Just wondering...
mattgt
PostPosted: 23:36 - 19 Apr 2006    Post subject: Just wondering... Reply with quote
me and my mate have just swapped exhausts. in the process, we decided to turn on the engines without any cans... the sound was amazing. my question: how exactly would this damage the bike? and, could this be replicated with some form of exhaust? twas truly a lovely moment... would love to do it again without breaking my bike!
Matt
-Savage-
PostPosted: 01:10 - 20 Apr 2006    Post subject: Reply with quote
my exhaust has a wee hole in the pipe at the minute, just before the connection for the can, and it sounds well sweet lol
i almost want to make it bigger rather than wield it up lol
mattgt
PostPosted: 02:09 - 20 Apr 2006    Post subject: Reply with quote
yeah, try taking off the whole can! the noise is so sweet Twisted Evil but my question is how much damage?
veeeffarr
PostPosted: 02:20 - 20 Apr 2006    Post subject: Reply with quote
Fuck all for just the once probably, heard of people removing the whole can including pipes before.
Wouldn't make a habit of it though, and presume it'd fuck a two stroke up pretty sharpish.
mr.z
PostPosted: 02:25 - 20 Apr 2006    Post subject: Reply with quote
A short ammount of time isn't a problem..
The exhaust restricts the air flow of the engine to a degree, takeing it off allows more thgough, which isn't a problem if your carbs are set up to add the extra fuel, otherwise its runing horribly horribly lean, which is extreemly bad.. (seizeing pistons e.t.c.) the other thing is it will run like shit because these not the right backpressure (a 2stroke would be at about half power or less, a four stroke will not be helped either)
A straight through pipe is just that, no obstruction, drain pipes.. thats as loud as you will get, shorter the louder, a mate had a trike that had stright through pipes (front end of a cx650) the noise peeled the enamel off your teeth, at idle it was noiseyer (the sound was lovely) open the throttle and say bye to your head.. it would oddly pass an mot without any trouble...
I had to change a seal on my transalp exhaust, that was the most impressive noise ive ever hered an engine make ever it was bootiful..
colin1
Captain Safety
PostPosted: 02:48 - 20 Apr 2006    Post subject: Reply with quote
i would have thought it would make the bike run lean so you could burn a hole in a piston if you did it long enough
but you could change the jetting so it was no longer running lean
veeeffarr
PostPosted: 02:53 - 20 Apr 2006    Post subject: Reply with quote
Would that really fuck fuel consumption though?
mr.z
PostPosted: 02:55 - 20 Apr 2006    Post subject: Reply with quote
Sure would Wink
Also mind the air needs to be getting through the filter too.. afaik if the pipe is too short air can be pushed back into the cylinder??
There are bikes that run with no filter, but probably not very often (or for very long)
colin1
Captain Safety
PostPosted: 02:56 - 20 Apr 2006    Post subject: Reply with quote
dunno
veeeffarr
I was thinking of sticking a K&N in my CG for a laugh, as there's a plastic cover on the airbox, which is then covered by the side panel...
mr.z
PostPosted: 03:00 - 20 Apr 2006    Post subject: Reply with quote
Toby R wrote:
I was thinking of sticking a K&N in my CG for a laugh..
Please dont Crying or Very sad Razz (allthough it has to be said it will run if you took it out completely or used an old pair of pants for a filter though, its that kind of bike..)
Generally airflow and filters and jeting are very far down the list of usefull cost efective power gaining methods (more or less the last thing after a big list of other things to do)
veeeffarr
PostPosted: 03:02 - 20 Apr 2006    Post subject: Reply with quote
Well my bike tops out at 60mph indicated (So prolly about 53mph) and should be going at least a tad faster than that...
I'm fucked for ideas as to what's wrong with it Razz
mr.z
PostPosted: 03:09 - 20 Apr 2006    Post subject: Reply with quote
I can safely say the cg will do an absoloute maximum of indicated 67, down a HUGE (like two mile) hill with a tailwind, and tats as fast as i'd like to make it go because it REALLY didn't like it!
A 125-4stroke twin will just about make indicated 70 apparently..
Been there done that, wihtout a licence an nsr125 will get you going faster reasonably relyably, otherwise its time to take a trip to the test center and ask nicely for one of them bits of paper Wink
veeeffarr
PostPosted: 03:15 - 20 Apr 2006    Post subject: Reply with quote
Waiting for tax office to give me my fucking money then test is getting booked! Smile
mattish
PostPosted: 11:52 - 20 Apr 2006    Post subject: Reply with quote
Had mine end of speedo (indicated 80) and was still pulling slightly Shocked
EDIT: just realised how offtopic that was, I want to try a large single with no can Cool
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 86.31 Kb
