 phill.c Traffic Copper
 Posted: 11:07 - 26 Apr 2006 Post subject: Grease and Lubes ??? |
Hello,
My bike has been stood since December ive been doing a few jobs cleaning polishing and so on. What I want to know is before I put it back on the road do I need to use any grease or lubes for the the following:
Wheels spindles
Levers
Calipers
Throttle tube - just put a new one on
Cables.
If somebody could tell what I need to use for each one that would be great or if there is anything else I need to do.
Thanks
Phill.c ____________________ CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed  |
 the grim reaper World Chat Champion
 Posted: 11:52 - 26 Apr 2006 Post subject: |
Wheel spindles - high temp grease, NOT copper grease, the copper grease breaks down.
Levers - Same as spindles, if only because it is slightly better than copper grease.
Calipers - brake grease if you're talking about the pistons, high temp again if you're talking about sliding calipers
Throttle tube - ditto, don't use copper grease near electrical bits and pieces.
Cables - If they're teflon lined, you shouldn't need to lube them but, if you decide to anyway, do NOT use WD40, it causes the teflon to swell and makes them worse. 3-in-1 oil is probably best.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
 Posted: 12:08 - 26 Apr 2006 Post subject: |
thanks for that mate appreciate it  ____________________ CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed  |
