bandit 400
mark allsopp
PostPosted: 15:00 - 25 Apr 2006    Post subject: bandit 400 Reply with quote
sorry new to this
can anybody tell me how and to tell if bike is restricted and how to take it off if it is bike in question is a 400 bandit
phill.c
PostPosted: 15:16 - 25 Apr 2006    Post subject: Reply with quote
to do mean restricted to 33bhp?
CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed Smile
mark allsopp
PostPosted: 15:23 - 25 Apr 2006    Post subject: Reply with quote
yes i presume so because it's dog slow and i'm sure it should be faster than it is??????????????????
phill.c
PostPosted: 15:34 - 25 Apr 2006    Post subject: Reply with quote
what do you get out of it and does it go right in to the red on the rev counter, but saying that it might not be restricted and could be something else. on most restristor kits its four washers which go in the air intakes (i think thats right). the only real way of telling is either dyno or just have look to see if they are there.
a good place for advice for 400's is 400greybike.co.uk alot of them come on here too.
phill.c
mark allsopp
PostPosted: 16:01 - 25 Apr 2006    Post subject: Reply with quote
thanks for the info i will check it out
mark allsopp
PostPosted: 17:16 - 25 Apr 2006    Post subject: Reply with quote
Gazdaman
I did a trackday!!!
PostPosted: 17:47 - 25 Apr 2006    Post subject: Reply with quote
Derestricted I'd expect to see 120mph without too many problems.
Restricted I'd say you'd see about 100mph flat out, and you might find it doesn't pull top gear very well.
It'll be 4 metal washers in the inlet manifold, i.e 'behind' your carbs.
Gaz
JonB
Afraid of Mileage
PostPosted: 18:11 - 25 Apr 2006    Post subject: Reply with quote
You think :S
The Bandit 600 doesn't get much above that does it?
Gazdaman
I did a trackday!!!
PostPosted: 00:23 - 26 Apr 2006    Post subject: Reply with quote
I think our bandits must have strange gearing, because they do seem to have a low top speed for their power.
Either way, restricted should see around a ton full speed.
A VFR400 will do 135mph true speed, So I'd expect 120ish, indicated at least from the bandit.
Gaz
mark allsopp
PostPosted: 16:08 - 26 Apr 2006    Post subject: Reply with quote
if thats true what everybody is saying then it is definately restricted or else i'm not pulling the throttle back enough and giving it eno0ugh revs cos it won't do above 70-80mph downhill with very strong wind attached!!!!!!!!!!!! Crying or Very sad Crying or Very sad
Gazdaman
I did a trackday!!!
PostPosted: 19:06 - 26 Apr 2006    Post subject: Reply with quote
Yes, it should go faster than that.
Is it firing on all cylinders? Are all the downpipes hot while the engine's running?
Gaz
mark allsopp
PostPosted: 15:34 - 27 Apr 2006    Post subject: Reply with quote
oh yes it fires on all cylinders and i had somebody change the carbs last year because i had one go down perhaps he did not set them up as well as he should have done i have checked every else out even changed plugs and replaced with titanium tipped ones!!!!!!!
greatmoorred
PostPosted: 19:58 - 27 Apr 2006    Post subject: Reply with quote
sounds like somethings wrong there mate, ive got a 400 bandit and it will do 95, and i assume, a bit more, but it was a country road and it was a bit bumpy Embarassed
mine sits at 70-75 quite hapily.
craigs23
Mr Muscle
PostPosted: 20:02 - 27 Apr 2006    Post subject: Reply with quote
I saw 110 a few times on my Bandit 400, with around 12-12,500 showing on the tacho. I reckon it'll be good for an indicated 115-120.
quik_d
PostPosted: 23:07 - 27 Apr 2006    Post subject: Reply with quote
my bros will sit at 80 quite happy and thats only 33BHP so the bandit should easy do that and more. Shocked Time to start checking things out i think
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
mark allsopp
PostPosted: 08:53 - 04 May 2006    Post subject: Reply with quote
okay so now we have established it's slow and not fast look in the for sale section as i'm listing it in there for anybody who wants a medium fast bike that go's slow hahahahahahaahahahahahahahaah!!!!!!!!!!!!! Laughing
The last post was made 20 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 88.68 Kb
