Headlights
Rookie
PostPosted: 01:28 - 15 Apr 2006    Post subject: Headlights Reply with quote
Riding home from work tonight at about 10.30pm, I noticed that the dipped beam on my bike leaves a lot to be desired. I think this is a standard trait of the Thundercat?
Anything that I can do to improve it, without blinding people? Confused
derbisenda16
PostPosted: 01:47 - 15 Apr 2006    Post subject: Reply with quote
i take it you have the standard buld in there? If you have shop around for a halogen bulb..Ebay i think may have a few. Ive been told tey can improve lighting 8 fold.
tatters
Exxon Valdez
PostPosted: 01:51 - 15 Apr 2006    Post subject: Reply with quote
The headlights on the Thunderace are crap too, a common fix which l have done is to fit a higher wattage halgon lamps l went from the standard twin 35w to twin 65w ones.
Rookie
PostPosted: 02:26 - 15 Apr 2006    Post subject: Reply with quote
Just got in from a quick blast to get a kebab. Mr. Green
Tell you something, those are getting changed ASAP. 120mph with full beam on was just plain scary, I could not see far enough ahead. Thank God I knew the road, and that is was perfectly straight.
quacker_boy
Cuddle Bitch
PostPosted: 07:57 - 15 Apr 2006    Post subject: Reply with quote
Any excuse eh? Laughing
Halogen bulbs mate, just fitted some to my bandit just because i liked the bluey tinge. The area lit up by my full beam lights is MAHOOSIVE!
tonyyzf
PostPosted: 08:42 - 15 Apr 2006    Post subject: Reply with quote
Confused A Kebab? were you riding drunk, or do you actually like Kebabs when you're sober??? Confused
MRX Steve
PostPosted: 11:27 - 15 Apr 2006    Post subject: Reply with quote
Would a more powerfull bulb work in my mrx50 as i have the same problem? It doesnt have a battery
Rieju MRX 50 Castrol Edition
Fastgut
PostPosted: 11:32 - 15 Apr 2006    Post subject: Reply with quote
Euuuurgh. A kebab whilst sober........doesn't bear thinking about. Sick
Was a driving instructor now working in Insurance
Bikes:2005 Speed Triple and 2004 FZ6 Fazer (now the other half's)
PostPosted: 11:36 - 15 Apr 2006    Post subject: Reply with quote
You shouldn't do this because it can bugger your bulbs, but with low beam on (so no other vehicles about) I often pull the 'pass' switch to hold high beam on as well.
This usually keeps both filaments of the bulb lit.
As I said, not reccomended though, because the bulbs aren't meant to take the increased heat for extended periods, though I haven't blown a bulb because of it yet.
Nath
PostPosted: 11:53 - 15 Apr 2006    Post subject: Reply with quote
Are you sure the headlamp aim is correct? If it's set too low your lights will not point far enough up the road to see where you're going. If it's set too high your lights will dissapear into the blackness, again meaning you can't see very much.
Always try the simple thing first Smile
Hard livin', hard luck.
derbisenda16
PostPosted: 12:21 - 15 Apr 2006    Post subject: Reply with quote
is it just be or does everyone just keep repeating the previous post? Confused
The last post was made 20 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 68.37 Kb
