vfr probs
john345453
PostPosted: 15:51 - 20 Apr 2006    Post subject: vfr probs Reply with quote
why wont my vfr 400 go above 8000 rpm? Sick
sickpup
Old Timer
PostPosted: 16:13 - 20 Apr 2006    Post subject: Reply with quote
NC24 by any chance?
Change the sparrk plugs and take out the restrictors.
john345453
PostPosted: 19:50 - 20 Apr 2006    Post subject: Reply with quote
any ideas how it would be restricted, ive heard its either a black box behind the clocks or washers in the carbs or exhaust. to be honest i wouldnt know what to look for cos im thick as shit.
john345453
PostPosted: 19:51 - 20 Apr 2006    Post subject: Reply with quote
its an nc 21
sickpup
Old Timer
PostPosted: 20:36 - 20 Apr 2006    Post subject: Reply with quote
Same engine and frame pretty much.
Not restricted unless its been 33bhp'd.
Ever been serviced?
john345453
PostPosted: 21:56 - 20 Apr 2006    Post subject: Reply with quote
it has been restricted to 33bhp supposedly but even so i would expect a ton from it and it has just had new plugs and carb clean.
sickpup
Old Timer
PostPosted: 23:09 - 20 Apr 2006    Post subject: Reply with quote
It won't do a ton, 90mph if you're lucky.
The NC21/24 react very badly to be restricted via the FI washers. From complete lack of power, very low top speed, starting problems to flooding and oiling plugs. As well as this your reg/rec will fry itself unless it has already been changed for a CBR600 one.
The restriction is washers in the inlet tract. There is no top speed restriction from the factory on an NC21 as this didn't appear on the 400's until 1989.
Just thought which NC21 do you have? the faired on unfaired with crash bars version?
john345453
PostPosted: 10:50 - 21 Apr 2006    Post subject: Reply with quote
its the faired version.
john345453
PostPosted: 10:53 - 21 Apr 2006    Post subject: Reply with quote
in neutral it will rev all the way. but as soon as your in gear 8000 rpm max. how difficult is it to remove these washers?
john345453
PostPosted: 20:19 - 21 Apr 2006    Post subject: Reply with quote
yet another symptom i go flat out about 75mph for about 2 miles then it starts shuddering and slowly dies so i pull over and just as im changing down gears to come to a halt it stalls. i ask myself wtf have i bought.
sickpup
Old Timer
PostPosted: 21:24 - 21 Apr 2006    Post subject: Reply with quote
You've bought a bike that doesn't take to restriction very well. Other than that I can't say.
Valentino Mossy
PostPosted: 21:28 - 21 Apr 2006    Post subject: Reply with quote
Do they have the same sort of restrictor box like the nc30 has ?
sickpup
Old Timer
PostPosted: 22:14 - 21 Apr 2006    Post subject: Reply with quote
No.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 03:20 - 22 Apr 2006    Post subject: Reply with quote
The CBR600 reg's aren't much better. Reason they fail less on cbr6's is because where they are doesn't get as hot. Better off getting an aftermarket finned item for around £60ish, or using one off another make of bike that has fins.
The Honda reg/rec replacement part now does have finns btw, but is fairly expensive.
DukeRed
PostPosted: 03:25 - 22 Apr 2006    Post subject: Reply with quote
https://www.400greybike.co.uk/Wksp-NC30Derestriction.asp
Might help.
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
john345453
PostPosted: 20:26 - 22 Apr 2006    Post subject: Reply with quote
just so i know what is the standard top speed like on these vfrs and should the revs climb quickly.
john345453
PostPosted: 20:30 - 22 Apr 2006    Post subject: Reply with quote
hate to sound stupid but what is an inlet tract?
EuropeanNC30R...
Gay Hairdresser
PostPosted: 20:31 - 22 Apr 2006    Post subject: Reply with quote
Standard I'd expect it to crack 120. Restricted, who knows, it's guaranteed to run crap though.
john345453
PostPosted: 20:39 - 22 Apr 2006    Post subject: Reply with quote
only 50mph off mark Crying or Very sad
The last post was made 20 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 94.08 Kb
