help my nsr broke down :( (update)
code guru
PostPosted: 17:09 - 10 Apr 2006    Post subject: help my nsr broke down :( (update) Reply with quote
ok well woz gona take the gearbox oil i bought from the shop back as i bought the wrong one so i took my bike out in the garage. started it up and left it 2 warm up for about 3-4 min then i left my drive way . well i stoped for a sec 2 speek 2 my mum then i left again. toped at the end off the road then pulled out, as i whent round the corner my back wheel locks up and my bike cut out. pushed it 2 the side and it wouldnt start, when u try and start it u can hear the startor motor go lick click once and thats it. its not turning, does this mean my piston has seized? i can just about push the bike 2 try and bump start it Embarassed
thanks for any help
oh yer its got an immobiliser but i dont think it will be that.
finpos
PostPosted: 17:15 - 10 Apr 2006    Post subject: Reply with quote
Sounds exactly like a seizure for sure.
The fact it's hard to push now also suggests it's towards the completely buggerated end of the seizure spectrum. Sorry!
finpos.
code guru
PostPosted: 17:20 - 10 Apr 2006    Post subject: Reply with quote
finpos.
its only hard 2 push when its in gear. when its not in gear its fine. well that means i will have 2 buy a new 125 kit and do it my self
yaut
PostPosted: 17:26 - 10 Apr 2006    Post subject: Reply with quote
My nsr broke down today too. Neutral I hear starter relay click after I push the start button, but starter motor doesn't turn over...
I drove it yesterday for more than 300km, was ok when I left it in evening. And now the bike just doesn't want to start for me. I packed my stuff, put all the gear on, went outside to the bike and couldn't go anywhere! Have all day-off ruined. I'm so mad that I'm getting another bike tonight Smile CBR250 Wink (I must be mental not just mad).
all dogs go to heaven
finpos
PostPosted: 17:29 - 10 Apr 2006    Post subject: Reply with quote
code guru - when it's not in gear, the engine's not spinning. that's the important clue!
Try agin once it's all cooled down. If not better, then it's probably engine in bitts time. I hope you bearings are ok.
finpos.
code guru
PostPosted: 17:31 - 10 Apr 2006    Post subject: Reply with quote
my stator motor clicks but it muct make that noise as it cand turn the crank as the piston is siezed Sad
code guru
PostPosted: 17:33 - 10 Apr 2006    Post subject: Reply with quote
finpos.
yer true
but when its in gear i can push it but i mean the bike is heavy and i aint strong .lol i hope its just the top end, gona take the 190 kit off 2moro and check
i whanted a 125 anyway so i dont mind changeing it 2 a 125
3806danny
PostPosted: 17:34 - 10 Apr 2006    Post subject: Reply with quote
how much did you pay for it?
veeeffarr
finpos.
yer true
There's your problem then :S
code guru
PostPosted: 17:37 - 10 Apr 2006    Post subject: Reply with quote
swaped it for my dna 125, straight swap so i am kind fucked coz my rieju is off the road and now my nsr. o well dont need it till sat but i am going on holiday so i only need the bike for one day but i can use the bus for that one day
finpos
Hit the nail on the head there - if you were lucky it might have been a partial seizure and some brute force (bump starting) may have freed it up and you could then remain blissfully ignorant of any damage to the bore/rings.
But because it's still resisting, you've probably melted something really quite badly. Look on the bright side - it's not completely seized, so you won't have to cut anything to get it apart!
finpos.
code guru
PostPosted: 17:41 - 10 Apr 2006    Post subject: Reply with quote
finpos wrote:
Hit the nail on the head there - if you were lucky it might have been a partial seizure and some brute force (bump starting) may have freed it up and you couldthen remain blissfully ignorant of any damage to the bore/rings.
finpos.
so wot u trying 2 say is it could just be the top end? well the top end is easy 2 change but were do i get a new 125 kit for my nsr? like dealers would whant like £200+
well i hope its just the top end and not botom. top i can do but i wouldnt touch the botom
veeeffarr
PostPosted: 17:44 - 10 Apr 2006    Post subject: Reply with quote
I'm no expert but surely if it's a 190 the barrell has been bored out? Surely that's a new engine jobby or can you get a 190 barrell sleeved down?
finpos
PostPosted: 17:46 - 10 Apr 2006    Post subject: Reply with quote
I wouldn't count on not having to do the bottom end if I were you. You won't know for sure until it's in bits.
Toby - hopefully, the 200 quid kit includes a new barrel, head, piston rings and gaskets. Unless the NSR has an integrated barrel, then you're stuffed.
Happy Easter etc Smile
finpos.
code guru
PostPosted: 17:48 - 10 Apr 2006    Post subject: Reply with quote
well its got an athena 190 kit that woz bought from stan stephens and the kit woz bought on the 15/09/05 and it had a new 190 piston fitted or bought on the 11/01/06
code guru
PostPosted: 17:52 - 10 Apr 2006    Post subject: Reply with quote
finpos.
well gona take the top off 2moro and check it out and when i go on holiday gona take it 2 my dads mates garage and get the botom end checked then and get the fork seals changed at the same time. would it just be cheaper if i bought another enghine and sell the bike? lol
finpos
PostPosted: 17:54 - 10 Apr 2006    Post subject: Reply with quote
Surely not another case of "oversize piston kit badly fitted to knackered bottom end given 6 months to live" syndrome? Wink
finpos.
code guru
PostPosted: 17:56 - 10 Apr 2006    Post subject: Reply with quote
well who ever fitted the 190 kit must be a dumb ass lol but i am a dumb ass for swaping my fine running dna for it. o well i prefer the nsr over the dna anyway
3806danny
PostPosted: 18:06 - 10 Apr 2006    Post subject: Reply with quote
try mixing 2 stroke in the petrol?
code guru
PostPosted: 18:08 - 10 Apr 2006    Post subject: Reply with quote
??????? i did put a bit off 2t oil in my tank but i filled up as well but surely that wouldnt cause it
3806danny
PostPosted: 18:22 - 10 Apr 2006    Post subject: Reply with quote
have you taken it apart yet?
code guru
PostPosted: 18:24 - 10 Apr 2006    Post subject: Reply with quote
na will do it 2moro as i aint got the room in my garage yet. my sis bike is in there and i cane be asked 2 move her bike so i will do it 2moro. gona try and bump start it now tho
3806danny
PostPosted: 18:30 - 10 Apr 2006    Post subject: Reply with quote
hows the sp 125?why dont you use that?
code guru
PostPosted: 18:31 - 10 Apr 2006    Post subject: Reply with quote
sp is running fine. reason i aint useing the sp is coz i aint insure on it, might transfare my rieju insurace over 2 it but i dont think my sis would whant me 2 ride her bike plus i dont realy like runners
code guru
PostPosted: 21:05 - 10 Apr 2006    Post subject: Reply with quote
does any 1 know were 2 drain the water in the enghine from????
as i am gona take the top end off 2 c if its ok and some 1 is selling a second hand 125 kit for £65 incl postage
The last post was made 19 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 125.53 Kb
