2004 636 forks and rear shock ----> 2004 Z750
byke95
PostPosted: 16:46 - 07 Apr 2006    Post subject: 2004 636 forks and rear shock ----> 2004 Z750 Reply with quote
Hi,
I'd like to, over time, source some USD forks and better rear shock for my Z750. I've guessed that the parts from a 2004 ZX6R could be a good match to the 2004 Z750. I am aware that some alterations would be needed although I'm not sure what these may be...
I'm a fairly inept mechanic but would seriously like to consider doing this, can someone tell me:
Arrow What would be involved (parts needed, man hours etc.)
Arrow What could go wrong
Arrow Anything else that a skilled person would think of that I haven't! Embarassed
(also, if you live in the Dorset area and are skilled enough to undertake a project like this - and would like to - please let me know, I'd be happy to pay for your time)
Thanks for the help, I appreciate this is a bit of a big question! Thumbs Up
Cheers,
Phil
PostPosted: 09:34 - 08 Apr 2006    Post subject: Reply with quote
Right,
You'll need to check that the headstocks of both bikes are the same size, cos then you can just do a straight yoke swap.
I have heard, for example, that it is possible to transplant an entire Gixxer 1000 front end onto an SV650, but you need to get the Gixxer steering shaft machined, and some spacers for the bearings or something.
What you must keep in mind is that bikes are not like lego, they are not all designed to have mix and match parts!
The rear shock would probably fit without too much of an issue.
Personally, I'd sell the Z750 and get a Z1000 before messing about with USD forks from other bikes.
Plus the ZX636 forks and shock are reputed to be extremely harsh for road riding. Add that to a steel spine frame for which they were not designed, and you may have a recipie for tankslappers, or you could damage the frame in some way.
You really do need to know what you are doing before you start a project like this. A good thing to do would be to find a Z750 forum and see if anyone else has already done it. That will take away the element of guess work.
Personally, I think if you are unsure about doing the work yourself, then you'd be better off selling the Z750 and buying a Z thou. Karma
PostPosted: 09:36 - 08 Apr 2006    Post subject: Reply with quote
https://www.motocicliste.net/moto/z1000/KAWA_Z1000_arancio.jpg
(just to prove to myself that the Z1000 does in fact have USD forks! Smile )
byke95
PostPosted: 12:15 - 08 Apr 2006    Post subject: Reply with quote
Thanks MarJay, that's really helpful stuff! Thumbs Up
Thinking I think I'll just go down the route of upgrading the suspension with trusted, straight swapping, aftermarket parts.
I'll be getting a Thou next year some time (I've only just bought the Z750), I'm thinking the Tuono, Z1000 or Buell (that's as long as I don't hear that yours has gone kaboom! Mr. Green )
Thanks again!
Phil
zenodamper
PostPosted: 00:11 - 09 Apr 2006    Post subject: Reply with quote
Why not just simply upgrade the shimming and valving of what is already there...? Like, why dump the stuff and exchange to unknown starting points, when what is there can be improved very easily??
byke95
PostPosted: 11:56 - 09 Apr 2006    Post subject: Reply with quote
Very good point, loads cheeper!!
bish777
PostPosted: 14:56 - 09 Apr 2006    Post subject: Reply with quote
I'm swapping an entire 1998 fireblade front end onto my 1986 GSXR7/11.
What you need to do is take the bottom yolks from your 750 set and your ZX636, and have the stem from the 750 pressed out and then pressed into the ZX636 yolks. Use Z750 head bearings and bobs your uncle! the entire ZX636 end should fit on. You may need to modify lockstops.
GSXR1100J
The last post was made 20 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 55.04 Kb
