clutch lever too tight.
greatmoorred
PostPosted: 11:48 - 17 Apr 2006    Post subject: clutch lever too tight. Reply with quote
Anyone else suffer from the clutch being a bit on the tight side ?
After a run out my left wrist is stiff from pulling in the lever.
Can i adjust this at the handle bars ?
SimonB
PostPosted: 11:52 - 17 Apr 2006    Post subject: Reply with quote
Any chance that your clutch cable is on its way out?
Bikes: Honda CBR250RR [sold], Yamaha FZR600 [sold], Honda CBR600RR6
Guest
PostPosted: 12:08 - 17 Apr 2006    Post subject: Reply with quote
Not if it's hydraulic Wink
If it's cable operated, check the routing of the cable to make sure it's not trapped or kinked, and lube it well.
Also check that the throwout mechanism at the gearbox end isn't clagged up with chain gunge.
edd
PostPosted: 00:56 - 18 Apr 2006    Post subject: Reply with quote
have you recently lubricated the clutch cable? If not, get a small bag, poke a hole in it and put the cable through. Then seal the bag with an elastic band onto the cable outer. Fill this bag with oil while you move the cable in and out. when oil strats dripping out of the other end of the cable it will be properly lubed.
Bluespark Automotive - Diesel Tuning for Performance and Economy
mr.z
PostPosted: 02:03 - 18 Apr 2006    Post subject: Reply with quote
much better is graphite spray (or other cable lube spray, i have some and its gold stuff, works just as well), hard to find but well worth it, its graphite in a solvent, it gets right down the cable and it stays there unlike wd40 or oil which will eventually just fall out.. when you get a new cable/speedo, if possible take the inner part out, copper slip + high melting point grease it up, cable lube if you have it though... then fit it, lasts a hell of allot longer Wink
ZRX61
Victor Meldrew
PostPosted: 16:27 - 18 Apr 2006    Post subject: Reply with quote
Actually they'l both turn into glue after a while when they mix with dirt..
The last post was made 20 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 47.56 Kb
