need help, calling all bikers...
Type_Mo
PostPosted: 22:04 - 20 Apr 2006    Post subject: need help, calling all bikers... Reply with quote
What bike have you got and what button do you have on your hand switches please.
Im after 1 that has all of the buttons on it if possible?
McGee
O RLY?
PostPosted: 22:07 - 20 Apr 2006    Post subject: Reply with quote
As in switchs on the grips.
My k5 gixer 6 has:
left:
Lights dip and high, Horn, trigger for flashing lights and blinkys oh and hazards.
Right:
Cut off and start.
Its pronounced Jixxer!
Type_Mo
PostPosted: 22:08 - 20 Apr 2006    Post subject: Reply with quote
That would be the simple way of putting it Razz Cheers mate
My DT:
Left:
Horn, Indicators, Lights on and off and Lights dipped and high beam!
Right:
Kill Switch
Chiz
PostPosted: 22:20 - 20 Apr 2006    Post subject: Reply with quote
Seems an odd Q but...
NSR125R:
LH: off, sidelight, dip beam (slidey thing)
Main beam button
'Flasher'
indicators
horn
RH: Kill switch
starter button
Rookie
PostPosted: 22:23 - 20 Apr 2006    Post subject: Reply with quote
Except for bikes without an electric start, and fancy things like heated grips, I've never seen it any different to the above posts.
Chiz
PostPosted: 22:25 - 20 Apr 2006    Post subject: Reply with quote
I think some BMW's have a switch for indicators on both sides, but apart from that...
MarkJ
PostPosted: 22:28 - 20 Apr 2006    Post subject: Reply with quote
My k5 gixer 6 has:
left:
Right:
Cut off and start.
That's what my 99 Hornet has, except there's no hazards and on the right above the start button is the light switch. The positions from left to right are: "Full" lights (determined by the full/dipped switch on the left handle), side-lights, lights off.
mr.z
PostPosted: 22:30 - 20 Apr 2006    Post subject: Reply with quote
Right, there is a soloution to this (if i'm getting what your after)
Mines
Left
Beam high/low
Indicators
Horn
Pass
Right
kill switch
start
lights/off/park/on
Now, you could do away with the kill switch, buy a barrel with start on it (like a cars) thats the start you dont need (or wire it to the pass button and paint it red and relable it), and hardwire the lights perminently on, so no need for the off/park/on switch.. so you can chuck the right hand switchgear.
Any reason why you only want one side? Razz
ZRX61
Victor Meldrew
PostPosted: 22:31 - 20 Apr 2006    Post subject: Re: need help, calling all bikers... Reply with quote
"ALL" of them? including theb ones that Gold Wings have for pumping the suspension up & down & volume etc for the stereo? Rolling Eyes
thx1138
PostPosted: 23:52 - 20 Apr 2006    Post subject: . Reply with quote
My headlight switch is on the headlight itself Shocked
the right handlebar has high / low beam switch, but it is an old bike, has electric start though.
Method
PostPosted: 00:26 - 21 Apr 2006    Post subject: Reply with quote
If i remember rightly, and i might be completely wrong...
But i remember Mo saying something about having trouble with one of his wrisits? (Sorry if this is wrong mate)
But yes like stated above you can hook up everything to one side if need be. Get a car style barrel or even get a remote start allarm / immobiliser Thumbs Up
However are the switches the only problem? If you have trouble with your wrists then are you also going to have trouble with either the brake or clutch? If so are you going to have to do a nice little mod to equip a double connection to the rear brake? Or clutch or something?
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Type_Mo
PostPosted: 00:35 - 21 Apr 2006    Post subject: Reply with quote
It was my hand that was hurting due to my very stiff clutch cable (which has been changed now)
And the hand switch is for my mates project bike.
Method
PostPosted: 00:39 - 21 Apr 2006    Post subject: Reply with quote
Ok mate - Sorry Wink
Type_Mo
PostPosted: 00:45 - 21 Apr 2006    Post subject: Reply with quote
no problem dude Wink ive changed the clutch cable twice now mate Laughing
veeeffarr
PostPosted: 00:46 - 21 Apr 2006    Post subject: Reply with quote
CG125
Left
Arrow Dip/Full Beam Toggle button, press lightly to flash lights
Arrow Indicator Button (Flick to ind. Direct, Push to Cancel)
Arrow Horn
Arrow Slide Switch that toggles between All lights/Dash light only/No lights
Right
Arrow Nothing!
What does a 'pass' button do by the way?
Method
PostPosted: 00:48 - 21 Apr 2006    Post subject: Reply with quote
Pass button is for flashing up random gay drivers that are annoying you in front.
Nah - Your pass light is basically a switch to your high beam - you are supposed to hold that as you overtake - makes your headlight brighter so that oncoming traffic can see you more Thumbs Up
mr.z
PostPosted: 01:04 - 21 Apr 2006    Post subject: Reply with quote
One thing though, dont make a habbit of useing it as they aren't wired to be used for more than a second or two at a time (both high and low beam at the time will cook the wire)
veeeffarr
PostPosted: 01:20 - 21 Apr 2006    Post subject: Reply with quote
Wow, never knew that.
Born2bVile
PostPosted: 03:21 - 21 Apr 2006    Post subject: Re: need help, calling all bikers... Reply with quote
It would help a lot more if you explained the reasons for needing everything on one side.
The list of interchangeable controls is endless now.
Cheers,
Byrnie.
NABD Treasurer
National Association for Bikers with a Disability
Reg Charity No. 1040907
McGee
O RLY?
PostPosted: 05:08 - 21 Apr 2006    Post subject: Reply with quote
I call it my trigger cause I pretend im shooting em down with the lights flashing Shocked
Funny when you make some one change lanes.
If cars were planes and my lights were guns I would be an ace by now Mr. Green
quacker_boy
Cuddle Bitch
PostPosted: 09:16 - 21 Apr 2006    Post subject: Reply with quote
Laughing Same, i used to love tail gating people and blasting the f**k out of them with my gun on the CBR Razz
Anyway:
Suzuki GSF250 Bandit
LH: Pass, Hi-Lo Beam, Indies and Horn
RH: Kill switch, lights on or off, starter button
Method
PostPosted: 11:07 - 21 Apr 2006    Post subject: Reply with quote
Mr.Z's got a point. Thing is i never use it for overtaking, because my lights are bright enough during the day anyway, and my green fairing is lovely and visible.
But when it gets dark enough to need to use it, ive got my main beam on anyway, because my lights are shite in the dark.
But yeah, thats what a pass light is for Thumbs Up
Wooly R6
PostPosted: 11:09 - 21 Apr 2006    Post subject: Reply with quote
My k5 gixer 6 has:
left:
Right:
Cut off and start.
same as on my 03 R6
R6 has been sold - 2004 Honda VFR VTEC now sold too - no bike at the moment
steveh
PostPosted: 11:21 - 21 Apr 2006    Post subject: Reply with quote
marauder:
Lh: main/dip beam, horn, indicator (l,r)
Rh: kill switch, starter, lights, side lights, off.
Steve Confused
Cillit-BANG
PostPosted: 11:41 - 21 Apr 2006    Post subject: Reply with quote
Surely most bikes have most of the controls on the left anyway. So if you only use the right hand controls to start the bike up and perhaps turn the lights on, why not just lean over with your left hand, seeing as you'll be sat still anyway Question If you can only use the right hand, I'm not so sure Exclamation
FWIW-
ZX6R Right
Arrow Starter
Arrow Kill Switch
Arrow Stopwatch Stop/Start
ZX6R Left
Arrow Full Beam
Arrow Pass flicker
Arrow Horn
Arrow Stopwatch 'Lap' button.
Arrow Indicator
The last post was made 20 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 135.89 Kb
