Clunking From Rear Wheel
WildGoose
White Van Man
PostPosted: 11:44 - 18 Apr 2006    Post subject: Clunking From Rear Wheel Reply with quote
right, this one has baffled me a bit, although the fix should be simple, its totally eluded me
the rear wheel is clunking when turned by hand when the bike is up on a paddock stand
a sound that i would associate with a chain not meeting the rear sprocket quite online, but it isnt occuring every time a tooth engages with the chain, tis every 8 or so
the wheel is aligned with the same marks on both sides of the swingarm, i have tried adjusting it a few turns either way on both sides, but it doesnt seem to sort the noise
interestingly the wheel only makes the noise when the axle nut is done up, which makes it all the more frustrating trying to cancel out the errors by adjusting the chain tensioners, as you have to make the adjustment then do the axle nut back up to hear if its making the noise
seems too simple, but ive tried everything i can think of, and now need advice
thanks for any points Thumbs Up
finpos
PostPosted: 11:55 - 18 Apr 2006    Post subject: Reply with quote
You don't metion the age/milage/model of the bike..
My guess would be that the cush drive rubbers are past their best. See if you can bridge the gap between the wheel and the rear sprocket carrier with your thumb while making it clunk, though obviously that's a bit difficult if you need to whizz the wheel around to make it happen.
Probably also worth while looking for any play in the wheel bearings.
finpos.
WildGoose
White Van Man
PostPosted: 12:11 - 18 Apr 2006    Post subject: Reply with quote
96 yamaha trx 850, 30,000 miles
finpos
PostPosted: 12:28 - 18 Apr 2006    Post subject: Reply with quote
10 year old bike with that milage - probably worth taking the wheel of to check the rubbers.
The good news is that if they are a bit on the tired side, you can pack them out with strips of something rubbery. re-assemble/re-fit the wheel and re-test for your clunking. Personally, I'd never ride the thing another 20,000 mile with it in a bodged state like that Wink
finpos.
BanditsHigh
Worse than a woman
PostPosted: 13:39 - 18 Apr 2006    Post subject: Reply with quote
This might be a really stupid suggestion ... but have you checked your wheel/sprocket carrier bearings?
Also another cause of knocking could be a slightly warped disc hitting a set of loose brake pads ... every time the disc dips it'll hit the pads and cause a noise ... this is quite unlikely from what you've described.
Wheel bearings or sprocket bearing starting to go sounds the most likely.
All the best ... Barry
NSR Mick
PostPosted: 15:03 - 18 Apr 2006    Post subject: Re: Clunking From Rear Wheel Reply with quote
Doesnt mean a great deal to be honest.
Look to see if the the teeth on the sprocket are going into the chain straight, although it does sound like a duff bearing, does it occur at the same point every wheel revolution?
Vin
PostPosted: 15:16 - 18 Apr 2006    Post subject: Reply with quote
Don't shout at me but my bike did this....scared the life out of me! It turned out that the way I had positioned the stand meant the sprocket nuts were hitting it and making a clunking sound. Doh!
The last post was made 20 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 51.87 Kb
