Tyre pressures
awj72
PostPosted: 23:47 - 18 Apr 2006    Post subject: Tyre pressures Reply with quote
Hi, just a quick question, what are "ideal" pressures for a '91 CBR600 FM? Can't find it in Haynes, unless I'm not looking right. Cheers guys
Woe to you, o earth & sea, for the devil sends the beast with wrath............
(my ebay clearout...... https://search.ebay.co.uk/_W0QQsassZawj72QQhtZ-1 )
byke95
PostPosted: 09:43 - 19 Apr 2006    Post subject: Reply with quote
You should be able to find a sticker under your seat (or maybe on the chain guard) that lets you know the recommended tyre pressure Thumbs Up
awj72
PostPosted: 14:24 - 20 Apr 2006    Post subject: Reply with quote
Ta. also can a puncture be repaired like a car tyre, or does it mean new tyre?? It's not a massive thing, just looks like a small panel pin type nail in the main face of the tyre, not in the tread. Ta again
Finglonga
PostPosted: 18:46 - 20 Apr 2006    Post subject: Reply with quote
Depends where the nail/screw/glass/dagger is in the tread. If its near the center of the tyre then you will be fine but at the edges then it may fail due to the flex in the sidewall.
Andy Sez....
F.Y.Y.F.F.
Rookie
PostPosted: 18:50 - 20 Apr 2006    Post subject: Reply with quote
Mine say the pressures on the tyre wall. 42PSI, front and rear.
Robby
Dirty Old Man
PostPosted: 20:24 - 20 Apr 2006    Post subject: Reply with quote
The pressures on the sidewall are the max pressures for the tyre, not the pressures to use.
Look for a sticker on the swingarm or look in the owners manual.
awj72
PostPosted: 20:35 - 20 Apr 2006    Post subject: Reply with quote
not in the side, it's right on the centre lilne. Cheers mate.
wondergirl
PostPosted: 00:42 - 01 May 2006    Post subject: Reply with quote
when i got a puncture they put a mushroom plug in it cost about £30 and i was told it was good up to 100mph.
numark1
Scared of girls
PostPosted: 00:51 - 01 May 2006    Post subject: Reply with quote
That sounds stupidly high. My last two bikes were 36-38 rear and about 32 front.
map
Mr Calendar
PostPosted: 01:02 - 01 May 2006    Post subject: Reply with quote
awj72 wrote:
...can a puncture be repaired like a car tyre...
As said depends on where and the tyre rating.
In the centre of the tread is ok.
However, if the tyre is Z speed rated then no, it can't be patched/plugged. That's not been funny, it's the law.
HTH Thumbs Up
numark1
Scared of girls
PostPosted: 01:06 - 01 May 2006    Post subject: Reply with quote
My friend had a z rated tyre plugged from a dodgy tyre place by a guy "on his lunch break" for £20. Did the job. Confused
Finglonga
PostPosted: 09:16 - 01 May 2006    Post subject: Reply with quote
HTH Thumbs Up
Probably sorted by now but......
Yep....depends where you go...some places won't touch it but others will ask if you still want it doing as is is a z rated tyre. Worth shopping around. Wink
Andy Sez....
F.Y.Y.F.F.
map
Mr Calendar
PostPosted: 11:08 - 01 May 2006    Post subject: Reply with quote
Finglonga wrote:
map wrote:
...if the tyre is Z speed rated then no...
...some places won't touch it but others will ask if you still want it doing...
Quite possibly true. However, if found out then they could get hammered (if anyone can be arsed with the paperwork Rolling Eyes).
However, worth bearing in mind if you have an off, even if the tyre was not to blame, and the insurance found it's been plugged when it shouldn't then they can invalidate your insurance. So if they do that then the police may take an interest in you riding without insurance, etc, etc.
Just some thoughts, probably pointing out the obvious Karma
Finglonga
PostPosted: 13:56 - 01 May 2006    Post subject: Reply with quote
Good point Thumbs Up , I just didn't want to fork out the money for another new tyre after the punctured one was only 2 days old. Evil or Very Mad
Summary: Ignore the bollox I posted in the above post unless your a tight Tawt like me. Wink
Andy Sez....
F.Y.Y.F.F.
Scorpius
PostPosted: 23:58 - 01 May 2006    Post subject: Reply with quote
Well my F(S) runs (correctly) at 36/42.
Cagiva Mito 125 (sold)
Honda CBR400RR NC23 (sold)
Currently riding: Honda CBR600F
The last post was made 20 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 87.61 Kb
