Tyre cracking
Barney
PostPosted: 13:34 - 11 Apr 2006    Post subject: Tyre cracking Reply with quote
I've never really had any confidence in my front tyre, Dunlop K505f but moneys tight and can't afford a new tyre Sad
Since the roads have dried up I've noticed these cracks appearing on the tyre and where it joins with the rims.
Is this serious and what causes it? I know its going to need a change, but how soon?
https://i32.photobucket.com/albums/d7/barney2006/Tyrecracking.jpg
CG125|CB400SF|CBR600FX|Triumph Daytona T595|CBR929RR
Jack_Cheese
PostPosted: 14:03 - 11 Apr 2006    Post subject: Reply with quote
That's pretty serious. Smaller cracks are no problem, but they look huge, and your tread is low anyway. Get it changed as soon as you can. My front is cracked, but not to that extent.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
mr.z
PostPosted: 14:08 - 11 Apr 2006    Post subject: Reply with quote
They look knackered Shocked
Is it kept outside? i think the sun can do this to them maybe.. but more likely age and wear.. or maybe its been over/under inflated at some point?
My front tyre is about 7 years old (it had been not runing for a fair few years) and looks a hell of allot better than that!
Think of it this way, your tyres are the only thing in contact with the road, have one fail suddenly and you'll know about it Thumbs Down
Barney
PostPosted: 15:09 - 11 Apr 2006    Post subject: Reply with quote
Ok, bit of a wake up call that, its due a service so I'm sure they will mention the tyre condition. Its just funny how quickly the cracks appeared within a week.
Yeah it is kept outside mr.z usually with a cover though.
Cheers.
Jack_Cheese
PostPosted: 15:15 - 11 Apr 2006    Post subject: Reply with quote
If it's stood for a while, even out of the sun, the tyre will crack. It just loses its flexibility...
Jack
Wooly R6
PostPosted: 15:52 - 11 Apr 2006    Post subject: Reply with quote
how longs the tyre been on - looks like a good two years or so!!! i would change it asap if it was my bike!!!! Thumbs Up
better safe than sorry
ps - read the thread about having a blowout!!!!
R6 has been sold - 2004 Honda VFR VTEC now sold too - no bike at the moment
GearboxGeezer
PostPosted: 15:57 - 11 Apr 2006    Post subject: Reply with quote
Id change them, even if it means not having cash to spend on other things. Id rather spend money which I havnt got on a tyre than spend money I havnt got repairing a smashed up bike due to having a blow out going round a courner...
Barney
PostPosted: 16:07 - 11 Apr 2006    Post subject: Reply with quote
Not exactly sure how long, obviously too long.
So can I just turn up at a somewhere like 'quick fit' and get them to sort it? How much are they likely to charge?
Barney
PostPosted: 16:33 - 11 Apr 2006    Post subject: Reply with quote
Also does anyone have any experience with BT45s or BT92s? Which is the better one for long motorway milage and the occasional weekend blast.
Cheers.
Redd
PostPosted: 17:29 - 11 Apr 2006    Post subject: Reply with quote
Easist thing to do is remove the front wheel and take it along to a bike garage and have them fit it and balance it to the loose wheel. If you don't have another form of transport, you'll probably have to ride there and pay a bit extra for them to remove the wheel.
Make sure they've got the tyre you're after and don't just turn up. I had to order in the BT45s I fitted to my XJ600n which took a few days. Once fitted and scrubbed in they were so much better than my old squared off ones. Now the bike doesn't scare the shit out of me when I go over cats eyes too Thumbs Up
Alternately, you could just buy the tyre and fit it yourself, but I wouldn't attempt that myself, I'd have to get some help...and we wouldn't be able to balance it either.
My BT45s were about £160 for the pair, but can't recall exactly what size. Something in the region of 110/70 17R for the rear if memory serves, so not huge tyres by any measure. That was fitted to loose wheels I brought with me in the car.
Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike
Barney
PostPosted: 17:38 - 11 Apr 2006    Post subject: Reply with quote
Ok, thanks for that Redd. So its ok to remove the front wheel on the centre stand and balance it out after? *EDIT* thats confusing, I will need a paddock stand right?
I'll order the BT45 from mandp, its 110/70/17 for the front so it only costs about 60 pounds.
Redd
PostPosted: 17:51 - 11 Apr 2006    Post subject: Reply with quote
If you've got the bike on the centre stand and take the front wheel off, the bike will fall since it leans on the front wheel. What we did (I say we, it was mostly Banditshigh that did the work Thumbs Up ) was put the bike on the centre stand then put a couple of axle stands under the frame at the front to support the weight. Tricky on your own I'd imagine, might want someone else there to help make sure the bike doesn't fall.
Yeti
PostPosted: 18:11 - 11 Apr 2006    Post subject: Reply with quote
I was running the same tyres up untill about 10 minutes ago. Just got in from fitting a set of D207's. But exactly the same things had happened to my set in the past week with all the good weather weve been having. Again i never trusted the tyre's they've got no grip at all, but they came fitted to the bike so i thought may aswell run them out as im not gonna be pushing the bike in winter. But as soon as i saw the cracking i ordered a new set and they were on within 3 days and i would advice you to do the same, but from the posts above that looks like what your gona do.
Regards Rob
Lifes a Beach!
colin1
Captain Safety
PostPosted: 18:16 - 11 Apr 2006    Post subject: Reply with quote
check your tyre pressure
low pressure puts more strain on the tyres, cracking them
i had this on a front tyre on an rs125
craigs23
Mr Muscle
PostPosted: 19:55 - 11 Apr 2006    Post subject: Reply with quote
BT92s would be better between the two. If it was my choice, I'd opt for an 090 front and a 92 rear - good front end grip, but with durability too.
bazza
PostPosted: 20:09 - 11 Apr 2006    Post subject: Reply with quote
Cheers.
BT020s or Avon Azaros. Both are dual compound touring tyres ideal for m-way mile munching. The central portion is a harder compund than the sides which have the grippier compound.
Nath
PostPosted: 20:15 - 11 Apr 2006    Post subject: Reply with quote
You should always ring around, *because*...
... I paid about £125 for a pair of BT45s, including fitting to loose wheels. I'm not gloating, just pointing out how different places can charge drastically different prices for the same thing (and one place I rang wanted nearly £200).
The tyres on my 550 are at least 10 years old, and cracked to fuck (far more than yours). I'm not enjoying riding on them, but I don't want to shell out for new ones just yet. I'm not sure if there's any chance of the tyre leaking air with tubeless tyres, but I'd probably be more worried if mine weren't tubed.
Hard livin', hard luck.
craigs23
Mr Muscle
PostPosted: 22:56 - 11 Apr 2006    Post subject: Reply with quote
It's a 400, I'm not sure if the sports touring tyres will ever get up to a nice enough temperature on a smaller bike. (They're Z rated - for machines of 600cc +). I had a few confidence issues when I thought fitting D207s to my RVF would be a good compromise between grip and durability. Was fine for the longevity, lasted 3,000 miles (well before their use by date) before I ditched them for H-rated GPRs (which offered an immediate improvement (and are also dual compound)).
Barney
PostPosted: 17:08 - 12 Apr 2006    Post subject: Reply with quote
Thanks for replies. What would I do without BCF? Rolling Eyes Smile
I've gone for the 090 on the front. Cheers Thumbs Up
The last post was made 20 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 105.61 Kb
