| greatmoorred |
 greatmoorred Nearly there...
| SimonB |
 SimonB Brolly Dolly
| Guest |
 Guest Brolly Dolly
 Posted: 12:08 - 17 Apr 2006 Post subject: |
Not if it's hydraulic
If it's cable operated, check the routing of the cable to make sure it's not trapped or kinked, and lube it well.
Also check that the throwout mechanism at the gearbox end isn't clagged up with chain gunge. |
| edd |
 edd Nearly there...
 Posted: 00:56 - 18 Apr 2006 Post subject: |
have you recently lubricated the clutch cable? If not, get a small bag, poke a hole in it and put the cable through. Then seal the bag with an elastic band onto the cable outer. Fill this bag with oil while you move the cable in and out. when oil strats dripping out of the other end of the cable it will be properly lubed. ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| mr.z |
 mr.z World Chat Champion
 Posted: 02:03 - 18 Apr 2006 Post subject: |
much better is graphite spray (or other cable lube spray, i have some and its gold stuff, works just as well), hard to find but well worth it, its graphite in a solvent, it gets right down the cable and it stays there unlike wd40 or oil which will eventually just fall out.. when you get a new cable/speedo, if possible take the inner part out, copper slip + high melting point grease it up, cable lube if you have it though... then fit it, lasts a hell of allot longer  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| ZRX61 |
 ZRX61 Victor Meldrew
The last post was made 20 years, 181 days ago. Instead of replying here, would creating a new thread be more useful? |
