CDI unit question
lee125
PostPosted: 10:08 - 30 Mar 2006    Post subject: CDI unit question Reply with quote
on my 93 nsr 125r the spark is rubbish and it wont start off the electric start and it takes ages to bump off could it be the cdi causing the rubbish spark or is it more to do with the ignition coil but if it was the cdi causing the rubbish spark wouldnt the rest of the electrics be rubish and not work properly please help as im unsure cheers and also the spark plug is like a sutty carbon colour Thumbs Up
alains
PostPosted: 11:01 - 30 Mar 2006    Post subject: Reply with quote
how can you say that your spark is rubbish ?
all ignition probs come from a lack of maintenance :
- worn plug
- clogged or dirty carb
- oil pump not adjusted
- dirty air filter
and rarely worn plug cap or ignition coil . also a bad process of starting .
i suggest : clean tank (fuel line) , air foam filter , carb , fit a BR9EIX plug . check the ignition as shown in my file https://www.geneva-racing.com/~alains/NSRtips.doc
to start :
- choke on , no acceleration
- start , let it run until it begin to stuff
- put a bit of acceleration (around 2000 rpm) and take choke off
- let it like that for 2-3 mn
then your engine must stay à 1400 rpm (+- 100)
PostPosted: 11:10 - 30 Mar 2006    Post subject: Reply with quote
To go with the above, what condition is the battery in?
While a cdi unit can fail like that, more often they just stop working altogether.
lee125
PostPosted: 11:45 - 30 Mar 2006    Post subject: Reply with quote
hi i took my bike round to my local mechanic and he has told me it is to do with the generator that 1 of the coils needs to be re-done so it is being sent off today i should have it back on tuesday or wednesday
lee125
PostPosted: 11:46 - 30 Mar 2006    Post subject: Reply with quote
and also i had already cleaned the carb and got a new plug checked the ignition coil and cleaned the petrol tank filter in the tap cheers and also the air filter Thumbs Up
alains
PostPosted: 13:52 - 30 Mar 2006    Post subject: Reply with quote
in case i've got here 2 stators (1 is nearly new) if you've got prob , send me a pm (it can be delivered within a week)
lee125
PostPosted: 16:00 - 01 Apr 2006    Post subject: Reply with quote
i got my generator thing back today after the ignition bits had been re-done and the spark is better but the bike still wont fire up and the carb has just been cleaned so petrol is getting there and the bike is sparking so i dont know wot could be causing this please help Thumbs Up
NSR Mick
PostPosted: 16:06 - 01 Apr 2006    Post subject: Reply with quote
Bad compression? Is it due a rebuild?
bish777
PostPosted: 16:07 - 01 Apr 2006    Post subject: Reply with quote
check in this order:
Battery
Coil
alternator
Ignitor (often wrongly called the CDI)
most likely you've got a shagged battery-if the battery is marginal, the draw of the started will drop the voltage enough to make the ignition box malfunction.
GSXR1100J
lee125
PostPosted: 16:08 - 01 Apr 2006    Post subject: Reply with quote
how can you test if the compression is rubbish as i dont have a gauge Thumbs Up
lee125
PostPosted: 16:09 - 01 Apr 2006    Post subject: Reply with quote
how do you check if the battery is nackered Thumbs Up
bish777
PostPosted: 16:25 - 01 Apr 2006    Post subject: Reply with quote
ask a car owning pal to jump your bike from their car, put jump leads from negative to negative, positive to positive, taking car not to touch the positive lead against the frame.
If the bike starts easily, its a good indication that your battery is knackered.
if you have a voltmeter check the voltage. fully charged is 12.7 volts or thereabouts. 11.9 volts is discharged and anything below that means the battery is faulty.
GSXR1100J
lee125
PostPosted: 17:52 - 01 Apr 2006    Post subject: Reply with quote
hi i checked the compression and it was fine and the battery is fully charged so i got a new spark plug b4 and it was sparking brilliant so i put it together on the bike but when i try using the electric start it doesnt start but if you bump it it starts but its not reving properly it slowly revs to 7000rpm then wont go any higher thenit just dies and then if u try 2 start it with the electric start it almost fires up but then wont i think it might b the choke cable sticking but im not sure could that cause this cheers Thumbs Up
lee125
PostPosted: 19:57 - 01 Apr 2006    Post subject: Reply with quote
found out its not the choke cable sticking i dont think its getting fuel to the cylinder but i have cleaned the fuel line and the carb any ideas wot else could be causing the petrol not to get to the engine cheers Thumbs Up
NSR Mick
PostPosted: 21:22 - 01 Apr 2006    Post subject: Reply with quote
Blockage from the tank, does the fuel flow from the tap ok?
lee125
PostPosted: 21:41 - 01 Apr 2006    Post subject: Reply with quote
yeah the fuel flows out fine Thumbs Up
bish777
PostPosted: 02:00 - 02 Apr 2006    Post subject: Reply with quote
just because a battery charger says "Full" doesnt mean the battery works properly.
GSXR1100J
lee125
PostPosted: 11:11 - 02 Apr 2006    Post subject: Reply with quote
the battery is reading around 12.7
meooo
PostPosted: 11:14 - 02 Apr 2006    Post subject: Reply with quote
Check the fuse/fuse holder......my sons nsr had probs starting/running & electrical probs recently & the fuse holder and cables had parted company (corroded) new fuse & holder fixed in 5 mins.......could be you spark problem too.
The last post was made 19 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 98.87 Kb
