Seats, again...
mr.z
PostPosted: 01:00 - 05 Apr 2006    Post subject: Seats, again... Reply with quote
Ello all..
Theres been a few threds about it but not been able to find it.. there was a link to a guide to recarveing your seat, foam types to use e.t.c. i'm getting the pan soon and have an inexhaustable supply of vynl to cover it (probably will end up doing it half a million times Razz)
Two things i want to do with it..
1.Couple of points are two hard, ends up like being sat on a plank after 100miles, same area every time.. i think the foam is pretty much knackered, so will be replaceing most of it with better stuff and glueing with gluegun..
2.Rear seat could do with being a bit more stepped, mere hint of a hill or fast stoping and my girlfriend ends up slideing towards me Laughing
0ddball
PostPosted: 01:27 - 05 Apr 2006    Post subject: Reply with quote
Theres a bit on it here https://motorcyclistonline.com/howto/cut_motorcycle_seats/
carrie78
PostPosted: 02:16 - 05 Apr 2006    Post subject: Reply with quote
Let us know how you get on with the seat. My partner has an ST1100 but I can't reach the floor properly. I was going to get a second hand seat to mutilate. I figured I could lose an inch or 2 of padding out of it. I don't have a limitless supply of PVC so have to try not to mess it up too many times. Any tips would be welcome.
Thanks
Carrie
Nath
PostPosted: 10:48 - 05 Apr 2006    Post subject: Reply with quote
I read somewhere on the ratbike zone about making seats, maybe recently.
What was said was to use foam off an old soafer or something, but to have it twice as high as you want the seat to be. Then you compress it hard onto your base and wrap gaffa tape around and around so holding it in position, and also allowing you to "mould" the foam into your chosen shape. When done you cover it in your vinyl, and nobody is to know that there's half a roll of gaffa tape under there Thumbs Up
Where did you get your vinyl from out of interest? I will be making a rider-only seat for my 550 sometime soon, but haven't sourced either the foam or the vinyl.
Hard livin', hard luck.
map
Mr Calendar
PostPosted: 11:02 - 05 Apr 2006    Post subject: Re: Seats, again... Reply with quote
mr.z wrote:
...too hard, ends up like being sat on a plank after 100miles, same area every time.. ...
If you're doing the recover yourself I'd recommend getting a gel pack (or two) and putting that in. Will be better than foam (that basically compresses so you're sitting on the hard stuff anyhow). However, will add a little to the cost (but can you put a price on a comfy ride?)
HTH Thumbs Up
mr.z
PostPosted: 11:44 - 05 Apr 2006    Post subject: Reply with quote
Ahh great point..
I'd wandered into one of these equestiran shops and they had gel sadle covers (for £20!), they must be great to sit on! i dont know if they could be cut up though?? (completely forgot about that Razz ) wondering if it could be added without ended up with half a million bumps and creaces in the seat Sad
I'd read the ratbike zone thing too, tis what got me thinking about redoing mine, can't justify £200 getting somebody to do it..
Apparently, the foam they use in bikes tends to be crap, theres truff available (reconfoam,rcoverfoam, something like that) which is far better, + useing a harder foam on the base and softer foam to finish off is ment to work well.. Then there permiable and non permiable foam Confused (and semi permiable)
Carrie78- Makeing the seat narrower where your legs go when stopped will also help allot (as much or more than loping stuff off the top) i'm fugureing useing cling film it could be tested before the final covering Question
Thansk for the replys all Wink Thumbs Up
mr.z
PostPosted: 17:32 - 05 Apr 2006    Post subject: Reply with quote
Bugger.. well the shop that had the gel seat things dont have them anymore and has to order them in :/
Where abouts could i get gel pads ? Sad
Mrs Kickstart
PostPosted: 19:14 - 05 Apr 2006    Post subject: Reply with quote
Try https://www.ppseat.co.uk/ in birmingham the do recovering inculding the gel pads so they might sell you some on there own
Regards
C
Help fight the safety camera partnerships Twisted Evil -- www.pepipoo.com
The last post was made 20 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 59.39 Kb
