Carbon reeds for ns125r
puremagic72
PostPosted: 16:51 - 13 Apr 2006    Post subject: Carbon reeds for ns125r Reply with quote
hi all, just bought some carbon reeds for my ns125-r,.
Their flat, do they have to be put on flat as they are, as i'm sure when i had the reed block out, the original ones were slightly bent?
Thanks,
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
code guru
PostPosted: 17:24 - 13 Apr 2006    Post subject: Reply with quote
reeds r normaly flat, maybe coz yours r mettal they got bend as thhe open and close load off times, and they might brake soon so u might as well change them asap
puremagic72
PostPosted: 17:38 - 13 Apr 2006    Post subject: Reply with quote
Yeah mine are metal, but no-one beleives me that they are, so if their permanently bent, it means replacing?
And as the carbon ones are flat, i take it they open when needed?
Thanks for the quick reply code guru.
code guru
PostPosted: 18:31 - 13 Apr 2006    Post subject: Reply with quote
ok the reeds open when the piston goes down. carbon fiber one's open quicker than metal ones, the reed must be flat against your reed block but as yours a metal they might got bent because well when woz the last time u changed them? lol but they will open a lot quicker the carbon fiber ones so u will get a slightly better acceleration
bent reeds , i would replace them asap
puremagic72
PostPosted: 19:29 - 13 Apr 2006    Post subject: Reply with quote
Well i had the bike about 5 months now, and after a few days i noticed the inlet manifold was taped up, i took it off and there was a huge tear on both sides, i replaced that and decided to check the reed block and reeds, thats when i noticed they were bent.
The bike splutters at 5500rpm till 6000, then the power valve really kicks in.
Just wanted to stop that small splutter.
Thanks again,
0ddball
PostPosted: 20:19 - 13 Apr 2006    Post subject: Reply with quote
When you say slightly bent are you talking about the actual reed or the metal bit that stops the reed from bending too far as in this pic?
https://www.afrayspeed.co.uk/online_catalogue/ts1/reed_block.jpg
ProXimaCore
Dougal
PostPosted: 20:22 - 13 Apr 2006    Post subject: Reply with quote
You'll find that most NSRs do that in that part of the rev range. Nothing to worry about.
Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing Sad
puremagic72
PostPosted: 20:24 - 13 Apr 2006    Post subject: Reply with quote
Yes the actual metal part, that is slightly bent(reed).
Its nearly as bent as that, i take it its normal then.
But i have some carbon reeds i am fitting tomorrow anyhow.
Thanks,
ProXimaCore
Dougal
PostPosted: 20:29 - 13 Apr 2006    Post subject: Reply with quote
Thanks,
Those metal bits in that picture aren't the reeds. The reeds are smaller plastic things inside there if I remember right.
code guru
PostPosted: 20:30 - 13 Apr 2006    Post subject: Reply with quote
ok the reed its self must be straight the plate behide it is bent as the reeds open but u dont whant them 2 open 2 much coz they will snap other wise so thats y the back plate is bent but the reed its self should be straight
code guru
PostPosted: 20:32 - 13 Apr 2006    Post subject: Reply with quote
Thanks,
yes mate the black part is the reed the gold/silver mettal part is the stoper
ProXimaCore
Dougal
PostPosted: 20:34 - 13 Apr 2006    Post subject: Reply with quote
Oh yeah I can make it out now. Yeah those black flexible plastic bits are the reeds.
puremagic72
PostPosted: 20:44 - 13 Apr 2006    Post subject: Reply with quote
Ok, these are the reed petals(carbon) pic below. I have to replace the original steel ones which are in there(like in your pic,bent)
code guru
PostPosted: 21:19 - 13 Apr 2006    Post subject: Reply with quote
yep they r cabonfiber and i bet u bought them from ebay? lol
puremagic72
PostPosted: 21:59 - 13 Apr 2006    Post subject: Reply with quote
How did you guess???
code guru
PostPosted: 22:04 - 13 Apr 2006    Post subject: Reply with quote
seen a few on there but i didnt bid on them coz i didnt have an nsr at the time . lol
The last post was made 19 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 90.91 Kb
