Clutch
Bod
PostPosted: 09:59 - 13 Apr 2006    Post subject: Clutch Reply with quote
Hi all I have an RSV Mille and have noticed that when I pull the clutch in the rear wheel still spins round rather than completely stop. Thus suggesting that the clutch is not disengaging fully is this common on bikes or do I have to adjust something?
Bod
Davo
Davo To The Rescue!
PostPosted: 11:08 - 13 Apr 2006    Post subject: Reply with quote
I assume this is when the bikes rear wheel is off the ground?
Although I'm not too sure on the Mille's.
Usually their are two sets of adjusters to check, one is by the clutch lever, and the other is usually down by where the clutch cable disappears into the engine cover.
Just adjust the cable a little bit at a time. Be careful though not to adjust it so much that the clutch starts slipping.
Have you changed the oil recently? I noticed when I changed my R6 from fully synthetic oil to semi-synthetic oil I noticed the rear wheel would spin slowly with the clutch disengaged (and in neutral), just put this down to fluid drag.
Bod
PostPosted: 11:12 - 13 Apr 2006    Post subject: Reply with quote
Hi there thanks for the input. The mille is hydraulic controlled so there is no cable......at least I think not lol. I've just bled the system and cleaned the oil out and its still spinning quite quickly.
Crying or Very sad
Redd
PostPosted: 19:38 - 13 Apr 2006    Post subject: Reply with quote
Mine does this too and I put it down to fluid drag. If the wheel is stationary and off the ground it won't spin with the clutch in...but if you start it moving it won't stop. There's enough force to keep it going but not enough to overcome it's inertia. Wouldn't worry about it so long as it's not turning on the ground Thumbs Up
Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike
Bod
PostPosted: 23:01 - 13 Apr 2006    Post subject: Reply with quote
Yep, no problem there then. Thanks for your help guys.
Bod
Rookie
PostPosted: 02:16 - 14 Apr 2006    Post subject: Reply with quote
I would have said this is fairly normal? Confused I haven't had the Cat on a paddock stand yet, but I remember on the centre stand, the (automatic) ped's rear wheel would always spin slowly. Never gave it a 2nd glance! Embarassed Laughing
3806danny
PostPosted: 10:18 - 14 Apr 2006    Post subject: Reply with quote
my rear wheel spins on the stand as
well
simon1221
PostPosted: 23:10 - 15 Apr 2006    Post subject: Reply with quote
The driving school CG done that as well. Idea
Bod
PostPosted: 12:02 - 16 Apr 2006    Post subject: Reply with quote
Looks like most bikes do it thankfully.
Cheers for all that replied.
Bod
biggaz
PostPosted: 20:52 - 16 Apr 2006    Post subject: Reply with quote
mine turns on center stand aswell bod, i put it down to the mice not knowing if its on the stand or not Smile
The last post was made 20 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 61.91 Kb
