Post subject: Reply with quote
its painfully slow going on a me 50, im going 20Mph up a 40Mph hill, i just got so tempted to nock it down a gear or 2 and open it up, but i just pulled into a street and waited for the traffic to be clear so i could get a run up to the hill at around 40 Mph Laughing
worked tho Thumbs Up
i must admit i did open it up twice yesterday Shifty Embarassed
The last post was made 19 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 75.65 Kb
